Idk if this is the right thread to post this on, but I’m trying to make a custom Neopixel Lightsaber using Proffie and I have a number of questions I can’t seem to find direct answers too.
If I use 4 pixel strips in a blade what should I rate the whole system to handle, Voltage and Amperage-wise.
Is there any point to adding Voltage Regulation, so I can use most any Battery of proper size to fit in a hilt. If I should, how should I make it?
Adding Ground Loop Isolation for the Speaker. Pointless or not?
Using a Latching or Reed Switch as a Kill Switch, instead of a high amp Slide Switch.
Putting the Kill Switch on the negative side instead of the positive side
Would it be useful/worthwhile or not to build into the hilt itself an mini ST-LINK with its own dedicated external port.
Is it a good idea to use a magnets for a quick connect blade?
Is there a certain Battery Recharge board anyone would recommend over others?
Wireless Charging, good or bad idea?
There will probably be more questions I think later, so I’ll add as I think of them
(Main Board)
Proffieboard v2.2
(Added Features)
OLED Display
Bluetooth Connectivity
External On/Off & Indication
Internal Debugging
External Type-C Plugs
External Board Reset Button
External Kill Switch/Button
3 Primary Buttons
Main Button: Power On/Off
Aux Button 1: General Effects Tap/Menu Control Hold
Aux Button 2: Special Effects Tap/Sound Font Selection Hold
1 or 2 Speakers
Audio Amplification Circuitry
?External Volume Adjustment?
Built-in Battery Protection Circuitry
Built-in Battery Type-C Recharge Circuitry
?Hilt Ring LED Battery Level Indication?
?Voltage Regulation Circuitry?
?Anti-Feedback Circuitry?
This is most or less the end goal for the Saber
