ProffieOS 8.7 beta (call for testers!)
ProffieOS 8.x is moving from alpha do beta. That means that everything has at least some documentation, and there will be zip files available. For now I’m going to only make the zip files available in this thread. You can also get the latest from github, which should be more or less identical to the latest release during the beta testing stage.
ProffieOS-v8.7.zip (840.2 KB)
The list of features should be mostly complete now, but I may still sneak in a few things. Once we go from beta to live, there will be no new features, only bugfixes.
The release Process
All the features listed below needs to be tested before we can move from beta to live. The more people help, the faster it will go.
How to test
Pick a feature below that you want to test, and that hasn’t been tested already. (It will say “Tested by NAME” next to it once it’s tested.) Try it out and see if it seems to work as expected. Report your findings in this thread, and if the test was successful, I will edit this post and add “Tested by NAME” next to the feature. Hopefully the feature you selected is either easy to figured out, or one that I’ve gotten around to document (There will be a book icon next to the feature if it is documented. Click on it to go to the documentation.), if not just post a question in this thread and I’ll make sure to point you to some information about how to use it.
Changes since V7.x
Menu System :closed_book:
This isn’t so much a menu, as it is a system for implementing menus. It also separates the menu setup from the prop file, so we can have multiple different menu configurations, and then prop A and menu B independently. Currently supported by the “saber” and the “BC” props. For most users, all they will need to know is how to use the MENU_SPEC_TEMPLATE define.
Sound Library V2
Adds a bunch more sounds to the spoken sound library to support the new menus. Also adds support for a configurable color list.
Color Display support :closed_book: (Tested by orntar)
Support 16-bit color displays. What is shown is composited from layers, and each layer can show independent color animations. Animations use a new file format called PQF which offers some compression (usually around 50%) while being very fast to decompress. PQF also offers loops, labels and conditions which lets you build complex animations which react to events from the saber.
SD card corruption protection :closed_book:
If enabled, SD cards will not be automatically mountable on your computer. Instead, you have to use a menu option on the saber, or a serial monitor command to be able to mount the SD card from the computer. Once done, you can turn off the setting again, thus preventing most forms of SD card corruption.
Dual-Blade support :closed_book:
ProffieOS can now keep track of which blades are on and off individually, which makes it easier for props to support Maul-style ignition.
Other minor new features
  • FastButton :link: (obscure feature, no testing required)
  • LeftRightRotaryReceiver :link: (obscure feature, no testing required)
  • Oled directory prefix support :closed_book: (tested by Triin)
  • Blaster oled controller :closed_book: (tested by orntar)
  • Servo Support :closed_book: (tested by kersskerner)
  • SubBladeWithList :closed_book: (tested by SaberSense)
New defines
  • BLADE_ID_SCAN_TIMEOUT :closed_book: (tested by SaberSense)
  • BLADE_ID_STOP_SCAN_WHILE_IGNITED :closed_book: (tested by Farnsworth9qc)
  • COLOR_MENU_GAMMA :closed_book: (obscure feature, testing not required)
  • CLASH_THRESHOLD_GAMMA :closed_book: (obscure feature, testing not required)
  • VOLUME_MENU_GAMMA :closed_book: (obscure feature, testing not required)
  • DISABLE_AUDIO :closed_book: (tested by Profezzorn)
  • DISABLE_WS2811 :closed_book: (obscure feature, testing not required)
  • DISABLE_MOTION :closed_book: (Tested by Profezzorn)
  • DISABLE_SD :closed_book: (Tested by Profezzorn)
  • DISABLE_NO_REPEAT_RANDOM :closed_book:
  • ENABLE_SPIDISPLAY :closed_book: (Tested by orntar)
  • FONT_PATTERN :closed_book: (tested by everyone, since it’s always in use in v8.x)
  • MENU_SPEC_MENU :closed_book: (tested by Profezzorn)
