ProffieOS v6.7 is now LIVE
Not really solved from my end. You shouldn’t be able to trigger a Lockup during Edit Mode, that’s what I’m trying to sort out. The code in my prop ignores effects while Edit Mode is active so still need your Serial Monitor output when it happens. I cannot recreate no matter how hard I hit the saber during Edit Mode no clash, no lockup, nothing so I need to see what is actually being detected in your Serial Monitor to figure out how it even occurred in the first place.
I get what you mean. Please spell out the specific typed commands to use while in Serial Monitor for the two button combination as well as the scroll functions so I can engage EditMode without having to handle the buttons or accidentally move the saber to get to the point I was at in Color List. Do I type “On+Aux” etc? Also I could not get any sound since the standard steps require disconnecting from the SD and I’ll give things another try. Again I get where you’re coming from and am down to try, it’s that I just don’t want to end up ripping my port shield cover off while trying this while running the cable. A side benefit of using this method to see how it is triggered and record at the same time is it eliminates any subtle movements while the audible Edit Menu prompts are playing and will give a truer read of the situation.
I just need you to recreate what your video shows with the Serial Monitor active and post the output from around the time it occurred.
I think turn is just ‘left’ or ‘right’ but I forget. I typically just do the actual actions on the saber and support the cable.
I grabbed a different cable and secured it before playing around. Here’s a quick recording in EditMode, it did a melt or drag towards the end. I’ll see what else I can get for you. A specific thing to note is it is a lot harder to get it to trigger with the sleeve and pommel off.
Welcome to ProffieOS v6.4. Type 'help' for more info.
Battery voltage: 4.02
EVENT: Power-Pressed#1 millis=22089
EVENT: Power-Pressed millis=22089
EVENT: Power-Released#1 millis=22340
EVENT: Power-Released millis=22340
EVENT: Power-Shortclick#1 millis=22340
EVENT: Power-Shortclick millis=22340
Ignition.
unit = 0 vol = 0.00, Playing TFULIGHT/hum/hum01.wav
unit = 1 vol = 0.50, Playing TFULIGHT/out/out03.wav
humstart: 1800
unit = 2 vol = 0.00, Playing TFULIGHT/swingl/swingl01.wav
unit = 3 vol = 0.00, Playing TFULIGHT/swingh/swingh01.wav
EVENT: Power-Pressed#1 ON millis=26036
EVENT: Power-Pressed ON millis=26036
EVENT: Power-Released#1 ON millis=26227
EVENT: Power-Released ON millis=26227
EVENT: Power-Shortclick#1 ON millis=26227
unit = 1 vol = 0.50, Playing TFULIGHT/in/in02.wav
EVENT: Stab millis=26324
No sounds found: pstoff
Unmounting SD Card.
Amplifier off.
EVENT: Power-Pressed#1 millis=27911
EVENT: Power-Pressed millis=27911
EVENT: Aux-Pressed#1 mods Power millis=27939
EVENT: Aux-Pressed mods Power millis=27939
EVENT: Power-Held#1 mods PowerAux millis=28212
EVENT: Power-Held mods PowerAux millis=28212
EVENT: Aux-Held#1 mods PowerAux millis=28240
EVENT: Aux-Held mods PowerAux millis=28240
EVENT: Power-HeldMedium#1 mods PowerAux millis=28712
EVENT: Power-HeldMedium mods PowerAux millis=28712
EVENT: Aux-HeldMedium#1 mods PowerAux millis=28740
EVENT: Aux-HeldMedium mods PowerAux millis=28740
EVENT: Power-HeldLong#1 mods PowerAux millis=29912
EVENT: Power-HeldLong mods PowerAux millis=29912
EVENT: Aux-HeldLong#1 mods PowerAux millis=29940
EVENT: Aux-HeldLong mods PowerAux millis=29940
Enter Edit Mode
Saving Current Preset
Saving Gesture State
Ignition.
