Stab the tip into something, technically it’s a linear thrust that ends in a clash at the tip. For ignitions a forward or backward thrust with a hard stop can trigger but it takes practice, Thrust On is easier to perform.
I have a diagram of gestures at the bottom of this page
Hello again. I read your response and decided to continue messing around with it a big more. Im up to clash threshold of 7.0 and volume down to 2000. Also if it counts for anything I am using the new swing acceleration feature. Anyway I still get clashes but Ive narrowed it down to the source. When the swing accelerator features triggers a swing sound, that swing sound for whatever reason is enough to creative just enough vibration from the speaker to trigger a clash. Whats strange about it is thats the only time its happening. I can trigger quotes and blasters and such and no clashes. it only happens as accent swing sounds are triggered. Also if it helps like Fernando mentioned im using kylo sound fonts which are a bit on the loud end. Anyway what stinks about this was that on OS5.9 I didnt have these issues, and not I have false clashes and a quiet saber
Ill try testing other, more normal fonts to see what happens.
FWIW, since OS6 (also using the acceleration based swng), I’ve noticed some random popping sounds from my speaker during the accent swng.wav’s. It’s been pretty inconsistent and I didn’t think that much of it. I know my speaker isn’t the highest quality, but I do keep my volume level quite low (1000 max, and only 3-4 ticks from the minimum setting). Also, I added in the new High Pass filter and I haven’t had any popping since then. I’d reset my volume level and try out 200 Hz first.
These are the defines:
#define FILTER_CUTOFF_FREQUENCY 200
#define FILTER_ORDER 8
(I’d start with 200 for the first define then go down to 150 etc as needed. 8 is the default for the 2nd one and works well for me)
The more I look at the new syntax the more fun it gets.
*Disclaimer, YES, of course the first one I’d choose to play with would be Fallen Order.
//Fett263's OS6 FallenOrder Demo Code
{"Fallen;common","tracks/none.wav",
StylePtr<
//Main blade
Layers<
StripesX<Int<6000>,Scale<SlowNoise<Int<2000>>,Int<-1600>,Int<-3200>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,BrownNoiseFlicker<Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,300>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Black,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,
//Force Effect
ColorSelect<IntArg<SWING_OPTION_ARG, 0>,TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Int<0>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,SwingSpeed<600>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TrDelay<30000>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,SwingSpeed<600>>,TrDelay<30000>>,EFFECT_FORCE>>,
//Ignition Effect
TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFadeX<IgnitionTime<300>>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<IgnitionTime<300>>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrFadeX<IgnitionTime<300>>>>,EFFECT_IGNITION>,
//Other Effect(s) - Retraction
TransitionEffectL<TrSelect<IntArg<RETRACTION_COOL_DOWN_ARG,0>,TrInstant,TrConcat<TrInstant,HumpFlickerL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,40>,TrDelayX<RetractionTime<0>>>,TrConcat<TrInstant,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrDelayX<RetractionTime<0>>>>,EFFECT_RETRACTION>,
//Lockup(s)
LockupTrL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<16000>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump< Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>, Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF< Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>> ,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>, Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,
//Lightening Block
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,
//Blast
EffectSequence<EFFECT_BLAST,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,BlastF<200,200>>,TrFade<300>>,EFFECT_BLAST>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
//Clash
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,ResponsiveBlastWaveL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>,EFFECT_CLASH>>,
//Drag
LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31000>,Int<2000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
//Melt
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<6000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<Int<29000>,Int<8000>>>,TrExtend<2000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<29000>,Int<8000>>>,TrFade<3000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
//In-Out
InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<300>>,TrWipeInX<IgnitionTime<300>>,TrColorCycleX<IgnitionTime<300>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrCenterWipeX<IgnitionTime<300>,Int<16384>>,TrCenterWipeInX<IgnitionTime<300>,Int<16384>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrWipeX<RetractionTime<0>>,TrColorCycleX<RetractionTime<0>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,TrCenterWipeX<RetractionTime<0>,Int<16384>>>,RotateColorsX<Variation,Black>>,
//PreOn
TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrInstant,AlphaL<RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Black>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,5>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<100>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,3>,Black,TrBoingX<Mult<Int<7260>,WavLen<EFFECT_PREON>>,3>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<200>>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<3664>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>>,EFFECT_PREON>,
//Battery Meter and Closing Argument
TransitionEffectL<TrConcat<TrExtend<3000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), , "OS6Fallen"},
Quick question for the sequential force/quote situation. Mine don’t play sequentially, would the quotes need to be named under something else now? I’ve mine in the Force folder, which I believe is normal.
force.wav’s don’t play sequentially. quote.wav’s do. If you want them in a folder use new folder called quote.
