ProffieOS 7.8 Arduino error
I’m getting an error I’ve never seen before when trying to upload my config to my saber. I’ve redone the style (from the library) twice, and redownloaded ProffieOS twice as well, nothing seems to have fixed it.
In file included from C:\Users\zacha\Downloads\ProffieOS-v7.8\ProffieOS\styles\fire.h:4,
                 from C:\Users\zacha\Downloads\ProffieOS-v7.8\ProffieOS\ProffieOS.ino:462:
C:\Users\zacha\Downloads\ProffieOS-v7.8\ProffieOS\styles\style_ptr.h: In instantiation of 'OverDriveColor StyleHelper<RetType>::getColor(int) [with RetType = RGBA]':
C:\Users\zacha\Downloads\ProffieOS-v7.8\ProffieOS\styles\style_ptr.h:35:18:   required from here
C:\Users\zacha\Downloads\ProffieOS-v7.8\ProffieOS\styles\style_ptr.h:35:63: error: could not convert '((StyleHelper<RGBA>*)this)->StyleHelper<RGBA>::getColor2(i)' from 'RGBA' to 'OverDriveColor'
   35 |   OverDriveColor getColor(int i) override { return getColor2(i); }
      |                                                               RGBA
You should post your config file for help.
Looks like a transparent color as the base layer of a style.
How should I go about posting the file?
Select all text in the config file and copy.
Then post here by typing 3 backticks (`) and hit return.
Then paste the text and hit return.
Type 3 more backticks and hit the Reply button.
It will format your text
like this
Alternately you can use Pastebin.com.
  • Go to the site.
  • paste your config in the big empty text box.
  • click “create new paste” button at the bottom of the page.
  • Copy the resulting URL from the address bar and paste that here in a reply.
StylePtr<Layers<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrColorCycleX<Int<1200>>>,HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,60>,HumpFlicker<RgbArg<ALT_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,135,255>>>,60>>,AlphaL<Stripes<2800,-3000,RgbArg<SWING_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<2096>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,255>>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,255>>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<1500>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<2>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,SyncAltToVarianceL,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>,BendTimePowX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowX<RetractionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_POSTOFF>>>()
Cool, but that’s just the blade style.
You should post the entire config file that you’re using and getting an error with when compiling in Arduino.
The top post of this thread does not follow the rules of this forum.
If it’s not updated or deleted, I will delete the whole thread.
Screenshots are not NOT allowed if cut-n-paste will work.
Sorry, but what does cut and paste mean in this situation? Does it mean a link, or something else?
// ProffieOS7 Config File
#define NUM_BUTTONS 1
#define VOLUME 1800
#define CLASH_THRESHOLD_G 3
#define FETT263_USE_BC_MELT_STAB
#define FETT263_BM_DISABLE_OFF_BUTTON
#define FETT263_TWIST_ON
#define FETT263_FORCE_PUSH
{ "KyberDark;common",  "",
StylePtr<Layers<StripesX<Int<3500>,Int<1600>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<10,0,26>>,RotateColorsX<Variation,Rgb<42,0,105>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<7,0,16>>,RotateColorsX<Variation,Rgb<30,0,66>>>>,AlphaL<Stripes<10000,-2000,HumpFlicker<Rgb<0,0,40>,Rgb<20,30,0>,50>,HumpFlicker<Blue,NavajoWhite,50>,HumpFlicker<Rgb<0,0,80>,Rgb<40,60,0>,50>>,SwingSpeed<600>>,ColorSelect<WavNum<EFFECT_FORCE>,TrInstant,TransitionEffectL<TrConcat<TrSmoothFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>,StaticFire<Red,Strobe<Black,Orange,30,30>,0,3,300>,TrDelayX<Percentage<WavLen<EFFECT_FORCE>,60>>,StaticFire<Red,Strobe<Black,Orange,30,30>,0,3,300>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrSmoothFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>,StaticFire<Blue,Strobe<Black,Cyan,30,30>,0,3,300>,TrDelayX<Percentage<WavLen<EFFECT_FORCE>,60>>,StaticFire<Blue,Strobe<Black,Cyan,30,30>,0,3,300>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrSmoothFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>,StaticFire<Green,Strobe<Black,GreenYellow,30,30>,0,3,300>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,60>>,StaticFire<Green,Strobe<Black,GreenYellow,30,30>,0,3,300>,TrFadeX<Percentage<WavLen<EFFECT_FORCE>,20>>>,EFFECT_FORCE>>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Moccasin,TrInstant,TrFadeX<Percentage<WavLen<>,35>>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Scale<ClashImpactF<>,Int<1>,Int<32768>>>>,TrFadeX<Percentage<WavLen