ProffieOS 7.7 is now the newest stable ProffieOS release.
You can get it from my website: ProffieOS
or from github: Release ProffieOS 7.7 · profezzorn/ProffieOS · GitHub
Here is a (mostly complete) list of new features in ProffieOS 7.x:
Features:
- New code for reading/writing ini files. Should cut down on SD card corruption significantly.
- Better Teensy4 support, including WS281x support.
- Alternate sound files: altNNN/
- Sound file sub-sub directories: hum/001/001.wav
- Updated clash detection
- StylePtr default arguments
- Bendable time in most transitions
- Most “help” command text moved to wiki page to save memory.
- Support for sorted track/font menus.
- OLED error messages
- low-power OLED mode
- Most OLED images can now use the length of the corresponding wav to decide how long to show the image or animation.
- Dynamic mixer bugfix
- New config file section: CONFIG_STYLES
- All config.ini files in the font search path are now read.
- New prop file: saber_caiwyn_buttons.h
- TrConcat can now be used without putting colors between transitions.
- Experimental ESP32-S3 support.
New font config variable:
- ProffieOSHumDelay
- ProffieOSSmoothSwingHumstart
New defines:
- BOOT_VOLUME
- AUDIO_CLASH_SUPPRESSION_LEVEL
- DISABLE_TALKIE
- BLADE_ID_SCAN_MILLIS
- KILL_OLD_PLAYERS
- POV_INCLUDE_FILE
- BLADE_ID_TIMES
New sound effects:
- altchng
New OLED images
- preon
- in
- out
- pstoff
New blade wrapper:
- SubBladeZZ
New EFFECT_* values:
- EFFECT_VOLUME_LEVEL
- EFFECT_ON
- EFFECT_QUOTE
- EFFECT_SECONDARY_IGNITION
- EFFECT_SECONDARY_RETRACTION
- EFFECT_OFF
- EFFECT_FAST_OFF
- EFFECT_OFF_CLASH
- EFFECT_NEXT_QUOTE
- EFFECT_INTERACTIVE_PREON
- EFFECT_INTERACTIVE_BLAST
- EFFECT_TRACK
- EFFECT_BEGIN_BATTLE_MODE
- EFFECT_END_BATTLE_MODE
- EFFECT_BEGIN_AUTO_BLAST
- EFFECT_END_AUTO_BLAST
- EFFECT_ALT_SOUND
- EFFECT_TRANSITION_SOUND
- EFFECT_SOUND_LOOP
- EFFECT_GAME_START
- EFFECT_GAME_ACTION1
- EFFECT_GAME_ACTION2
- EFFECT_GAME_CHOICE
- EFFECT_GAME_RESPONSE1
- EFFECT_GAME_RESPONSE2
- EFFECT_GAME_RESULT1
- EFFECT_GAME_RESULT2
- EFFECT_GAME_WIN
- EFFECT_GAME_LOSE
- EFFECT_USER5
- EFFECT_USER6
- EFFECT_USER7
- EFFECT_USER8
- EFFECT_SD_CARD_NOT_FOUND
- EFFECT_FONT_DIRECTORY_NOT_FOUND
- EFFECT_ERROR_IN_FONT_DIRECTORY
- EFFECT_ERROR_IN_BLADE_ARRAY
New off type:
- OFF_FAST
Styles:
- LockupTrL has a new argument: CONDITION
- StylePOV
- ContinuousPOV
- ChargingStylePtr
- TransitionPulseL
New Functions:
- ClampF / ClampFX
- Divide
- IsBetween
- Subtract
- TwistAcceleration
- AltF
- SyncAltToVarianceF
- LockupPulseF
- ModF
- VolumeLevel
- HumpFlickerFX
New Transitions:
- TrBlink(X)
- TrDoEffect(X)
- TrDoEffectAlways(X)
- TrLoop
- TrLoopN(X)
- TrLoopUntil
Sound library addition:
- moffopt.wav
New style arguments:
- ALT_COLOR2_ARG
- ALT_COLOR3_ARG
- STYLE_OPTION2_ARG
- STYLE_OPTION3_ARG