  • MENU_SPEC_TEMPLATE :closed_book: (tested by LyleStyle)
  • MOUNT_SD_SETTING :closed_book: (tested by NoSloppy, olivierflying747-8)
  • NO_BLADE_ID_RANGE :closed_book: (tested by SaberSense)
  • PROFFIEOS_LOG_LEVEL :closed_book: (tested by olivierflying747-8)
  • SMOOTH_COLORCHANGE_TICKS_PER_REVOLUTION :closed_book: (tested by LyleStyle)
  • ENABLE_IDLE_SOUND :closed_book: (tested by Bruinrogue)
  • BUTTON_LONG_CLICK_TIMEOUT :closed_book: (tested by olivierflying747-8)
New styles
  • DisplayStyle :closed_book: (tested by hkwwinger)
  • Pixelate :closed_book: (tested by Profezzorn)
  • HardStripes :closed_book: (tested by Profezzorn)
  • TransitionLoopWhile :closed_book: (tested by Profezzorn)
New functions
  • ReadPinF :closed_book: (tested by Profezzorn)
  • AnalogReadPinF :closed_book: (tested by Profezzorn)
  • BlasterModeF :closed_book: (tested by Profezzorn)
  • BulletCountF :closed_book: (tested by Profezzorn)
  • BlasterChargeF :closed_book: (tested by Profezzorn)
  • IntSelectX :closed_book: (tested by BlackDragonN001)
New Transitions
  • TrDoEffectAlways :closed_book: (tested by Profezzorn)
New Menus and settings :closed_book:
Top Menu
Edit Settings Menu
  • Volume (tested by LyleStyle)
  • SD Access (tested by LyleStyle)
  • Dimming (tested by LyleStyle)
  • Clash Threshold (tested by LyleStyle)
  • Blade Length (tested by LyleStyle)
Edit Preset Menu
  • select font (tested by LyleStyle)
  • select track (tested by LyleStyle)
  • move preset up/down (tested by LyleStyle)
  • select/insert preset (tested by LyleStyle)
  • delete preset (tested by LyleStyle and olivierflying747-8)
Edit Style Menu
  • Select Style (tested by Profezzorn)
  • Apply Colors
  • Apply Settings
  • Reset
  • Change Style
Style Settings Menu
  • Color settings (tested by olivierflying747-8)
  • Large numerical settings (tested by Profezzorn)
  • Small numerical settings
  • Time settings (tested by Profezzorn)
Color Edit Menu
  • Hue (tested by olivierflying747-8)
  • Brightness (tested by olivierflying747-8)
  • Red/Green/Blue (tested by olivierflying747-8)
  • Named color menu (tested by Profezzorn)
  • Copy/Paste
  • Reset (tested by olivierflying747-8)
  • Save (tested by Profezzorn)
New serial monitor commands
  • sd :closed_book: (tested by NoSloppy)
  • quote :closed_book: (tested by LyleStyle)
  • swing :closed_book: (tested by LyleStyle)
  • slash :closed_book: (tested by LyleStyle)
  • spin (with ENABLE_SPINS) :closed_book: (tested by Profezzorn)
  • get_variation :closed_book: (tested by Profezzorn)
  • | (tag command) :closed_book: (Tested by Profezzorn)
New EFFECT_*
  • EFFECT_MENU_CHANGE :closed_book:
  • EFFECT_ACCENT_SWING :closed_book: (tested by NoSloppy)
  • EFFECT_ACCENT_SLASH :closed_book: (tested by NoSloppy)
  • EFFECT_BLADEIN (tested by NoSloppy)
  • EFFECT_BLADOUT (tested by NoSloppy)
New named colors :closed_book: (tested by LyleStyle & NoSloppy)
  • Amber
  • BlueRibbon
  • BrainFreeze
  • BrutalPink
  • BusyBee
  • CanaryYellow
  • CathodeGreen
  • CyberYellow
  • ElectricBanana
  • ElectricLime
  • ElectricPurple
  • ElectricViolet
  • Flamingo
  • HaltRed
  • HotMagenta
  • ImperialYellow
  • Lemon
  • LimeZest
  • Limoncello
  • MasterSwordBlue
  • MintyParadise
  • MoltenCore
  • NeonRose
  • Orange
  • OrangeJuice
  • OverdueBlue
  • PaleGreen
  • PlungePool
  • PsychedelicPurple
  • RareBlue
  • SafetyOrange
  • SchoolBus
  • Star
  • SuperSaiyan
  • VibrantMint
  • ViolentViolet
  • VividRaspberry
  • VividViolet
  • ZeusBolt
New Sound effects :closed_book:
  • fastout (tested by LyleStyle)
  • quote (tested by LyleStyle)
  • chhum (tested by NoSloppy)
  • mclick (tested by NoSloppy)
  • idle (tested by Bruinrogue)
New oled image support :closed_book:
  • lowbatt
  • bladein
  • bladout
  • blast, reload, empty, jam, clipin, clipout, destruct (for blasters) (tested by orntar)
Prop Changes
(so far, there may be a few more coming before release)
saber_BC_buttons.h
  • Dual blade independent control with a single Proffieboard. (for staff sabers).
    Works with 1,2, or 3 button config. Uses standard (current) bladestyles, no modification needed.