<>,50>>>,EFFECT_CLASH>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,30>>,AlphaL<Stripes<5000,1000,Orange,DarkOrange,Rgb<150,60,0>,Rgb<60,30,0>,Rgb<150,14,0>,OrangeRed>,SmoothStep<Int<20000>,Int<20000>>>,TrJoin<TrSmoothFadeX<Percentage<WavLen<EFFECT_STAB>,90>>,TrWipeX<Percentage<WavLen<EFFECT_STAB>,70>>>>,EFFECT_STAB>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_BLAST>,BlastL<Rgb<100,200,255>,850,250,351>,AlphaL<TransitionEffectL<TrConcat<TrFade<300>,Rgb<70,70,255>,TrFade<300>>,EFFECT_BLAST>,BlastF<700,250,100000>>,BlastL<Rgb<100,200,255>,300,350,100000>,TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,LockupTrL<Layers<AlphaL<TransitionLoopL<TrConcat<TrDelayX<Scale<SlowNoise<Int<3000>>,Int<30>,Int<800>>>,Mix<SlowNoise<Int<1000>>,Black,Black,White,Black>,TrDelayX<Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>>,Int<32768>>,AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,AlphaL<BrownNoiseFlicker<Yellow,Black,50>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<10000>>>>,TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>,TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_LOCKUP_BEGIN>,LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>,LockupTrL<Layers<AlphaL<Black,Int<16000>>,AlphaL<White,StrobeF<Scale<SlowNoise<Int<1000>>,Int<1>,Int<6>>,Scale<SlowNoise<Int<1000>>,Int<10>,Int<50>>>>,AlphaL<RandomFlicker<Strobe<White,Rgb<83,0,255>,50,10>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<100>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<83,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>> >,SaberBase::LOCKUP_LIGHTNING_BLOCK>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,Rgb16<20393,93,93>,DarkOrange>,Mix<TwistAngle<>,Rgb16<20393,93,93>,Orange>,0,4,5,4000,10>>,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<4000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>,AlphaL<Red,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,TrExtend<3000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,TrFade<3000>>,TrColorCycle<1500,-2000>,SaberBase::LOCKUP_MELT>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,InOutTrL<TrWipeSparkTipX<White,BendTimePowInvX<Int<1000>,Int<180000>>>,TrWipeInSparkTipX<White,BendTimePowX<Int<600>,Int<180000>>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<10000>>>,TrFade<1287>,AlphaL<Orange,Bump<Int<0>,Int<8000>>>,TrFade<643>,AlphaL<Red,Bump<Int<0>,Int<6000>>>,TrFade<643>>,EFFECT_RETRACTION>,ColorSelect<WavNum<EFFECT_PREON>,TrInstant,TransitionEffectL<TrConcat<TrInstant,AlphaL<AlphaL<Mix<Scale<Trigger<EFFECT_PREON,Int<1983>,Int<1>,Int<1>>,Int<0>,Int<30000>>,HumpFlicker<White,Black,20>,HumpFlicker<White,Black,100>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,100>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Strobe<Black,White,15,50>,500>>,SmoothStep<Scale<Trigger<EFFECT_PREON,Int<1983>,Int<1>,Int<1>>,Int<2000>,Int<16000>>,Int<-500>>>,Scale<Trigger<EFFECT_PREON,Int<1983>,Int<1>,Int<1>>,Int<2000>,Int<32768>>>,TrDelayX<Int<1983>>,AlphaL<BrownNoiseFlicker<White,Black,500>,SmoothStep<Int<16000>,Int<-500>>>,TrWipeInSparkTipX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<350>,Int<90>>,White,TrWipeIn<150>,Black,TrInstant,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<2000>,Int<-500>>>,TrDelay<450>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<8000>,Int<-500>>>,TrFade<200>,Black,TrDelay<128>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<6000>,Int<-500>>>,TrFade<200>,Black,TrDelay<373>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<1500>,Int<-500>>>,TrFade<222>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<1500>,Int<-500>>>,TrFade<222>,Black,TrDelay<733>>,EFFECT_PREON>,AlphaL<TransitionEffectL<TrConcat<TrFade<300>,HumpFlicker<White,RotateColorsX<Variation,Rgb<95,0,210>>,10>,TrDelay<500>,HumpFlicker<White,RotateColorsX<Variation,Rgb<95,0,210>>,10>,TrFade<984>,HumpFlicker<White,Black,200>,TrWipeIn<150>>,EFFECT_PREON>,Scale<Trigger<EFFECT_PREON,Int<1450>,Int<484>,Int<1>>,Int<6000>,Int<32768>>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<AlphaL<Mix<Scale<Trigger<EFFECT_PREON,Int<13989>,Int<1>,Int<1>>,Int<0>,Int<30000>>,HumpFlicker<White,Black,20>,HumpFlicker<White,Black,100>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,100>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Strobe<Black,White,15,50>,500>>,SmoothStep<Scale<Trigger<EFFECT_PREON,Int<13989>,Int<1>,Int<1>>,Int<2000>,Int<16000>>,Int<-500>>>,Scale<Trigger<EFFECT_PREON,Int<13989>,Int<1>,Int<1>>,Int<2000>,Int<32768>>>,TrDelayX<Int<13989>>,AlphaL<BrownNoiseFlicker<White,Black,500>,SmoothStep<Int<16000>,Int<-500>>>,TrWipeInSparkTipX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<350>,Int