- IGNITION_OPTION2_ARG
- RETRACTION_OPTION2_ARG
New pairable sound transitions
- lock → endlock
- armhum → endarm
- auto → endauto
- lb → endlb
- melt → endmelt
- drag → enddrag
Fett263 prop changes:
- Removed delay between Clashes (for Clash Spamming)
- Removed delay for gesture ignitions on boot and after retraction
Control Updates / Changes
- Force / Quote* Effect Available While OFF (*depending on defines)
- “Quick Select” for Scroll Presets allows selection and immediate ignition of preset
- Change to “Gesture Sleep” controls (needed to allow for new features refer to control list)
- Circular Volume and Dimming menu (no max/min stop - via define)
- Disable various mode and “on-the-fly” editing controls (via defines)
- Support for new “Special Ability” effects (via define)
- Support for BC control variations (via defines)
- “Spin Mode” (via defines) - disables Clash and Lockup during spinning and flourish maneuvers
- Use both Spoken Battery Percent and Volt based on blade angle (via define)
- Added “Increment By” controls for Ignition/Retraction Time, Delay, Options in Edit Mode
- Added Support for ALT_COLOR2_ARG, ALT_COLOR3_ARG, STYLE_OPTION2_ARG, STYLE_OPTION3_ARG, IGNITION_OPTION2_ARG and RETRACTION_OPTION2_ARG to Edit Mode
New Features
- Edit Setting Menu (via define) - allows a “Settings only” menu system in place of full Edit Mode
- Quick Select on Boot (via define) - saber starts in Select Preset Mode on boot up for faster preset selection
- “Quiet” Track Player (remove spoken prompts via define)
New Defines
- FETT263_DISABLE_CHANGE_FONT
- FETT263_DISABLE_CHANGE_STYLE
- FETT263_DISABLE_COPY_PRESET
- FETT263_DISABLE_MULTI_BLAST
- FETT263_TRACK_PLAYER_NO_PROMPTS
- FETT263_RANDOMIZE_QUOTE_PLAYER
- FETT263_QUICK_SELECT_ON_BOOT
- FETT263_EDIT_SETTINGS_MENU
- FETT263_DISABLE_QUOTE_PLAYER
- FETT263_QUOTE_PLAYER_START_ON
- FETT263_SPECIAL_ABILITIES
- FETT263_SPIN_MODE
BC Variations
- FETT263_USE_BC_MELT_STAB
- FETT263_BC_SAY_BATTERY_VOLTS_PERCENT
New Effect Support
*requires FETT263_SPECIAL_ABILITIES define
- EFFECT_BATTERY_LEVEL
- EFFECT_QUOTE
- EFFECT_NEXT_QUOTE
- EFFECT_TRACK
- EFFECT_ALT_SOUND
- EFFECT_SOUND_LOOP
- EFFECT_ON
- EFFECT_FAST_ON
- EFFECT_OFF
- EFFECT_FAST_OFF
Available Mini Game EFFECTs
- EFFECT_GAME_START
- EFFECT_GAME_WIN
- EFFECT_GAME_LOSE
BC prop
- Spoken Battery level in volts or percentage. Both always available.
- Live toggle between sequential or random quote play added.
- Twist to select presets added.
#define BC_NO_BMto disable battle mode features.- Bypass postoff by Turn off while pointing up.
Volume menu updates
- Removed “cycle through”, added Quick MAX and MIN vol instead.
- Twist to change volume added.
Caiwyn prop
New defines:
- CAIWYN_BUTTON_CLASH
- CAIWYN_BUTTON_LOCKUP
- CAIWYN_SAVE_TRACKS
- CAIWYN_SAVE_TRACK_MODE
- DISABLE_COLOR_CHANGE