unit = 1 vol = 0.50, Playing TFULIGHT/out/out01.wav
humstart: 1800
unit = 3 vol = 0.00, Playing TFULIGHT/swingl/swingl01.wav
unit = 2 vol = 0.00, Playing TFULIGHT/swingh/swingh01.wav
Playing medit.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 11
EVENT: Aux-Released#1 ON millis=30436
EVENT: Aux-Released ON millis=30436
EVENT: Power-Released#1 ON millis=30465
EVENT: Power-Released ON millis=30466
EVENT: ?47 ON millis=33251
EVENT MENU TURN RIGHT
Playing mstyle.wav, channels: 1 rate: 44100 bits: 16
EVENT: ?47 ON millis=34638
Playing mcolor.wav, channels: 1 rate: 44100 bits: 16
EVENT: Power-Pressed#1 ON millis=35980
EVENT: Power-Pressed ON millis=35980
EVENT: Power-Released#1 ON millis=36218
EVENT: Power-Released ON millis=36218
EVENT: Power-Shortclick#1 ON millis=36218
Style RAM = 3572
Playing mcolorsb.wav, channels: 1 rate: 44100 bits: 16
EVENT: ?47 ON millis=38059
Playing mcolorop.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 26
EVENT: Stab ON millis=38741
Battery voltage: 3.84
EVENT: Power-Pressed#1 ON millis=40171
EVENT: Power-Pressed ON millis=40171
EVENT: Power-Released#1 ON millis=40395
EVENT: Power-Released ON millis=40395
EVENT: Power-Shortclick#1 ON millis=40395
Playing meffect.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 4
EVENT: ?48 ON millis=42577
Style RAM = 3572
Style RAM = 3572
Style RAM = 3572
EVENT MENU TURN LEFT
Playing mswing.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 19
EVENT: Stab ON millis=43482
EVENT: ?48 ON millis=43816
Style RAM = 3572
Style RAM = 3572
Playing mretract.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 8
EVENT: Stab ON millis=44423
EVENT: ?48 ON millis=45346
Style RAM = 3572
Playing mignite.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 5
EVENT: Stab ON millis=46184
EVENT: ?48 ON millis=46865
Style RAM = 3572
Playing mpreon.wav, channels: 1 rate: 44100 bits: 16
EVENT: ?48 ON millis=48173
Style RAM = 3572
Style RAM = 3572
Playing mlb.wav, channels: 1 rate: 44100 bits: 16
EVENT: ?48 ON millis=49818
Style RAM = 3572
Playing mdrag.wav, channels: 1 rate: 44100 bits: 16
EVENT: ?48 ON millis=51252
Style RAM = 3572
Playing mlockup.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 23
EVENT: Stab ON millis=52212
EVENT: ?48 ON millis=52738
Style RAM = 3572
Playing mclash.wav, channels: 1 rate: 44100 bits: 16
EVENT: Stab ON millis=53147
EVENT: ?48 ON millis=54252
Style RAM = 3572
Playing mblast.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 13
EVENT: ?48 ON millis=56135
Style RAM = 3572
Style RAM = 3572
Playing mbase.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 36
EVENT: Clash ON millis=57084
EVENT: Power-Pressed#1 ON millis=57352
EVENT: Power-Pressed ON millis=57352
EVENT: Power-Held#1 ON millis=57657
EVENT: Power-Held ON millis=57657
EVENT: Power-Released#1 ON millis=57686
EVENT: Power-Released ON millis=57686
EVENT: Power-Shortclick#1 ON millis=57686
Playing moption.wav, channels: 1 rate: 44100 bits: 16
EVENT: Clash ON millis=58217
EVENT: ?47 ON millis=59983
Playing mcolorlt.wav, channels: 1 rate: 44100 bits: 16
Battery voltage: 3.82
EVENT: ?47 ON millis=60965
EVENT: Power-Pressed#1 ON millis=62033
EVENT: Power-Pressed ON millis=62033
EVENT: Power-Released#1 ON millis=62271
