I just tested creating edits for non-collaborators.
It’s actually really easy. You would need a github account of course.
First time you try to edit something, it says it will create a fork for you.
Once the edit is done, it saves it in a branch on your fork, and then it asks if you want to create a pull request. Once the pull request is done, I get an email, approve or disapprove the change, and that’s it.
All of this happens on the github site, so it’s just a few extra clicks compared to being a collaborator.
Things are coming along.
Most of the pages are now organize in directories, which should make it easier to find stuff.
It also makes the all pages page fairly well organize.
I’ve also added an everything on one page, page, but it might need some more work to be useful. If nothing else, it makes it possible to find stuff without knowing what page it’s on. It could also be printed to a PDF and saved, or even printed out, if someone feels like there are too many trees on the planet…
At some point I should probably spend more time writing documentation and less time making it nifty though.
Could we have a page explaining how to use FromFileStyle ?
and videotoblc.
I did it once, and while it was quite the process, I feel there’s a lot of possible untapped power there for blade effects.
So far only one drawback of the new format. We used to be able to get a link directly to the sub-section of a page to point someone to the correct thing to read, such as jumping right to #style-definition:
The anchors are still there, but there isn’t an easy way to “get” the links right now.
I did experiment with this thing called jekyll-linkify, which puts a “#” mark next to every heading, but I thought it looked kind of ugly. Also, it’s written entirely in jekyll, and while I’m not sure I think it might break some things.
In the original wiki, the link thingy only shows up when you hover over the header, which is a neat trick. We should probably try to do something like that. Either with jekyll-linkify, or maybe we can do it with pure CSS.
One option for the technically savvy user is to use right click → inspect, which will the element and it’s ID (which can be used as an anchor).
