This could use some Documentation
I have an interface coming to this tool that will make it much easier to see and set up as well.
Thanks. I had searched “arg” and got nothing, although I remember seeing that page.
You could have found it by looking it up in the ProffieOS 7.x documentation thread.
Feel free to improve it though.
It could use some examples with multiple arguments, and maybe some examples of how to copy arguments from an ini file into a configuration (or vice versa)
I’m also adding support for all this stuff in the style editor btw.
Here’s an example that seems to work.
StylePtr<CrystalHyperResponsiveRotoscopeOriginalTrilogyDodgerBlue>(
"65535,0,0 ~ ~ ~ ~ ~ 0,65535,0 ~ 0,65535,0 0,65535,0"
I was hoping to be able to do something like the following to make it more human readable, but from what I can tell, that’s not possible. Will definitely work for making a complex style and reusing it multiple times.
"65535,0,0 " // BASE_COLOR_ARG = 1, // Primary Base Color
"~ " //ALT_COLOR_ARG = 2, // Alternate or Force Color (free-use)
"~ " //STYLE_OPTION_ARG = 3, // Style Option
"~ " //IGNITION_OPTION_ARG = 4, // Ignition Options
"~ " //IGNITION_TIME_ARG = 5, // used in IgnitionTime alias
"~ " //IGNITION_DELAY_ARG = 6, // Ignition Delay Time
"0,65535,0" //IGNITION_COLOR_ARG = 7, // Ignition "Power Up" Color
"~ " //IGNITION_POWER_UP_ARG = 8, // Ignition "Power Up" Options
"0,65535,0" //BLAST_COLOR_ARG = 9, // Blast Color
Hence the interface Fredrik is building into the Editor and I’m working on for this tool .
You can comment if you want but the value needs to be in the “” for it be read.
("65535,0,0 " // BASE_COLOR_ARG
"~ " // ALT_COLOR_ARG
"3 " // STYLE_OPTION_ARG
This line is missing a space before the second "
, if you fix that, I think it will work.
You are absolutely correct. Thank you! It’s working now.
I don’t know if this is a Config Helper issue, a Style issue, or a ProffieOS 7.3 issue.
I’ve set the Off Behavior of my CC to have a pulsing flicker two color, and it only pulses in a single color. No flicker, no second color.
using CrystalFallenOrderCalKestisSilver = Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,InOutTrL<TrInstant,TrInstant,AudioFlicker<Pulsing<Rgb<0,66,170>,Mix<Int<16384>,Black,Rgb<0,66,170>>,3000>,RgbArg<ALT_COLOR_ARG,Rgb<50,50,75>>>>>;
You set it to AudiofFicker. … There’s no audio when it’s off.
Maybe you want to use RandomFlicker instead?
I’ll have a look when I get a chance.
OK, this has been fixed. You’ll need to refresh the page(s) to get the update.
As Brian noted, AudioFlicker uses the sounds that are playing to generate your flicker, if you play a Track or use the Force/Quote while Off you should see it flicker accordingly, if you just want it flicker or do something without sounds select a different effect.
Thanks I’ll try it soon !
Thanks, playing with it now. Do note this Style was from your Style Library.
Yeah, I know. People use it so it’s in there but if it’s not what you’re after there’s a ton of other options.
So how does this work? Are these in position of the order the ARGs are found in the style? Like 1:1?
It’s not where they are found in the style, but which enum value is used.
BASE_COLOR_ARG is always the first one, regardless of where it is in the style.
This page has the full list:
Here’s the easy to read and edit version.
StylePtr<MainFallenOrderCalKestisDodgerBlue>(
/* Style argument overrides. Each value is in the order expected from https://pod.hubbe.net/config/styles/style_arguments.html.
Each value must end in a space.
"~ " means "use the default value for the style as built"
colors must be coded as Rgb16 /**/
"65535,0,0 " //BASE_COLOR_ARG = 1, // Primary Base Color
"~ " //IGNITION_COLOR_ARG = 7, // Ignition "Power Up" Color
"2 " //IGNITION_POWER_UP_ARG = 8, // Ignition "Power Up" Options
"~ " //BLAST_COLOR_ARG = 9, // Blast Color
"~ " //CLASH_COLOR_ARG = 10, // Clash Color
"~ " //LOCKUP_COLOR_ARG = 11, // Lockup Color
"~ " //LOCKUP_POSITION_ARG = 12, // Clash/Lockup Location for Responsive Effects (mid-point)
"~ " //DRAG_COLOR_ARG = 13, // Drag Color
"~ " //DRAG_SIZE_ARG = 14, // Drag Size
"~ " //LB_COLOR_ARG = 15, // Lightning Block Color
"~ " //STAB_COLOR_ARG = 16, // Stab / Melt Color
"~ " //MELT_SIZE_ARG = 17, // Stab / Melt Size
"~ " //SWING_COLOR_ARG = 18, // Swing Color (Responsive Swing Effects)
"~ " //SWING_OPTION_ARG = 19, // Swing Options (Responsive Swing Effects)
"~ " //EMITTER_COLOR_ARG = 20, // Emitter Color (Emitter Spark) can be used for PostOff
"~ " //EMITTER_SIZE_ARG = 21, // Emitter Size (Emitter Spark), can be used for PostOff
"~ " //PREON_COLOR_ARG = 22, // PreOn Color
"~ " //PREON_OPTION_ARG = 23, // PreOn Option
"~ " //PREON_SIZE_ARG = 24, // PreOn Size
"~ " //RETRACTION_OPTION_ARG = 25, // Retraction Options
"~ " //RETRACTION_TIME_ARG = 26, // used in RetractionTime alias
"~ " //RETRACTION_DELAY_ARG = 27, // Retraction Delay Time
"~ " //RETRACTION_COLOR_ARG = 28, // Retraction "Cool Down" Color
"~ " //RETRACTION_COOL_DOWN_ARG = 29, // Retraction "Cool Down" Options
"~ " //POSTOFF_COLOR_ARG = 30, // PostOff Color
"~ " //OFF_COLOR_ARG = 31, // Off Color (Color when blade is Off for crystals and accents)
"~ " //OFF_OPTION_ARG = 32, // Off Options (when blade is Off, for crystals and accents)
// Arguments 33 and up are new in ProffieOS 7.x
"~ " //ALT_COLOR2_ARG = 33, // Generic 2nd Alt Color
"~ " //ALT_COLOR3_ARG = 34, // Generic 3rd Alt Color
"~ " //STYLE_OPTION2_ARG = 35, // Generic 2nd Style Option
"~ " //STYLE_OPTION3_ARG = 36, // Generic 3rd Style Option
"~ " //IGNITION_OPTION2_ARG = 37, // Ignition BEND Option
"~ " //RETRACTION_OPTION2_ARG = 38, // Retraction BEND Option
