ProffieOS7.x Fett263 Prop File Updates
Thank you all. Getting closer!
7.4 resolves the Twist issue, it’s posted in the Beta thread.
Just thinking aloud here if this idea is worth exploring. @Fett263 Is there a way to have the prop setup so if you are just using the color change button combination (with the saber ignited for a quick blade color change) so the ignition and retraction mirror the color change without having to end up going into EditMode to finalize so ignition, blade, and retraction all match like we could do w the old syntax?
That depends on how you write the style, not the prop.
followed your instructions on how to do the multi phase/alt font with special abilities.
My question is how do I actually activate a special ability? I have a 1 button saber, do I have to hold the button for a certain amount of time or do x number of clicks? Thanks
You need style code that supports and a define that enables, then just follow controls from this page.