EVENT: Power-Released ON millis=62271
EVENT: Power-Shortclick#1 ON millis=62271
Style RAM = 3572
Style RAM = 3572
Playing mselect.wav, channels: 1 rate: 44100 bits: 16
EVENT: ?47 ON millis=64227
unit = 4 vol = 0.50, Playing common/clrlst/clrlst01.wav
Audio underflows: 30
EVENT: ?47 ON millis=64459
EVENT: ?47 ON millis=65869
unit = 4 vol = 0.50, Playing common/clrlst/clrlst02.wav
Audio underflows: 25
EVENT: ?47 ON millis=67096
unit = 4 vol = 0.50, Playing common/clrlst/clrlst03.wav
EVENT: Stab ON millis=68041
EVENT: ?47 ON millis=68615
unit = 4 vol = 0.50, Playing common/clrlst/clrlst04.wav
EVENT: Stab ON millis=69143
EVENT: ?47 ON millis=69926
unit = 4 vol = 0.50, Playing common/clrlst/clrlst05.wav
Audio underflows: 29
EVENT: ?47 ON millis=71200
unit = 4 vol = 0.50, Playing common/clrlst/clrlst06.wav
Audio underflows: 27
EVENT: ?47 ON millis=72344
unit = 4 vol = 0.50, Playing common/clrlst/clrlst07.wav
EVENT: ?47 ON millis=73607
unit = 4 vol = 0.50, Playing common/clrlst/clrlst08.wav
Audio underflows: 33
EVENT: Stab ON millis=74091
EVENT: Power-Pressed#1 ON millis=74449
EVENT: Power-Pressed ON millis=74449
Playing mzoom.wav, channels: 1 rate: 44100 bits: 16
EVENT: Power-Released#1 ON millis=74645
EVENT: Power-Released ON millis=74646
NewColor(1,1)
Style RAM = 3572
Style RAM = 3572
Style RAM = 3572
Failed to open: presets.ini
Failed to open: presets.tmp
Style RAM = 3572
Audio underflows: 210
Playing msave.wav, channels: 1 rate: 44100 bits: 16
EVENT: Stab ON millis=77292
EVENT: Aux-Pressed#1 ON millis=79102
EVENT: Aux-Pressed ON millis=79102
EVENT: Aux-Released#1 ON millis=79274
EVENT: Aux-Released ON millis=79274
EVENT: Aux-Shortclick#1 ON millis=79274
EVENT: Aux-Shortclick ON millis=79274
Playing mcancel.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 15
Battery voltage: 3.79
Audio underflows: 9
EVENT: Aux-Pressed#1 ON millis=80103
EVENT: Aux-Pressed ON millis=80103
EVENT: Aux-Released#1 ON millis=80295
EVENT: Aux-Released ON millis=80296
EVENT: Aux-Shortclick#1 ON millis=80296
EVENT: Aux-Shortclick ON millis=80297
Audio underflows: 16
EVENT: Aux-Pressed#1 ON millis=81369
EVENT: Aux-Pressed ON millis=81369
EVENT: Aux-Released#1 ON millis=81561
EVENT: Aux-Released ON millis=81562
EVENT: Aux-Shortclick#1 ON millis=81562
EVENT: Aux-Shortclick ON millis=81563
EVENT: Aux-Pressed#1 ON millis=82568
EVENT: Aux-Pressed ON millis=82568
EVENT: Aux-Released#1 ON millis=82761
EVENT: Aux-Released ON millis=82761
EVENT: Aux-Shortclick#1 ON millis=82761
EVENT: Aux-Shortclick ON millis=82761
Audio underflows: 17
EVENT: Stab ON millis=82933
unit = 4 vol = 0.50, Playing TFULIGHT/stab/stab07.wav
Playing mmain.wav, channels: 1 rate: 44100 bits: 16
Playing mexit.wav, channels: 1 rate: 44100 bits: 16
Audio underflows: 55
Here’s another quick recording with it just in standard function not EditMode with me using aux to trigger blast and it suddenly going into stab/melt. Yes I clicked a ton of times trying to get it to back out (disable) of blast and got what else happened with other stuff.
EVENT: Power-Pressed#1 millis=18974
EVENT: Power-Pressed millis=18974
EVENT: Power-Released#1 millis=19154
EVENT: Power-Released millis=19154
EVENT: Power-Shortclick#1 millis=19154
EVENT: Power-Shortclick millis=19154
Ignition.
