ProffieOS v6.x ALPHA testing
Yes indeed.
OK Done for tonight, but last 2 things to report before I go.
At the moment pairing is not working using this in the config.ini and having same # of files for preon-out and pstoff-in
ProffieOS.SFX.preon.paired=1
ProffieOS.SFX.pstoff.paired=1
2nd, These both compile fine, but using WavLen causes nothing to show on the blade. This works fine:
TransitionEffectL<TrConcat<TrInstant,Green,TrDelayX<Int<700>>>,EFFECT_POSTOFF>,
This does nothing:
TransitionEffectL<TrConcat<TrInstant,Green,TrDelayX<WavLen<EFFECT_POSTOFF>>>,EFFECT_POSTOFF>,
I tried with WavLen<> no specified EFFECT same result.
Good progress night!
This won’t work, because the pairing needs to be done on the sound that is first. So to link OUT to PSTOFF, you would want ProffieOS.SFX.out.paired=1.
The first one ought to work though. I will check that out.
I’m guessing that the WavLen issue is because for some reason the postoff wavlen is returning zero. Will check that too.
WavLen/WavNum should now work for EFFECT_PSTOFF I think.
Found & fixed a bug in the variable parsing.
Haven’t actually tested that paired/volume it works properly yet though.
So if this is system wide, should pairing OUT to HUM work?
And therefore even BGNLOCK to LOCK , LOCK to ENDLOCK etc…?
Currently you can only pair things that play “gapless”.
In monophonic mode, “poweron” has a gapless transition to the hum, as do most effects in fact. However, in polyphonic mode, the two effects overlap, so pairing them is not currently possible.
I suppose we could potentially change the way this is configured to something like: ProffieOS.SFX.hum.paired=out; That would also have the advantage that it would be possible to do things like pairing in to out, or pstoff to preon.
Tested EFFECT_POSTOFF - now working.
WavLen<> within the TransitionEffectL without EFFECT specified also works fine.
Pairing sounds - test conditions:
Same #of preon and out files.
Same # of in and pstoff files.
ProffieOS.SFX.in.paired=1
  • result no pairing.
Changing the default here to true, it does work, so it’s close to working.
Pairing EFFECT_PREON blade effect to selected preon.wav file - test:
( the above temporary setting default to true still set for testing)
ColorSelect<SELECTION,COLOR1,COLOR2....> where SELECTION is WavNum<> and no EFFECT is specified, random COLOR is selected along with random sound.
When giving it the EFFECT as in ColorSelect<WavNum<EFFECT_PREON>.... , the COLORs are chosen correctly and match 1:1
This is likely expected, as ColorSelect doesn’t have an EFFECT already, it’s just that it compiles, but no warning that it’s not going to work.
I can’t think of any kind of check to prevent this, it just needs to be done right.
Updated top post.
Will take a look at this:
Discovered that readVariable doesn’t accept dots as variable names.
That should be fixed, so maybe it works now?
Working! 123
Testing Gapless preon-> out again.
Slight pop at beginning of preon, at the seam, and at the end of out.wav.
Maybe that’s the 500Hz sine test tone I used? It does have zero crossings and loops seamlessly unto itself. Typical saber sounds and even testfont spoken files sound fine.
Or did microfades on sounds’ beginnings and ends need to change at all to make gapless work?
Gapless just means that the samples are played as if it had been one file. It doesn’t blend, fade or modify the samples in any way.
Regarding Edit Mode using FETT263 prop file…
It seems the maximum setting for clash threshold is stuck at 4.
I want to increase it to 6 to allow for a larger range of clash threshold settings available in the edit menu, but I haven’t had any luck. I have tried deleting global.ini/global.temp from my SD card and reuploading my config with CLASH_THRESHOLD_G 6.0
Here are the #defines I am currently using in my config file in case I have a conflict going on that I am not aware of:
#define VOLUME 3000
const unsigned int maxLedsPerStrip = 135;
#define CLASH_THRESHOLD_G 6.0
//OS6 defines
#define FILTER_CUTOFF_FREQUENCY 250
#define FILTER_ORDER 12 // Higher filter orders also uses more cpu has to be an even number between 2 to 16 and defaults to 8
//#define DYNAMIC_BLADE_LENGTH
#define DYNAMIC_CLASH_THRESHOLD
//FETT263 prop defines
#define FETT263_CLASH_STRENGTH_SOUND // enables Clash Strength selection for sounds
#define FETT263_MAX_CLASH 16 // optional define to set the hardest clash on saber range 8 ~ 16, defaults to 16 if not defined
#define FETT263_SWING_ON
#define FETT263_SWING_ON_SPEED 250 // 250 ~ 500 recommended
#define FETT263_TWIST_ON // automatically enters Battle Mode
//#define FETT263_SAY_COLOR_LIST // requires .wav files
//#define FETT263_SAY_COLOR_LIST_CC // requires .wav files
//#define FETT263_SAY_BATTERY // requires .wav files
//FETT263 prop battle mode defines
#define FETT263_LOCKUP_DELAY 200 // delay in millis to determine Clash vs Lockup 200 default
#define FETT263_BM_CLASH_DETECT 6 // max value to use clashes in Battle Mode Range 0 ~ 6
If I recall 4.0 was the max value possible, is this right @profezzorn? All the max values are built into the menu system, you can’t override them. If it can be set higher then I’ll update the menu accordingly.
Technically it depends on what the hardware is.
However, for Proffieboards, the maximum was essentially 4 up until proffieOS 5.x
In 6.x it is 16, assuming I wrote the code correctly.
OK, so change max to 16.0?
I should also point out that clash thresholds might need to be tweaked a little between 5.x and 6.x.
The acceleromer is getting read more often, which will change the sensitivity a little.
(And yes, I think you should probably change the max to 16, but I’m not sure if it’s useful to be able to make it that high.)
OK, how about 8.0 (or something else)? Seeing as CLASH_THRESHOLD_G becomes the minimum value when calculating for the Clash Strength Sounds, if you set it too high there’s no range to calculate seeing as 16.0 is the maximum level detected.
If you’re going to make it lower than 16, then you should also test it to make sure that whatever maximum you choose is reasonable.
Fair enough, I’ll do some testing and update.
