I was reading through the new props in 8.1 and see the results of @Sabersense 's work. Amazing!
The clicking feature sounds like a great solution to sabers that suffer from squishy buttons (they look so good, though
The saber I’m taking about relies on the Fett263 prop. Can I move the Sabersense click feature into Fett’s prop? I feel like there’d be an issue with defines. I’ll certainly try if it’s possible!
Not familiar, what is it you’re wanting? I’m currently updating my prop for OS8 so I can probably add the option in via a define.
#define SABERSENSE_BUTTON_CLICKER
Button Clicker to play press/release wav files when
buttons are pressed. Intended for Scavenger hilt
where wheel makes tactile feel difficult.
Requires press.wav and release.wav files to work.
void PlaySound(const char* sound) {
RefPtr<BufferedWavPlayer> player = GetFreeWavPlayer();
if (player) {
if (!player->PlayInCurrentDir(sound)) player->Play(sound);
if (GetWavPlayerPlaying(&SFX_boot)) return false;
switch (EVENTID(button, event, modifiers)) {
case EVENTID(BUTTON_POWER, EVENT_PRESSED, MODE_ANY_BUTTON | MODE_ON):
case EVENTID(BUTTON_POWER, EVENT_PRESSED, MODE_ANY_BUTTON | MODE_OFF):
case EVENTID(BUTTON_AUX, EVENT_PRESSED, MODE_ANY_BUTTON | MODE_ON):
case EVENTID(BUTTON_AUX, EVENT_PRESSED, MODE_ANY_BUTTON | MODE_OFF):
SaberBase::RequestMotion();
#ifdef SABERSENSE_BUTTON_CLICKER
// Intended to play click sound on button presses, primarily for Scavenger
// hilt where wheel makes tactile switch feel difficult.
PlaySound("press.wav"); // Requires press.wav file to work.
return false;
case EVENTID(BUTTON_POWER, EVENT_RELEASED, MODE_ANY_BUTTON | MODE_ON):
case EVENTID(BUTTON_POWER, EVENT_RELEASED, MODE_ANY_BUTTON | MODE_OFF):
case EVENTID(BUTTON_AUX, EVENT_RELEASED, MODE_ANY_BUTTON | MODE_ON):
case EVENTID(BUTTON_AUX, EVENT_RELEASED, MODE_ANY_BUTTON | MODE_OFF):
PlaySound("release.wav"); // Requires release.wav file to work.
In the saber sense prop:
I first saw it here in the OS8 beta thread:
Not sure where to begin and end, but in prop I see:
return false;
if (SaberBase::Lockup()) {
SaberBase::DoEndLockup();
SaberBase::SetLockup(SaberBase::LOCKUP_NONE);
return true;
} else {
return false;
That would be most excellent of you if possible.
If you need click effects, there are some sound file downloads on my website that include them:
Thanks, seems straightforward enough, I have a queue of OS8 additions to work through but should be able to implement.
