Question on Pull to the Darkness font
I have everything loaded up, but once the coruption finishes, the blade goes immediatly back to blue. tried with both pre-set options. is this something with my saber or do i possibly have something no enabled correctly?
If you post your config text with the full top section produced by his library, then Fett263 and others can see what might be wrong.
To paste it here, press the </> button above the reply box and paste with the code between the backticks like
this
Did you set up the altNNN folders in your font as the style expects? This behavior is almost always due to the alt font not being set up.
The other possible issue is multiple Control Layers in your preset. If you have multiple blades make sure there’s only on Control Layer style.
Watch the Recommended videos at the top of the library, it will cover how to set up.
I had a typo on the alt folder. one to many 0’s
got it working