<90>>,White,TrWipeIn<150>,Black,TrInstant,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<2000>,Int<-500>>>,TrDelay<450>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<8000>,Int<-500>>>,TrFade<200>,Black,TrDelay<128>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<6000>,Int<-500>>>,TrFade<200>,Black,TrDelay<373>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<1500>,Int<-500>>>,TrFade<222>,AlphaL<HumpFlicker<White,Black,50>,SmoothStep<Int<1500>,Int<-500>>>,TrFade<222>,Black,TrDelay<733>>,EFFECT_PREON>>,TransitionEffectL<TrConcat<TrExtendX<Int<1000>,TrSmoothFade<200>>,AlphaL<Gradient<Blue,Green>,SmoothStep<VolumeLevel,Int<-1>>>,TrSmoothFade<500>>,EFFECT_VOLUME_LEVEL>,AlphaL<TransitionEffectL<TrConcat<TrSmoothFade<500>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrDelay<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-1>>>,TrSmoothFade<1000>>,EFFECT_BATTERY_LEVEL>,Ifon<Int<0>,Int<32768>>>>>(),
"preset0"
{ "Ronin;common",  "",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<800>,TrWipeIn<800>,Black>>>(),
"preset1"
{ "Mercenary;common",  "",
StylePtr<Layers<StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<15,14,0>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<90,87,0>>,Black>>,RotateColorsX<Variation,Rgb<40,40,0>>,Pulsing<RotateColorsX<Variation,Rgb<36,33,0>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<60,58,0>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<90,88,0>>,RotateColorsX<Variation,Rgb<5,5,0>>,3000>>,AlphaL<StyleFire<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<2,2,0>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<44,42,0>>,Pulsing<RotateColorsX<Variation,Rgb<22,20,0>>,Black,800>>,SwingSpeed<375>>,AlphaL<RotateColorsX<Variation,LemonChiffon>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<750>,Int<-17300>,Int<32768>>,Int<0>>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>,RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,White>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,White>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,White>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,White>,AudioFlicker<RgbArg<LB_COLOR_ARG,White>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,White>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,White>,Int<16000>>,30>,TrSmoothFade<600>>>,AlphaL<RotateColorsX<Variation,LemonChiffon>,SmoothStep<Scale<SlowNoise<Int<2750>>,Int<1750>,Int<3750>>,Int<-4000>>>,ResponsiveStabL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,DeepPink>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,50>>,TrFadeX<Percentage<WavLen<EFFECT_STAB>,50>>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<RgbArg<BLAST_COLOR_ARG,White>,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<RgbArg<BLAST_COLOR_ARG,White>,200,200>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,White>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,White>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<100,100,150>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,80>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<110,115,140>>,RotateColorsX<Variation,Rgb<60,60,80>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,80>>>>,TrFadeX<Percentage<WavLen<>,65>>>,EFFECT_IGNITION>, TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFadeX<Percentage<WavLen<>,125>>>,EFFECT_RETRACTION>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,27500>,Int<5000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,29250>,Int<5000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<6000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<Int<29000>,Int<8000>>>,TrExtend<2000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<29000>,Int<8000>>>,TrFade<3000>>,TrFade<250>,SaberBase::LOCKUP_MELT>,InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,8>>,TrWaveX<White,Percentage<WavLen<EFFECT_IGNITION>,25>,Int<300>,Percentage<WavLen<EFFECT_IGNITION>,8>,Int<0>>>,TrColorCycle<950,7500>>,TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<>,33>>,TransitionLoopL<TrJoin<TrWipeIn<142>,TrSparkX<RotateColorsX<Variation,LemonChiffon>,Int<425>,Int<142>,Int<32768>>>>,TrDelayX<Percentage<WavLen<>,67>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<>,33>,Percentage<WavLen<>,67>,Int<0>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,HotPink>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,LightPink>,RotateColorsX<Variation,LemonChiffon>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepPink>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Yellow>>>,RotateColorsX<Variation,LemonChiffon>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-350>,Int<17500>>,Int<-4000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Black,SmoothStep<Sin<Int<10>,Int<16500>,Int<14500>>,Sin<Int<7>,Int<10500>,Int<9500>>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>>>(),
