Program Crystal Chamber to not just mirror blade
Hi, I am building a crustal chamber and want it to behave differently than the blade. When the blade is off I want it to slowly pulse for example. Is there a resouce that walks through how to do this? Will it kill my battery life?
First you’ll want to wire it to act as it’s own blade. Either by wiring independent or by wiring in series with a blade and using SubBlade to set it up as it’s own blade. Once it’s wired as it’s own blade and set up in your BladeConfig, you can then just build a style in my library for Crystal Chamber and set the OFF Behavior however you want.
In terms of battery life, you’ll want to define IDLE_OFF_TIME accordingly to have the saber power down at some point or it will run through your battery fairly quickly.