Example:
force
force01.wav
force02.wav
quote
quote01.wav
quote02.wav
Try lowering it to 9.25 on threshold maybe that will solve that. I have my speaker at 1800 and works beautifully.
Ah so it requires a whole new folder now, that’s what I thought, thanks for the reply, that clears it up for me a lot.
It doesn’t require a folder, you just need quote1.wav, quote2.wav, quote3.wav in the font, they will play sequentially through Quote Player. If you do want to use a folder make sure the folder is named “quote” and is in the root of the font or just put the quote wavs in the root of the font, either works.
As noted, quote.wav plays sequentially (if more than one file exists), force.wav plays randomly.
This is not isolated to just the Kylo fontset. I get it happening on my Battle, Son of Corellia, and Survivor fonts when in Battle Mode. It’s repeatable using EditMode and things go into Lockup with the board just sitting idle in an edit option and no movement of the saber initiated.
It’s almost like there’s an oversampling going on due to the increased reads the board does.
For clarity since I’m gonna mess with base settings you mean RAISE threshold not lower it correct since most who read this will have the older lower threshold settings from 5.9 or older, correct?
Thanks for the reply and thanks for letting me know, I’ll take that into note. Currently loving OS6 so I appreciate all of your guys’ work.
*Thought, is the accidental (inadvertent) triggering prop specific and if (or?) not could simply reducing the sampling rate of the board resolve this? As-in since going to a higher sample rate to coordinate with the new swing options and needing the sensitivity to do so be reduced to a point where that’s still effective and the issue is solved?
Increased motion sampling rate makes a lot of things better, so I’m not going to change that unless I have to. If push comes to shove, I will have the clash detection look at two values instead of one before declaring it a clash. I need to understand the spurious clashes better first though. I’m planning to put my speaker on top of my board this weekend and see if I can trigger something…
This shouldn’t be possible, Edit Mode disables all effects, are you certain this actually occurred in Edit Mode because I can’t see any way for that to occur in my prop?
@Fett263
Yes I am sure, here’s a recording of it being repeated. I don’t even know what that accept sound is it makes when I try to save in Color List but it does it afterwards each time. I have to finally lift the saber up enough for the motion to disable the lockup and get out of Edit Mode as the video shows. See next reply for the config. Nothing usable in SerialMonitor on my side.
Here’s the config if you need it. I’m waiting to see what plays out as far as what people are changing their clash thresholds to before I do anything else. This way it’s one issue one solution this time around. No customized files, nothing not to “standard” with all this. The font pack is The Survivor | Kyberphonic
@profezzorn Let me know what you figure out. I know I can also trigger the clash error in the blade itself using a 5.9 bladestyle versus one of the test 6.4’s and Secret Apprentice | Kyberphonic where one of the out.wav files triggers things consistently. Note: As with the config bladestyle count I have gone to using bare minimum SD content as well for these tests. Just the common folder, font folder, and tracks folders. The SD has been cleared, reformatted with SD Card Formatter, and a clean reload done to eliminate any issues on this side.
#define VOLUME 1700
#define CLASH_THRESHOLD_G 4.0
//Went from initial threshold of 3.1 to 4.0 and still happens. Gonna keep increasing to see.
#define ENABLE_SERIAL
#define FETT263_MULTI_PHASE
#define FETT263_SWING_ON
#define SHARED_POWER_PINS
#define SAVE_STATE
//CalKestis__Jedi:FallenOrder_MultiColor_BrighterVersion
{"Fallen;common","tracks/sugaanessena.wav",
StylePtr<
Layers<
TransitionEffectL<TrConcat<TrExtend<3000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>>>(), "OS6Fallen"},
{ 0,
WS281XBladePtr<122, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
CONFIGARRAY(presets) },
I don’t have Instagram so I can’t see video. Post Serial Monitor output even if you don’t see anything specific. And make sure you’re actually using the current OS with no mods whatsoever.
You don’t need an IG login to see a public post.
Just click the link on a computer browser and hit refresh and it’ll work. Currently pushed volume down from 2200 to what you see above and clash is at 6.0 and I’m trying out a small piece of NVH foam to see if it dampens things. It’s not a loose board or anything else so I am gonna play with both sabers some more first and will let you know. As I said above, NO MODS, straight stock.
Side note, AWESOME JOB on all the demo 6.4 bladestyles!!!
Ok, that’s odd it shouldn’t be possible, let’s see Serial Monitor output to see what is actually being detected.
SOLVED. Using a small piece of NVH confirmed my thoughts. Then pushing clash to 6.0 and the volume down to 1700 did the trick. Removed the NVH foam and things stayed good.
An idea, when EditMode is engaged can we have the hum volume automatically drop by 30% if not in an edit setting that requires font folder sound feedback if for nothing more than to try and see if that helps?