"preset2"
{ "Binary;common",  "",
StylePtr<Layers<ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrColorCycleX<Int<1200>>>,HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,60>,HumpFlicker<RgbArg<ALT_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<0,135,255>>>,60>>,AlphaL<Stripes<2800,-3000,RgbArg<SWING_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<2096>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,255>>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,0,255>>>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<1500>>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>,200>,RandomPerLEDFlicker<Mix<Int<3137>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<2>>,Int<-1>>,EFFECT_USER1>,TransitionEffectL<TrDoEffectAlwaysX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<-1>>,Int<2>>,Int<-1>>,EFFECT_USER2>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RandomPerLEDFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,SyncAltToVarianceL,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,0,255>>,BendTimePowX<IgnitionTime<1500>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrColorCycleX<BendTimePowX<RetractionTime<0>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>,TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlickerL<RgbArg<POSTOFF_COLOR_ARG,Rgb<255,255,255>>,Int<30>>,SmoothStep<Scale<SlowNoise<Int<2000>>,IntArg<PREON_SIZE_ARG,2000>,Sum<IntArg<PREON_SIZE_ARG,2000>,Int<3000>>>,Int<-4000>>>,TrDelayX<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>>>,EFFECT_POSTOFF>>>(),
"preset3"
{ "Coda;common",  "",
StylePtr<Layers<Mix<Sin<Int<3>>,AudioFlicker<RotateColorsX<Variation,DodgerBlue>,Stripes<5000,-90,RotateColorsX<Variation,Rgb<0,55,165>>,RotateColorsX<Variation,Rgb<0,85,115>>,RotateColorsX<Variation,Rgb<0,65,145>>,RotateColorsX<Variation,Rgb<0,30,185>>>>,AudioFlicker<RotateColorsX<Variation,Rgb<0,155,255>>,Stripes<5000,-90,RotateColorsX<Variation,Rgb<0,95,170>>,RotateColorsX<Variation,Rgb<0,115,215>>,RotateColorsX<Variation,Rgb<0,145,145>>,RotateColorsX<Variation,Rgb<0,65,225>>>>>,AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black,300>,SwingSpeed<400>>,AlphaL<Stripes<1000,-2000,RandomPerLEDFlicker<RotateColorsX<Variation,DeepSkyBlue>,Black>,Black,RotateColorsX<Variation,DeepSkyBlue>,Black>,SwingSpeed<525>>,LockupTrL<Layers<AlphaL<AudioFlickerL<Rgb<255,240,80>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<LemonChiffon,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<875>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<RotateColorsX<Variation,Yellow>>,EffectSequence<EFFECT_BLAST,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,LocalizedClashL<White,80,30,EFFECT_BLAST>,ResponsiveBlastWaveL<White,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,BlastL<White,200,200>,ResponsiveBlastFadeL<White,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<White,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,ResponsiveClashL<TransitionEffect<Rgb<255,240,80>,LemonChiffon,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<90,180,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,26,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<90,180,255>>,RotateColorsX<Variation,Rgb<0,26,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>>,TrFade<400>,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<90,180,255>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,26,60>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<90,180,255>>,RotateColorsX<Variation,Rgb<0,26,60>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<0,42,128>>,RotateColorsX<Variation,Rgb<0,26,60>>>>,TrFade<450>,HumpFlickerL<AlphaL<RotateColorsX<Variation,Rgb<90,180,255>>,Int<19000>>,25>,TrFade<2875>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrFade<1125>,RotateColorsX<Variation,Rgb<90,180,255>>,TrInstant>,EFFECT_RETRACTION>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<500>,TrWipeIn<1125>>,TransitionEffectL<TrConcat<TrFade<450>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,10>,Bump<Int<0>,Int<3000>>>,TrFade<350>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,15>,Bump<Int<0>,Int<5000>>>,TrFade<450>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,20>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,DeepSkyBlue>,25>,Bump<Int<0>,Int<10500>>>,TrBoing<150,1>>,EFFECT_PREON>>>(),
"preset4"
{ "Spaceballs;common",  "",
