Last one for today, will get back to styling tomorrow.
Compile error, although things looked great in the library:
In file included from /Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/ProffieOS.ino:621:
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/config/SakiOS7.h:87: error: wrong number of template arguments (0, should be 1)
87 | StylePtr<Layers<Stripes<24000,-30,Stripes<3500,-3000,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>,Mix<Int<7710>,Black,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>>,Mix<Int<6425>,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>,White>,Mix<Int<16384>,Black,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>>>,Mix<Int<14000>,Black,Stripes<3500,-3000,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>,Mix<Int<7710>,Black,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>>,Mix<Int<6425>,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>,White>,Mix<Int<16384>,Black,Gradient<Rgb<0,255,0>,RotateColorsX<Int<30000>,Rgb<0,255,0>>>>>>>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,0,0>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-6000>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrSelect<IncrementWithReset<ThresholdPulseF<Sum<EffectPulseF<EFFECT_USER5>,EffectPulseF<EFFECT_USER6>,EffectPulseF<EFFECT_USER7>,EffectPulseF<EFFECT_USER8>>,Int<30000>>,EffectPulseF<EFFECT_RETRACTION>,Int<1>,Int<1>>,TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,992>,Int<98304>>>>,TrInstant>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrInstant,Black,TrConcat<TrWipeInX<Mult<Int<300>,Int<6553>>>,RandomBlink<30000,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Black>,TrJoin<TrDelayX<Mult<Int<300>,Int<19660>>>,TrWipeInX<Mult<IgnitionTime<230>,Int<6553>>>>,Mix<SmoothStep<Scale<SlowNoise<Int<30000>>,IntArg<EMITTER_SIZE_ARG,1000>,Sum<Int<5000>,IntArg<EMITTER_SIZE_ARG,1000>>>,Int<-3000>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<Int<300>,Int<19660>>>>>,EFFECT_USER5>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<600>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_USER6>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeInX<Int<300>>>,EFFECT_USER6>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<Int<600>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFade<800>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrInstant,Black,TrColorCycleX<Int<300>>>,EFFECT_USER7>,TransitionEffectL<TrConcat<TrInstant,Black,TrWipeSparkTipX<Rgb<255,38,0>,Int<300>>>,EFFECT_USER8>,TransitionEffectL<TrDoEffectAlwaysX<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_QUOTE,Int<0>,Int<-1>>,EFFECT_USER5>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_USER6>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_USER7>,TransitionEffectL<TrDoEffectAlwaysX<TrDoEffectAlwaysX<TrInstant,EFFECT_FAST_ON,Int<-1>,Int<-1>>,EFFECT_QUOTE,Int<>,Int<-1>>,EFFECT_USER8>>>(),
In file included from /Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/layers.h:5,
from /Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/sparkle.h:15,
from /Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/ProffieOS.ino:470:
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/functions/int.h:30:7: note: provided for 'template<int N> using Int = SingleValueAdapter<IntSVF<N> >'
30 | using Int = SingleValueAdapter<IntSVF<N>>;
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/config/SakiOS7.h:87: error: template argument 3 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/config/SakiOS7.h:87: error: template argument 1 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/config/SakiOS7.h:87: error: template argument 19 is invalid
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/config/SakiOS7.h:87: error: no matching function for call to 'StylePtr<<expression error> >()'
In file included from /Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/fire.h:4,
from /Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/ProffieOS.ino:469:
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/style_ptr.h:100:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr()'
100 | StyleAllocator StylePtr() {
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/style_ptr.h:100:16: note: template argument deduction/substitution failed:
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/style_ptr.h:124:16: note: candidate: 'template<class STYLE> StyleFactory* StylePtr(const char*)'
124 | StyleAllocator StylePtr(const char* default_arguments) {
/Users/catherinebogin/Documents/Sabers/ProffieOSCollection/ProffieOS7.14Sept2024/ProffieOS/styles/style_ptr.h:124:16: note: template argument deduction/substitution failed:
Compilation error: wrong number of template arguments (0, should be 1)
Config:
// ProffieOS7 Config File
#define NUM_BLADES 2
#define VOLUME 1000
#define CLASH_THRESHOLD_G 3
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define SAVE_PRESET
#define DISABLE_COLOR_CHANGE
#define FETT263_DISABLE_QUOTE_PLAYER
{ "EmpressPalpatine;common", "common/tracks/Empress.wav",
https://fett263library.com/early-access/#CustomBlade
OS7.14 v3.52
Merge Styles
Default: Glacier Crawl [Rgb<150,211,95> (Gradient Color Up = Gradient: 30000)
1: Death Star Blast [AltColorArg]
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Emitter Effect: Emitter Flare [Color: EmitterColorArg]
Special Ability 5: Play Sound - Ignite Uses quote00.wav or quote/000/000.wav
Special Ability 6: Ignite
Special Ability 7: Ignite
Special Ability 8: Play Sound - Ignite Uses quote.wav or quote/0/000.wav
/* copyright Fett263 (Accent LED / PCB) OS7 Style
https://fett263library.com/early-access/#Simple
OS7.14 v3.52
On Behavior: Unstable Flicker (Single Color) [Color: BaseColorArg]
Off Behavior: Heart Beat [Color: BaseColorArg]
Base Color: BaseColorArg (0)
PowerUp Effect: Power Flash [Color: IgnitionColorArg]
Lockup Effect: NoneLightning Block Effect: NoneDrag Effect: NoneMelt Effect: None */
StylePtr<Layers<RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10560>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,InOutTrL<TrInstant,TrInstant,TransitionLoop<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,TrFade<1200>>>>>>(),
"EmpressRage"
{"SailorMoon;common", "common/tracks/SailorMoon.wav",
OS7.14 v3.52
Wave (Stripe) Blade Stripe Width: 1000, Speed Option: Fixed, Speed: 0
Default: Static [Rgb<0,135,255>]
1: AudioFlicker (Single Color (25%)) [Rgb<255,0,255>]
Preon Effect: Center Absorb [Color: Rgb<255,64,255>]
Ignition Effect: SparkTip Center In [Color: IgnitionColorArg]
Retraction Effect: Cycle Down [Color: RetractionColorArg]
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
Special Ability 1: Play Quote
Special Ability 2: Next Quote
StylePtr<Layers<StripesX<Int<1000>,Int<0>,Remap<CenterDistF<>,Remap<InvertF<RampF>,RotateColorsX<Saw<Int<20>>,Gradient<Rgb<0,135,255>,RotateColorsX<Int<-4000>,Rgb<0,135,255>>,RotateColorsX<Int<-8000>,Rgb<0,135,255>>>>>>,AudioFlicker<Rgb<50,0,50>,Mix<Int<8192>,Black,Rgb<100,0,100>>>>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_NEXT_QUOTE,Int<-1>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrCenterWipeInSparkX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<0>,Int<16384>>,TrColorCycleX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Rgb<20,0,20>>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrInstant>,Remap<CenterDistF<>,Layers<TransitionLoopL<TrSparkX<RotateColorsX<Sin<Int<1000>,Int<0>,Int<32767>>,Rgb<255,64,255>>,Int<200>,Int<100>,Int<32768>>>,AlphaL<RotateColorsX<Sin<Int<1000>,Int<0>,Int<32767>>,Rgb<255,64,255>>,SmoothStep<Int<0>,Scale<Trigger<EFFECT_PREON,WavLen<EFFECT_PREON>,Int<500>,Int<200>,Int<100>>,Int<-1>,Int<-20000>>>>>>,TrInstant>,EFFECT_PREON>>>(),
/* copyright Fett263 CustomBlade (Accent LED / PCB) OS7 Style
OS7.14 v3.52
Wave (Stripe) Blade Stripe Width: 400, Speed Option: Fixed, Speed: 0
Off Behavior: Solid Color [Color: Rgb<255,0,255>]
Melt Effect:
StylePtr<Layers<StripesX<Int<400>,Int<0>,RotateColorsX<Saw<Int<20>>,Gradient<Rgb<0,135,255>,RotateColorsX<Int<-4000>,Rgb<0,135,255>>,RotateColorsX<Int<-8000>,Rgb<0,135,255>>>>,AudioFlicker<Rgb<255,0,255>,Mix<Int<8192>,Black,Rgb<255,0,255>>>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,31000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,26000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrInstant,TrInstant,Rgb<255,0,255>>>>(),
"SailorMoon"},
{ 0, WS281XBladePtr<109, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<13, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