  • Scroll Presets mode.
  • Quotes play with blade ON or OFF, and will not overlap / interrupt one another.
  • Force effects won’t overlap / interrupt one another.
  • Mute sound plays before igniting muted.(optional mute.wav used)
  • Custom Blade Length editing mode.
  • Custom Volume Menu moved to a mode.
  • OS System Menu version available with a #define.
  • 8 USER EFFECTS available (a.k.a. used like Fett263 “Special Ablilities”)
Deprecated features:
  • No Volume UP/DOWN with buttons. Use rotary control instead,
    but QuickMinVolume and QuickMaxVolume are still available.
  • swap and monoforce features of yore are now just assignable User Effects.
  • #define NO_VOLUME_MENU removed.
blaster.h
  • #define BLASTER_ENABLE_AUTO (Tested by orntar)
  • supports DISABLE_TALKIE
saber.h
  • supports new menu system
blaster_BC_buttons.h (new prop)
  • Volume Menu with QuickMAX and QuickMIN.
  • Spoken battery level in both volts or percentage. (tested by olivierflying747-8)
  • On-Demand battery level (Shows Green to Red if EFFECT_BATTERY_LEVEL is used in Blade Style).
  • Quote player with On-the-fly sequential option.
  • Next / previous preset. (tested by olivierflying747-8)
  • Self-Destuct overload.
  • Defaults to KILL on boot. (tested by olivierflying747-8)
  • Option to use separate effect sounds to match the current mode.
    By using alt sound folders in the font, each mode can have better matched effects
    (reload, full, clipin/clipout, etc…).
    Sounds for the modes should go in the following alt folders:
    • STUN mode - alt000
    • KILL mode - alt001
    • AUTO mode - alt002
  • No jam if empty. (tested by olivierflying747-8)
  • AUTOFIRE mode is enabled simply by having auto.wav files available in the sound font.
    This mode also counts bullets and causes an “empty clip” if you use
    #define BLASTER_SHOTS_UNTIL_EMPTY.
    Each shot is timed to the length of the wav file that’s playing, and
    the empty sound repeats at same rate auto was firing for added realism.
sabersense_buttons.h (new prop)
Overview
  • Designed to be simple yet powerful with easy-to-remember controls;
  • Predominantly harmonized 1 and 2 button controls - great for users with large collections;
  • Uses consistent ‘rules’ to help remember multiple features;
  • Complex or difficult gesture controls removed.
Specific Features:
  • Powerful preset navigation allows skip to first, last or middle preset; (tested by olivierflying747-8)
  • Move forwards or backwards one, five or ten presets at a time (2 button only); (tested by olivierflying747-8)
  • Sequential quote player in both blade on and blade off states, randomized force effect player with blade on; (tested by olivierflying747-8)
  • Button ‘clicker’ accessible via #define plays press.wav and release.wav on button presses. Useful for Scavenger hilts where tactile switch feel is difficult. (tested by olivierflying747-8)
  • On-demand BladeID scanning on a button press with a #define;
  • Manual array selector on a #define, allows manual cycling through multiple arrays on a button press. Can be used for multiple blade lengths, separating groups of presets, turning accents or motors on and off etc.; (tested by olivierflying747-8)
  • Full system reset on button press - deletes all saves files and restores ‘factory’ defaults. (tested by olivierflying747-8)
Fett263 prop
  • MENU_SPEC_TEMPLATE support (tested by LyleStyle)
  • Edit Mode supports MOUNT_SD_SETTING (tested by olivierflying747-8)
  • FETT263_MANUAL_BLADE_ID
  • FETT263_MANUAL_BLADE_ARRAY
  • FETT263_REPLACE_CC_COLOR_LIST
  • FETT263_SIMPLIFIED_PROP
  • FETT263_SWING_CLASH_DELAY
  • FETT263_SS_BUTTON_CLICKER (tested by olivierflying747-8)
long post, thank you for reading - Profezzorn
WOW!
Regarding dual blades and the BC prop is see that the blades can be defined:
Dual Blades requires defining BC_DUAL_BLADES and optionally
|        BC_MAIN_BLADE and BC_SECOND_BLADE.
My staff has 2 quad zigzag blades. Can I define a 2 groups of sub blades as BC_MAIN_BLADE and BC_SECOND_BLADE?
The blade array is:
{ 0,
  // first quad-zigzag blade
  SubBlade(0, 34, WS281XBladePtr<140, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
  SubBladeReverse(35, 69, NULL),
  SubBlade(70, 104, NULL),
  SubBladeReverse(105, 139, NULL),
  // second quad-zigzag blade
  SubBlade(0, 34, WS281XBladePtr<140, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >()),
  CONFIGARRAY(presets) },
I don’t think the BC prop supports this, at least not currently.