humstart: 1800
unit = 2 vol = 0.00, Playing TFULIGHT/swingl/swingl03.wav
unit = 3 vol = 0.00, Playing TFULIGHT/swingh/swingh03.wav
Battery voltage: 3.68
EVENT: Aux-Pressed#1 ON millis=21349
EVENT: Aux-Pressed ON millis=21349
EVENT: Aux-Released#1 ON millis=21509
EVENT: Aux-Released ON millis=21509
EVENT: Aux-Shortclick#1 ON millis=21509
EVENT: Aux-Shortclick ON millis=21509
unit = 1 vol = 0.50, Playing TFULIGHT/blst/blst02.wav
EVENT: Stab ON millis=21611
unit = 4 vol = 0.50, Playing TFULIGHT/bgnmelt/bgnmelt.wav
Playing TFULIGHT/melt/melt.wav
EVENT: Power-Pressed#1 ON millis=25068
EVENT: Power-Pressed ON millis=25068
EVENT: Power-Released#1 ON millis=25243
EVENT: Power-Released ON millis=25243
unit = 1 vol = 0.50, Playing TFULIGHT/endmelt/endmelt.wav
EVENT: Stab ON millis=25390
EVENT: Power-Pressed#1 ON millis=28257
EVENT: Power-Pressed ON millis=28258
EVENT: Power-Released#1 ON millis=28437
EVENT: Power-Released ON millis=28437
EVENT: Aux-Pressed#1 ON millis=30127
EVENT: Aux-Pressed ON millis=30128
EVENT: Aux-Released#1 ON millis=30248
EVENT: Aux-Released ON millis=30248
EVENT: Aux-Shortclick#1 ON millis=30248
EVENT: Aux-Shortclick ON millis=30248
unit = 1 vol = 0.50, Playing TFULIGHT/blst/blst04.wav
EVENT: Stab ON millis=30438
EVENT: Power-Pressed#1 ON millis=33599
EVENT: Power-Pressed ON millis=33599
EVENT: Power-Released#1 ON millis=33797
EVENT: Power-Released ON millis=33797
EVENT: Stab ON millis=33881
EVENT: Power-Pressed#1 ON millis=35387
EVENT: Power-Pressed ON millis=35387
EVENT: Power-Released#1 ON millis=35520
EVENT: Power-Released ON millis=35520
EVENT: Stab ON millis=35744
EVENT: Power-Pressed#1 ON millis=36848
EVENT: Power-Pressed ON millis=36848
EVENT: Power-Released#1 ON millis=37025
EVENT: Power-Released ON millis=37028
unit = 5 vol = 0.50, Playing TFULIGHT/endmelt/endmelt.wav
EVENT: Stab ON millis=37274
unit = 1 vol = 0.50, Playing TFULIGHT/bgnmelt/bgnmelt.wav
EVENT: Aux-Pressed#1 ON millis=38165
EVENT: Aux-Pressed ON millis=38165
EVENT: Aux-Released#1 ON millis=38290
EVENT: Aux-Released ON millis=38290
unit = 4 vol = 0.50, Playing TFULIGHT/endmelt/endmelt.wav
EVENT: Stab ON millis=38376
EVENT: Aux-Pressed#1 ON millis=38846
EVENT: Aux-Pressed ON millis=38847
EVENT: Aux-Released#1 ON millis=38944
EVENT: Aux-Released ON millis=38944
EVENT: Stab ON millis=39021
EVENT: Aux-Pressed#1 ON millis=39085
EVENT: Aux-Pressed ON millis=39085
EVENT: Aux-Released#1 ON millis=39251
EVENT: Aux-Released ON millis=39251
unit = 6 vol = 0.50, Playing TFULIGHT/endmelt/endmelt.wav
Battery voltage: 3.65
EVENT: Power-Pressed#1 ON millis=43125
EVENT: Power-Pressed ON millis=43125
EVENT: Power-Released#1 ON millis=43368
EVENT: Power-Released ON millis=43368
EVENT: Power-Shortclick#1 ON millis=43368
EVENT: Stab millis=43545
Unmounting SD Card.
Amplifier off.
Battery voltage: 3.80
Battery voltage: 3.81
Very odd, it’s ignoring the Stab and Clash events throughout Edit Mode like it should except at very end which makes no sense. The sound is definitely inducing Stab and Clash events but they get ignored in all instances but one but no idea why the one instance is different.
Glad I asked then because yeah, you see it too now. Thanks
I have stuff the rest of the next two days w family but I’ll try to stay in the chat on this.
@profezzorn any ideas on this? If we “return true” while menu is active I don’t see how this is possible?
There is no instance in the menu where menu_ is not true so this line should prevent in all cases, correct or is there something in the clash/stab event outside the prop that can still happen even when the prop returns true?
and
Hello again!
So I think this is my final report on the false clash issues I was having. After extensive trail and error I’ve resolved my issue. I used to have clash threshold around 4-4.5 and I’ve now set it to 9-10 now, BUT I must say I am surprised I am still able to trigger clashes quite normally. So I guess I didn’t lose anything there. Same goes for stab/melt.
