Profiles dont change on blade id
Hi, I use the gitversion ce12a06a1e236b5101ec60c950530a9a4719a74d
Since that profiles dont change when the blade changed. blade is recognized correct.
scanid select correct blade but profiles dont change. It stays in array “presets”, instead of jump to array “no_blade”. Serial reset command, dont change the preset set.
I read in the commits that there was a change relying to blades.
Or could it be the save preset option??
    WS281XBladePtr<474, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3, bladePowerPin4, bladePowerPin5> >(), /
    DimBlade(30, SubBladeWithStride(0, 0, 2, WS281XBladePtr<16, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin
    DimBlade(70, SubBladeWithStride(1, 15, 2, NULL)), // Dim2
    CONFIGARRAY(presets)
    600000,
    WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3, bladePowerPin4, bladePowerPin5> >(), //
    CONFIGARRAY(no_blade)
Here are my preset array, simplified
    "Deadlink;fallback;common",
    StylePtr<MainRandomFlickerTwoColorBaseColor>(),
    StylePtr<Black>(),
    StylePtr<Black>(),
    "My"
    "Battery;fallback;common",
    &style_charging,
    StylePtr<Black>(),
    StylePtr<Black>(),
    "Charging"
Preset no_blade[] = {
    "NoBlade;fallback;common",
    StylePtr<Black>(),
    StylePtr<AccentPower>(),
    "No Blade"
Hope you know what I mean;-)
nice day
Command back, I updated the repo, and now its fine again.
Sorry, I know this I should have done before stealing someones time.
You really should have a speparate save directory for the “no blade” case.