It is possible to support using blade sets, not sure how much work it would be to do though.
How hard would it be to make something like a “SubBladeGroup” ?
Where for example, the above “// first quad-zigzag blade” Could be seen as a single blade ?
(This is possibly starting to veer off course of this thread topic )
If it was a single blade, then you couldn’t assign individual styles to it.
Correct, a single blade style would feed all the subblades.
But then it’s not a zig-zag blade anymore.
I have considered implementing something like that for efficiency though.
Some styles runs quite slow on a saber with 500+ pixels.
For ignition purposes, using blade sets is almost certainly the right solution though.
Tested MOUNT_SD_SETTING. I use this ALL the time now.
Here’s a writeup if it helps.
This define will allow manual control of when to allow the SD to mount to the computer when Mass Storage is enabled by issuing ‘sd 1’ in Serial Monitor.
First let’s review how Mass Storage works.
Having the Arduino setting Tools>USB Type> Serial + Mass Storage selected allows the SD card to be accessed over USB (using the Proffieboard as a card reader).
The way it used to work before OS8 and this define was after the boot sound played, the SD card would immediately mount to the computer as an external USB drive.
File transfers could take place then, and when finished, you would eject the SD from the computer. From then, the Proffieboard would use it as normal.
This meant that you always had to wait for the SD card to mount, and then eject it before uploading or using Serial Monitor.
It also meant that to re-access the SD, you’d need to either reboot, or unplug and then re-plug the USB cable.
Now here’s how it can work in OS8 using #define MOUNT_SD_SETTING.
Even though Mass Storage was selected and uploaded, this define prevents the SD card from mounting until manually “allowed” by the user.
To allow the SD to mount, send the command sd 1 in Serial Monitor.
When you finish accessing the SD card and “eject” it from the computer, the Proffieboard will use it as normal and set the permission back to FALSE.
If you want to access the SD again, you can just issue the sd 1 command again, and repeat as above.
Hey where is the place to request new features… like other modes for blaster. Such as a charging shot or a recharge /cool down shot. and having an sd config, so the it can know what modes to use.
I’ve enabled a TCSS Proffie Testing station. Is there anything that I can test with that?
To request a new feature, go here: https://crucible.hubbe.net/
Sure.
I’m not sure what a tcss testing station can do specifically, but generally speaking, you should be able to to test almost everything listed in the top post, except maybe menus. Most of the menu stuff requires you to turn the board around to select menu entries, which might be a pain with a testing station.
This is the product: https://www.thecustomsabershop.com/Electronics/Diagnostic-Stations/Proffie-39-Diagnostic-Station
As they use their own breakout board: https://www.thecustomsabershop.com/Electronics/Diagnostic-Stations/Proffie-tester-breakout-PCB
Regrettably they didn’t connect any data pins save for Data1-4. So I’m not sure how could I test the displays without soldering on the board or such. I will see if I can think of something easy to attach to the testing board.
I’m not sure what their tester is for to be honest.
Seems reasonable for testing blades maybe?
Not breaking out half the pins means that anything new, fun or interesting can’t happen on this testing station.
This is my testing station: Proffieboard V1/V2/V3 Test Rig
Might not look as nice, but at least it breaks out all the pins, including the debugger ones, which is perhaps the most important.
It doesn’t have a blade connector, but it does have neopixels right on the board.
The documentation for ProffieOS 8 is coming along nicely. About 85% done.
However, so far testing has been very slow.
If we continue at the current rate, ProffieOS 8 will be released in mid 2029.
Yes, along with a Star Wars theatrical release :slight_smile:
Thank you for the additonal documentation. Looks like there are some things I can look at even if I don’t have a blaster or use screens, particularly with the menu options.
Tested ENABLE_IDLE_SOUND. So far, it’s playing the idle.wav I’ve placed in my test board (only 1 preset) and SD card. Idle.wav just a renamed hum file from another font.
Ok, I think the documentation is more or less finished.
I will write more if people have trouble using any of the features, or if more features are added before it’s locked down… (which happens when we go from beta to live.)
I’m probably going to make some zip files and move this to beta stage tomorrow.
Using the BC prop and tested the following (all successfully):
fastout.wav on swing on plays instead of out.wav
#define SMOOTH_COLORCHANGE_TICKS_PER_REVOLUTION 60 (sounds good)
Used named colors from the editor (BC version): Ivory, Plungepool
More later.