Next, I’m used to running my volume at 2250 (75%) because I always wanted my saber as loud as possible without risking blowing my speaker and common knowledge is to not max them out to increase speaker lifespan. Anyway I’m down to 1500 now (50%) and honestly I must say it still sounds pretty loud so maybe not much loss there either. (Was there any changes in the OS to audio processing,etc? Just curious)
I think the false clashes really came from a combination of low clash threshold, high volume and possible my chassis/speaker set-up itself. It’s a PETG chassis, but it’s a bit thinner then most because I have a 21700 5000mah battery so not much there compared to a thicker chassis that would to absorb some of the vibration from the speaker. I use the smugglers outpost 28mm silver elite 2w/4ohm and that thing really moves. If you have one you know what I’m talking about. It creates a lot of vibration. So having a thin chassis that’s not absorbing vibration was likely a big slice of the pie.
SO if you update to OS6 don’t be afraid to raise your threshold at bit and drop down your volume if you are having false clashes. That should be good!
(Also note this is all running Kylo fonts from KSith, kyberphonic, Fett263 prop file but no edit or other fancy modes. Someone mentioned trying the bypass filter and I did at 200 and 150 but those didn’t help my issue as much as just adjusting clash threshold and volume settings. I actually took them back off and it’s fine without the filters. All in all Swing acceleration, real clash, dual mode sound all work great! Cool features and that’s for those Fernando.)
*Possibly Off-Topic: Interesting question that I can visualize maybe yaw coming into play like I’ve seen with vehicle sensors? I could be off here since it’s a sound board but think of it as if there’s a slight twist horizontally on the level while twisting or pressing the button or the center of gravity is interrupted and the chip is picking things up as a different type of signal or signal combination and interpreting it without a stop or ignore clause? It’s an auto racing tech call I remember solving that the reference is from but LMK if this applies here.
Shouldn’t matter, unless there’s a separate function outside my prop causing.
@Powellspowerups Stephen thanks. That gives us someone else playing with and tuning the settings. As soon as I get back I’m going to see what lowering volume from 1700 in increments of 250 and then slowly dropping the clash by .1 increments does. Ideally I’ll be able to get to the point of triggering this and then making it go away again. I know it’s a possible separate thing now but if anything else it’s good reference material that installers etc can use.
Is it possible that we have already exited menu mode at this point, but mmain.wav and mexit.wav are queued up behind mcancel.wav, so they haven’t played yet?
Hmm, good point. Thanks.
@A_Rogue_Child is this occurring when you’re exiting? That would make sense once you exit the menu is no longer active but the prompts will finish playing.
So I also have had to increase my clash threshold when moving from OS5.9 to OS6.3 on the two sabers I have converted so far.
For saber one, it is the same saber, font(s) config, volume, etc. No edit mode, but I am using battle mode always on.
Saber one : OS5.9 clash threshold = 4.0, OS6.3 = 7.0, but I think I may need to increase it a little more.
For saber two, other than the OS the only differences are that I am using Fett263’s test styles for OS6 and I have implemented edit mode. Same fonts, volume setting, etc.
For saber two: OS5.9 threshold = 3.0, OS6.3 clash threshold = 4.0
Much smaller increase needed in saber two, I am not sure how or why that is - or if it is helpful. The only other difference is that I am using SAC22 prop for 5.9 and Fett263 prop for 6.3 for both sabers.
Also, as far as the actual hilts go, I run the volume pretty hot in both, but saber one has an exceptional resonance chamber where saber two has an average/typical resonance chamber.
@profezzorn @Fett263 No. I was still in the menu when this occurred and had NOT exited it yet. That IG video clip shows similar.
@KlubiGan Thanks for the feedback, good reference material.
That doesn’t seem to be the case in the serial monitor output you provided though. At the end, there are four AUX clicks, roughly one second apart, then the stab sound occurs while it’s still working on playing the exit sounds.
So in that particular case, that seems to be what is actually happening.
If it happens while the menu is still active, and NOT exiting, then we need to see the serial monitor output from that in order to figure out what is going on.
I spent 3 hours messing with stuff getting it to repeat and another batch of time recording it. Watch the video, try it out yourself, maybe even drop the clash threshold down to 3.1 which is where I first started seeing the issue and see what results you get. The video shows it all from prior.
I will, but if I can’t reproduce it I can’t fix it.
I thought you had some way of reproducing it.
Which is listed above as far as what I have for config, what settings I was at and changed to as well as the font, etc used. If you need deeper both hilts are KR Flagships with Jeremy’s chassis upgrade done to both. I can try to get more later.
Sent a a dm.
