Ok, it’s officially late-o-clock, but I have got syntax highlighting and “copy to clipboard” buttons working now, and I have updated the “proffieboard setup” page with images and to use proffie-dfu-setup.exe instead of zadig.
Next step will be how write a page that lets you use the configurator to set up a simple config file and flash it to your board. (with screenshots)
Google’s security sweep software apparently takes issue with proffieos-dfu-setup.exe for some reason. (It won’t tell me why it doesn’t like it, it just says it’s unwanted software and tells me to delete it.) Apparently google now holds the keys to the web.
The whole experience is very “nice website you have there, pity if something were to happen to it…”.
The good news is that as a Google engineer, I have the ability to use internal bug reporting tools to try to resolve the problem. I’ll report what happens here.
I just got a Community Guidelines Strike Warning on youtube because I had a link to the POD in the video description.
Community Guidelines strikes
Warning
Your content was removed due to a violation of our Community Guidelines.
Because it's the first time, your account isn't affected. You're only warned once and this warning will remain on your channel.
If this happens again
Your channel will get a Community Guidelines strike.
You won't be able to do things like upload, post, or live stream for 1 week.
Content removed
If you think we made a mistake, you can appeal this decision
Warning on February 2, 2023
Type
Content
Policy
Actions
ProffieOS config errors: FIXING
https://pod.hubbe.net/troubleshooting/arduino-error-messages.html
Harmful or dangerous content
There’s an option to APPEAL… but what would I even say?
“You dumdums, it’s fine!”
Verify domain ownership via DNS record
-pod.hubbe.net
1
Select record type:
Learn more
2
Sign in to your domain name provider (e.g. godaddy.com or namecheap.com)
3
Copy the TXT record below into the DNS configuration for pod.hubbe.net google-site-verification=A8w5FMM4nkN_2iQiGu6LErJxFhVhhfDdkrkTa385ALo
4
Press verify below
Note: DNS changes may take some time to apply. If Search Console doesn’t find the record immediately, wait a day and then try to verify againLearn more
