Awesome thank you
The special feature play quote will that sound from the quote folder or the previous way of putting quotes in the force folder ?
See notes in top of style code
it tells you the naming expected.
If using subfolders the name needs to be same as the sound, if you put quote01.wav in /force folder it canāt use. So quote01.wav would be in root or /quote folder.
That makes sense and will be awesome having the quotes be able to play seperate to actual force sounds just gets better
Quotes have been separate since OS6 ![]()
Iāll post this error here.
error.txt (126.4 KB)
I need the style code the library generated.
I have found the issue and submitted the fix, this will become v7.12 once profezzorn is able to review and update the OS. The fix will allow all Special Abilities to run Rain Mode (and a few other styles) properly and keep Rain Mode active while Off but still allow proper toggling.
Using Multiphase Lockup
Lockup 0: Responsive localised
Lockup 1: Any
Effect: Any except Intensity audio flicker on lockup 1
Stops preview with error: Missing > or ,
Also - are you planning to add multiphase options on Base Flare / Emitter Effect and Rain?
bladestyle.txt (9.5 KB)
OK, Iāll have a look tonight.
Not in the near future but possibly down the line.
So, this particular style (Thunderstorm or related āSmoke Bladesā) may not play well with Kyber Select color options. Iāll have to do a little testing but it seems like I may have to add some prevention in the library so it cannot be selected on these types of blades.
In the interim, if you want that blade style select a normal color option, not Kyber Select.
This should be fixed, it was actually the Begin Lockup selection that had the typo. Youāll need to refresh to get new script.
OS7.12 is now available with fix for Rain Mode in Special Abilities.
I wanted to create a yin-yang blade with the rain toggle and was playing with different rain colors. I think a little bug popped up.
Rain color set to AltColor2. No problems (red). I then changed the altcolor2 to green and it stayed red on the preview blade. I tried refreshing the preview, no change.
Then I closed out the preview/enhancements window, reopened by clicking back on Main Blade in the blade builder, and the changes were applied (alt color 2 was green, and so was the preview rain effect.)
I then repeated the process and got the same result, trying to change back from green to red as alt color 2.
The style code from a switch from red to green, where the preview remains red:
https://fett263library.com/early-access/#CustomBlade
OS7.12 v2.2
Yin and Yang Blade (Blade Angle)
Default: Audio Rotoscope - Single Color (Original Trilogy) [BaseColorArg]
1: Audio Rotoscope - Single Color (Original Trilogy) [AltColorArg]
Yin and Yang Blade: Blade changes based on pointing up or down, creates yin and yang effect when spun.
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
Special Ability 1: Toggle Rain Mode Uses trloop00.wav or trloop/000/000.wav (rain sounds looped)
StylePtr<Layers<Mix<IsLessThan<BladeAngle<>,Int<16384>>,AudioFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,AudioFlicker<Stripes<10000,-2600,RgbArg<ALT_COLOR_ARG,Rgb<255,244,157>>,RgbArg<ALT_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<7710>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,244,157>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,244,157>>>>,RgbArg<ALT_COLOR_ARG,Rgb<255,244,157>>>>,ColorSelect<EffectIncrementF<EFFECT_USER1,Int<2>>,TrFade<100>,AlphaL<White,Int<0>>,AlphaL<RgbArg<ALT_COLOR2_ARG,Rgb<0,255,0>>,SparkleF<300,800>>>,TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER1>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
The rain toggle is very cool.
Iāll have a look this weekend, Iām currently traveling.
This has been fixed, youāll need to refresh page to get update.
Iām getting a popup:
āMissing Retraction Effect Codeā
I canāt say what triggers it per-se, I think while changing some fields in the enhancements screen, and ultimately when clicking āGet Style Codeā. However, the style copy/pasted fine.
Post the style code you generated when it appeared, it will tell me which options you had selected. Then I can take a look tomorrow.
