I updated to the latest Proffie OS (6.9) and Arduino IDE (2.1.0). When verifying a config, I get “redefinition of void setup" and “void loop”. This happens with configs that used to verify just fine. They all have this same error now. Help!
Please post the full error message and your config file.
C:\Users\hp\Desktop\ProffieOS\trinket.ino:20:6: error: redefinition of 'void setup()'
20 | void setup() {
C:\Users\hp\Desktop\ProffieOS\ProffieOS.ino:1407:6: note: 'void setup()' previously defined here
1407 | void setup() {
C:\Users\hp\Desktop\ProffieOS\trinket.ino:27:6: error: redefinition of 'void loop()'
27 | void loop() {
C:\Users\hp\Desktop\ProffieOS\ProffieOS.ino:1520:6: note: 'void loop()' previously defined here
1520 | void loop() {
Compilation error: redefinition of 'void setup()'
#define VOLUME 2000
#define CLASH_THRESHOLD_G 1.0
//#define ENABLE_BLASTER_AUTO
#include "../props/blaster.h"
{ "Solo", "tracks/blast.wav",
StylePtr<Lockup<BlastFadeout<BlastFadeout<Black,AudioFlicker<Black,Red>,250,EFFECT_FIRE>,AudioFlicker<Black,Blue>,1500,EFFECT_STUN>,AudioFlicker<Black,Red>>>(),
"blast"
{ 0,
WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets)
Where did this file come from?
It’s not supposed to be in the ProffieOS directory.
I have no idea. I just updated to the latest Proffie and Arduino. Now all my configs that used to verify now display this same error, exactly to the positions of the error message.
Is there a way to correct this on my end?
I reverted back to Proffie 6.7 and all verify as they should.
Obviously you shouldn’t have to do that.
Deleting trinket.ino is probably enough.
Great! Thanks for your help.
