good day,coming of the back of my previous post the voice pack error is gone however i am unable to pull up the edit section of the proffie os workbench
it stays stuck on fetching edit options
I can look into it.
However, some more information might be needed, like:
Also, if you can check the “developer tools” to see if there is a backtrace or error of some sort there, that would be very helpful. (Let me know if you need help with this.)
chrome,pc,latest v8 proffie,fett 263 prop(i believe thats what its called)
myconfigexp2.h (51.8 KB)
i will include devtool errors asap
Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘replaceAll’)
at style_arg_edits (app.html:651:37)
at make_style_field (app.html:704:10)
at updateEditPane (app.html:861:12)
at updateCurrentPreset (app.html:887:5)
at showCurrentPreset (app.html:874:3)
at SetPreset (app.html:918:3)
does this help?
also
app.html:699 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘TEMPLATE’)
at make_style_field (app.html:699:41)
hello i put the reply to the questions in post have you had a chance to look?,i have taken a lightsaber programming hiatus up until now so im back on it again
Sorry for the long delay.
I took a look at the code, and it’s a bit of a head-scratcher.
Two things that may help:
1.ok i got what im sure is the code from above the error,ENABLING EDITING
app.html:481 Sending 19| get_max_blade_length 1
app.html:437 > 1,3,19|114
app.html:481 Sending 20| get_blade_dimming
app.html:437 > 1,5,20|16384
app.html:481 Sending 21| get_clash_threshold
app.html:437 > 1,4,21|3.00
app.html:481 Sending 22| get_gesture test
app.html:437 >
app.html:481 Sending 23| sd
app.html:437 > 1,12,23|SD Access ON
app.html:1630 ENABLING SETTINGS
app.html:649 Array(3)
app.html:652
base color
app.html:653 undefined
app.html:657 62194,20303,0
app.html:652
alt color
app.html:657 ~
app.html:652
style option
app.html:657 0
app.html:652
ignition option
app.html:657 ~
app.html:652
ignition time
app.html:657 500
app.html:652
igniti
app.html:657 ~
2.i think this is right
VOID ~
Style RAM = 1740
VOID ~
Style RAM = 1740
VOID ~
Style RAM = 1740
VOID ~
Style RAM = 1740
VOID ~
Style RAM = 1740
VOID ~
Style RAM = 1740
INT 10992
INT 10992
Battery voltage: 4.01
Ln 15, Col 46
Proffieboard V2
on COM6
2
Style RAM = 1728
VOID ~
Style RAM = 1728
VOID ~
Style RAM = 1728
VOID ~
Style RAM = 1728
VOID ~
Style RAM = 1728
VOID ~
Style RAM = 1728
VOID ~
Style RAM = 1728
INT 10992
Ln 15, Col 46
Proffieboard V2
on COM6
2
i used another version of proffie os workbench made by criptic96 and that actually loaded my edit options for about twenty seconds and then it froze,im going to grab the devlogs from there as well and see how they compare
errors here:
usb.js:23 [UsbInterop] USB read exception
Like I told you before in a PM, but I thought it might be a good idea to also mention it here.
I had a (somewhat) similar problem, which I resolved using a different usb cable.
I noticed I had connection problems with the workbench, and also my own workbench version. When I went to investigate I found out the serial monitor from arduino IDE also had connection issues.
After using a different usb cable, most of my connection issues were gone.
Maybe it’s these things messing it up.
Let me do some testing…
ok new cable arrived no change at all