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<108,255,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<108,255,0>>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,26113>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26113>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26113>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26113>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"preset5"
{ "Malicos;common",  "",
StylePtr<Layers<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,LockupTrL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,LayerFunctions<Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>,SaberBase::LOCKUP_LIGHTNING_BLOCK>,LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26396>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,25263>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,25263>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"preset6"
{ "Vader;common",  "",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,TransitionEffectL<TrConcat<TrFade<400>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrDelay<1500>,StyleFire<Stripes<2500,-5000,BrownNoiseFlicker<Red,Black,20>,Rgb<10,0,0>,BrownNoiseFlicker<Black,Rgb<255,25,25>,70>,Rgb<128,0,0>>,Rgb<80,0,0>,0,5,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>,FireConfig<2,3000,0>>,TrFade<800>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,ResponsiveLockupL<Strobe<White,BrownNoiseFlicker<White,Blue,300>,50,1>,TrConcat<TrInstant,White,TrFade<400>>,TrFade<100>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Scale<SwingSpeed<100>,Int<10000>,Int<14000>>>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
"preset7"
{ "Survivor;common",  "",
StylePtr<Layers<Stripes<16000,-1000,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,Pulsing<Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>,800>,RgbArg<BASE_COLOR_ARG,Rgb<255,68,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,26679>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26396>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26679>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26679>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"preset8"
{ "Assassin;common",  "",
StylePtr<Layers<HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<180,130,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,255,0>>,60>,AlphaL<RgbArg<EMITTER_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-6000>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,25688>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26254>,Int<3000>>>,TrWipeIn<200>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,25688>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,25688>,Int<4000>>>,TrFade<300>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,Black>>>(),
"preset9"
 /* Generated with Fett263 Config Helper v3.0 */
cut-n-paste means copying the text, not an image.
Specifically in this case, it means using the “copy error message” button in arduino, then pasting that into the post. (Using ``` before and after to make it into a nicely formatted chunk of text.)
I don’t see why this error is happening.
Arduino: 1.8.19 (Mac OS X), Board: "Proffieboard V2, Serial, SDCARD (SPI), 80 MHz, Smallest Code"
In file included from ProffieOS/styles/fire.h:4,
                 from ProffieOS/ProffieOS.ino:532:
ProffieOS/styles/style_ptr.h: In instantiation of 'OverDriveColor StyleHelper<RetType>::getColor(int) [with RetType = RGBA]':
ProffieOS/styles/style_ptr.h:35:18:   required from here
ProffieOS/styles/style_ptr.h:35:63: error: could not convert '((StyleHelper<RGBA>*)this)->StyleHelper<RGBA>::getColor2(i)' from 'RGBA' to 'OverDriveColor'
      |                                                               RGBA
Using library Wire at version 1.0 in folder: ~/Library/Arduino15/packages/proffieboard/hardware/stm32l4/3.6.0/libraries/Wire
Simplifying and reducing the Binary preset style to this base color only still causes the error.
StylePtr<Layers<
  ColorSelect<AltF,TrSelect<Ifon<Int<1>,Int<0>>,TrInstant,TrFade<300>>,
  HumpFlicker<Red,Mix<Int<16448>,Black,Red>,60>,
  HumpFlicker<DeepSkyBlue,Mix<Int<16448>,Black,DeepSkyBlue>,60>>>>(),
Adding a Black layer underneath does allow compiling, so it thinks there’s transparency?
That’s interesting for sure, I’ll try and see if I can fix whatever transparency may be there. This is definitely a first for me
@profezzorn The issue seems to be with TrSelect.
Everything works fine until that is used.
Style Editor has no problem with it FWIW.
TrSelect is currently ALWAYS transparent.
It’s unfortunately somewhat difficult to fix.
Ok good to know.
So @Jrdriverzc , just add a Black layer as the base color, like
StylePtr<Layers<Black,
ColorSelect<..............
Alright, will do, thanks for the help, much appreciated.
