Does the new style library not offer the base colours that OS6 one does? You had some quick and easy standard blade colours like silver and gold to choose from.
It has ALL of them, watch the Recommended videos at the top for how to use the new interfaces ![]()
Definitely watch the videos. He covers the entire lesson(s) on the changes in a really great way.
Ah yeah⦠Itās the little colour wheel icon. If I may make a UI suggestion, flip the colour block and wheel icon functions, since most people will just want the quick access (ie reaching for the bigger button) and have the colour picker as the wheel (since it is a closer approximation of the function).
The ābigā icon IS the color input, itās an html object (same as Style Editor). The ācolor wheelā icon is a menu that preloads the ānamedā sounds into the color input. I can see if thereās a different icon I can use but not sure when Iāll get to it, I still have a lot of work on my plate. TBH, just hover over objects or click on them if youāre not sure what they do, itās all pretty self explanatory if you try it.
Given the color wheel has a target point maybe just having a brightly colored or pulsing surround on the color block selected would work? Then itās just visually intuitive both ways.
Thatās generated by your browser, other browsers have different input views for that object.
Ahh. Iāll have to try it out in Chrome for Mac instead of Safari then.
Iāve a question as Iām thinking of trying this out this weekend. Does the tr00.wav have to rest solely in a single folder and can I differentiate it across different folders? Like if I want the transition sound a specific one for my Fallen/Survivor alt-font and a different one for the Darksaber alt-font?
*So far everything works perfect. ![]()
Any and all sounds work with altNNN set up.
Just being honest, in terms of the amount of work Iāve done and the amount I have in front of me, this super, super, super low priorityā¦
This is awesome. I was also wondering if we have any more documentation on the free 123 pads and and other additional pads on the board. I havent found any new documents pertaining to this. The cofigurrator for v3 still has the use of 4 data lines and no more. I would like to incorporate more of the out pads including data so some of these new style items can be applied. Any info would be awesome. Thanks in advance.
Probably better to post in its own thread, this is a board specific question, not really related to the library.
Ok thanks. I went and did that. We can delete my inquiry here.![]()
Weāre getting a āMissing Preon Codeā popup with some preon selections in the Greyscale section.
[Screenshot Removed as requested.]
Helping the kids and the class I help with look at it I noticed if you pull the āGet Style Codeā it of course doesnāt have the preon options but also your licensing info is missing.
Initial code given right after the popup is⦠(*which tells me things ARE working to a degree)
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<200,0,0>>>,
//Red audioflicker
TransitionEffectL<TrConcat<TrFade<200>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SwingSpeed<500>>,TrDelay<30000>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,SwingSpeed<500>>,TrFade<800>>,EFFECT_FORCE>,
//Force effect, temporarily allows a swing effect where solid dark orange takes over the blade when swinging
AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Red>,Black,300>,SwingSpeed<315>>,
//Unstable swing
LockupTrL<Layers<
AlphaL<NavajoWhite,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>>,SaberBase::LOCKUP_NORMAL>,
//Responsive lockup
//Responsive lightning block
Mix<Sin<Int<8>>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Bump<Int<0>,Int<6000>>>,AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Bump<Int<0>,Int<22000>>>>,
//Timed "breathing" emitter flare - NOTE: Due to the way Proffie works, this isn't always "lined up" and might be slightly ahead or slightly behind the hum's breathing. To fix you can turn the saber off and back on until it's lined up. The timing is right, but the code runs in the background even after turning the saber off so it doesn't always start "on time."
//AlphaL<RotateColorsX<Variation,Rgb16<65535,11439,0>>,Bump<Int<0>,Scale<TwistAngle<>,Int<3000>,Int<20000>>>>,
//Alternate twist responsive "breathing" emitter flare, twist the hilt in time with the breathing in a meditative way, or time it while going through different stances, etc.
ResponsiveStabL<Orange>,
//Responsive stab
//Responsive clash
//Drag
//Responsive melt
InOutTrL<TrWipe<2650>,TrWipeIn<1375>>,
//Wipe out ignition, wipe in retraction
TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
So I tried a trick and hit refresh to ignore the popup and all of a sudden you get the preon and full code. Then hitting Get Style Code itās all there. (*Now it works!?)
/* copyright Fett263 Greyscale (Primary Blade) OS7 Style
https://fett263.com/fett263-proffieOS7-style-library.html#Greyscale
OS7.11 v1.016-p
Base Style: Analog (AudioFlicker with Ripple Swing)
Base Color: BaseColorArg (0)
Preon Effect: Emitter Heat Up [Color: PreonColorArg]
StylePtr<Layers<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<20000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,AlphaL<RotateColorsX<Int<27000>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,SwingSpeed<500>>,AlphaL<Stripes<2500,-4000,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,Mix<Int<7710>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,Pulsing<Mix<Int<3855>,Black,RotateColorsX<Int<31000>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,Black,800>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrExtendX<WavLen<EFFECT_PREON>,TrFade<100>>,AlphaL<HumpFlickerL<Mix<Trigger<EFFECT_PREON,Mult<WavLen<EFFECT_PREON>,Int<24000>>,WavLen<EFFECT_PREON>,Int<500>>,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,White>,20>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-3000>>>,TrFade<200>>,EFFECT_PREON>>>(),
Browsers are Chrome and Safari (for Mac), multiple devices. Cannot verify via pc.
@NitTheGrit and @NoSloppy can you cross verify please?
Remove screenshots itās not needed. Which specific Preon selection triggers the error?
Screenshot removed as requested. Itās not all of the Greyscale presets, only certain ones and it starts at the Emitter Heat Up and Seismic Charge preons in the Analog and Splinter bladestyles.
I can ask their instructor to get us a list. Iām only helping there two days a week. Can probably have it by Thursday or Friday. ![]()
If it said āMissing Preon Codeā I just to know the preon that they were trying to add. The alert means the script couldnāt find the code for that specific preon selection. I donāt need a list, you try to set a Preon, it canāt find the code, you tell me the preon name, I fix it.
Will do. Give us a couple days. ![]()
Hi Fett263,
Iām redoing my config for the build Iām doing (with my new proffieboard that I just bought).
the Interactive Ice Blade (force effect) doesnāt trigger, I tried to change the colour and trigger the force button but nothing happened. I had another force trigger and that seems to work (Interactive Power build up force effect).
