Ok, I’ll have a look. Post your config so I can see if there’s a define issue.
#include "proffieboard_v1_config.h"
#define VOLUME 2300
#define CLASH_THRESHOLD_G 2.2
#define DISABLE_COLOR_CHANGE
#define FETT263_MAX_CLASH 16
#define FETT263_SAY_BATTERY_VOLTS
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_SWING_ON
#define SAVE_STATE
#define ENABLE_SERIAL
#define ENABLE_SSD1306
// Max 20 characters
#define BLE_PASSWORD "1234"
// Max 32 characters.
#define BLE_NAME "Tran"
// Max 9 characters
#define BLE_SHORTNAME "Tran"
// Fire speed, valid values are 1 - 10
#define FIRE1_SPEED 8
// How long to wait before firing up crossguards.
#define FIRE1_DELAY 800
// Each of these have three values: A, B, C
// A = non-random intensity
// B = random intensity
// C = cooling
// The first two control temperature, and as we add
// A + rnd(B) to the base of the blade each animation frame.
// The second controls how rapidly the fire cools down
// This is used during normal operation.
#define FIRE1_NORMAL 0, 1000, 2
// This is used when a clash occurs
#define FIRE1_CLASH 3000, 0, 0
// This is used during lockup.
#define FIRE1_LOCKUP 0, 5000, 10
// Helper
#define FIRE1PTR(NUM, DELAY) \
StyleFirePtr<RED, YELLOW, NUM, DELAY, FIRE1_SPEED, \
FIRE1_NORMAL, FIRE1_CLASH, FIRE1_LOCKUP>()
{ "anhtrain;common", "common/tracks/drone.wav",
/* © Fett263 Rotoscope (Primary Blade) OS6 Style
Style Options
Default(0): Base Color (Original)
1: Base Color + Alt Color (Original)
2: Base Color (Fast)
3: Base Color + Alt Color (Fast)
4: Base Color (Slow)
5: Base Color + Alt Color (Slow)
Effects =
Ignition Effect Options: Default (0): Standard Ignition, 1: Wipe In, 2: Cycle Up, 3: SparkTip Ignition, 4: Center Out, 5: Center In
Power Up Effect Options: Default (0): Disabled, 1: Unstable Power Up, 2: Bright Power Up , 3: AudioFlicker Power Up
Retraction Effect Options: Default (0): Standard Retraction, 1: Run Up, 2: Cycle Down, 3: SparkTip Retraction 4: Split Retraction, 5: Center In
Cool Down Effect Options: Default (0): Disabled, 1: Unstable Cool Down, 2: Bright Cool Down, 3: AudioFlicker Cool Down
Preon Effect Options: Default(0): Disabled, 1: Faulty Ignition V1, 2: Faulty Ignition V2, 3: Overload, 4: Erratic, 5: Pulsing
Swing Effect: Default (0): Disabled, 1: Enhanced Bright Swing, 2: Bright Swing, 3: Force Boost Enhanced Bright Swing, 4: Force Boost Bright Swing
Lockup Effect: Intensity Lockup
Lightning Block Effect: Responsive Lightning Block
Drag Effect: Standard Drag
Melt Effect: Intensity Melt
Blast Effect: Multi-Blast (Sequence)
Clash Effect: Real Clash
Battery Level: % Blade - Red to Green
StylePtr<Layers<
ColorSelect<IntArg<STYLE_OPTION_ARG, 0>,TrInstant,RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<14000,-4000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<14000,-4000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,
ColorSelect<IntArg<SWING_OPTION_ARG, 0>,TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Int<0>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,SwingSpeed<600>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TrDelay<30000>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,SwingSpeed<600>>,TrDelay<30000>>,EFFECT_FORCE>>,
TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFadeX<IgnitionTime<300>>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<IgnitionTime<300>>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrFadeX<IgnitionTime<300>>>>,EFFECT_IGNITION>,
TransitionEffectL<TrSelect<IntArg<RETRACTION_COOL_DOWN_ARG,0>,TrInstant,TrConcat<TrInstant,HumpFlickerL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,40>,TrDelayX<RetractionTime<0>>>,TrConcat<TrInstant,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrDelayX<RetractionTime<0>>>>,EFFECT_RETRACTION>,
LockupTrL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<16000>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump< Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>, Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF< Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>> ,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>, Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,
EffectSequence<EFFECT_BLAST,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,BlastF<200,200>>,TrFade<300>>,EFFECT_BLAST>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,ResponsiveBlastWaveL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>,EFFECT_CLASH>>,
LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31000>,Int<2000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<6000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<Int<29000>,Int<8000>>>,TrExtend<2000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<29000>,Int<8000>>>,TrFade<3000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<300>>,TrWipeInX<IgnitionTime<300>>,TrColorCycleX<IgnitionTime<300>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrCenterWipeX<IgnitionTime<300>,Int<16384>>,TrCenterWipeInX<IgnitionTime<300>,Int<16384>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrWipeX<RetractionTime<0>>,TrColorCycleX<RetractionTime<0>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,TrCenterWipeX<RetractionTime<0>,Int<16384>>>,RotateColorsX<Variation,Black>>,
TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrInstant,AlphaL<RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Black>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,5>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<100>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,3>,Black,TrBoingX<Mult<Int<7260>,WavLen<EFFECT_PREON>>,3>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<200>>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<3664>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrExtend<3000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
"ANH TRAIN"
{ "kross;common", "common/tracks/kylo.wav",
/* © Fett263 Kylo Ren Film-Based Unstable (Primary Blade) OS6 Style
Effects =
StylePtr<Layers<
StaticFire<BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RandomPerLEDFlicker<Mix<Int<3213>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,300>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,0,6,10,1000,2>,
>>(), "KROSS"
{ "oldben;common", "common/tracks/force.wav",
Style Options
Effects =
StylePtr<Layers<
"Old Ben"
{ "vader;common", "common/tracks/hall.wav",
Style Options
Effects =
StylePtr<Layers<
"R1Darth\nRED"
{ "rescue;common", "common/tracks/rescue.wav",
Style Options
Effects =
StylePtr<Layers<
"Rescue"
{"f1;common", "common/tracks/pod.wav",
Style Options
Effects =
StylePtr<Layers<
"falcon"
{ "seismic;common", "common/tracks/fett.wav",
// Slave 1 with seismic charge preon
StylePtr<Layers<
Mix<SmoothStep<Int<16384>,Int<4000>>,Stripes<10000,500,Rgb<0,30,80>,Rgb<0,60,180>>,Stripes<10000,-500,Rgb<0,30,80>,Rgb<0,60,180>>>,
// Dim Blade 50% "Power Save" button combo
EffectSequence<EFFECT_POWERSAVE,
AlphaL<Black,Int<16384>>,
AlphaL<Black,Int<0>>>,
// Clash - 3 stage fading impact spot
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Moccasin,TrInstant,TrFade<300>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Int<18000>>>,TrFade<600>>,EFFECT_CLASH>,
// Stab
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<300>,AlphaL<Stripes<5000,1000,DarkOrange,Rgb<80,60,0>,Orange,Rgb<60,30,0>,Black,DarkOrange,Orange>,SmoothStep<Int<20000>,Int<2000>>>,TrJoin<TrSmoothFade<900>,TrWipe<700>>>,EFFECT_STAB>,
// Blast
MultiTransitionEffectL<TrConcat<TrDelay<700>,AlphaL<Black,Int<0>>,TrFade<800>,LocalizedClashL<HumpFlicker<DarkOrange,Red,50>,2000,50,EFFECT_BLAST>,TrFade<600>>,EFFECT_BLAST>,
LocalizedClashL<Blinking<White,Black,130,800>,1560,50,EFFECT_BLAST>,
LocalizedClashL<Blinking<Red,Black,130,500>,1560,15,EFFECT_BLAST>,
// Lockup
LockupTrL<Layers<
AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,
AlphaL<BrownNoiseFlicker<Yellow,Black,50>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,
TrConcat<TrInstant,
AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<100>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
// Non-Responsive Drag
LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>,
// Lightning Block
ResponsiveLightningBlockL<RandomFlicker<Strobe<White,Rgb16<21301,0,65535>,50,10>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>>,
//Begin Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>,TrFade<100>>,
//End Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb16<21301,0,65535>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>> >>,
// Melt
LockupTrL<
//Mely Colors
AlphaL<Mix<TwistAngle<>,Yellow,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,
// Melt Shape
SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,
//Melt Begin and End transitions
TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_MELT>,
// Ignition Powerup
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlicker<DeepSkyBlue,White,100>,TrFade<800>>,EFFECT_IGNITION>,
// In/out using Trigger for instantaneous Center-out wipes
InOutTrL<TrConcat<TrInstant,Layers<
AlphaL<Black,SmoothStep<Scale<Trigger<EFFECT_IGNITION,Int<300>,Int<1000>,Int<500>>,Int<16385>,Int<0>>,Int<-1>>>,
AlphaL<Black,SmoothStep<Scale<Trigger<EFFECT_IGNITION,Int<300>,Int<1000>,Int<500>>,Int<16384>,Int<32768>>,Int<0>>>>,TrDelay<1000>>,TrJoin<TrWipe<700>,TrWipeIn<700>>>,
TransitionEffectL<TrConcat<TrInstant,Cyan,TrDelay<50>>,EFFECT_IGNITION>,
// Asteroid impacts after detonation - timed sequence
TrDelay<1500>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Red,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<3000>,Int<6000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<400>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Orange,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<6000>,Int<10000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<200>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Black,White,100>,Bump<ChangeSlowly<SlowNoise<Int<30000>>,Int<60000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<300>,AlphaL<Red,Int<0>>,
TrDelay<200>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Yellow,Red,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<10000>,Int<28000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<200>,AlphaL<Red,Int<0>>,
TrDelay<500>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Orange,White,100>,Bump<ChangeSlowly<SlowNoise<Int<30000>>,Int<60000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<200>,AlphaL<Red,Int<0>>,
TrDelay<100>,GreenYellow,TrDelay<25>,AlphaL<BrownNoiseFlicker<Red,White,100>,Bump<Scale<SlowNoise<Int<30000>>,Int<5000>,Int<13000>>,ChangeSlowly<SlowNoise<Int<30000>>,Int<20000>>>>,TrDelay<100>,AlphaL<Red,Int<0>>,
TrDelay<500>,GreenYellow,TrDelay<25>>,EFFECT_IGNITION>,
// Seismic Charge preon effect. use with linked preon sound
TransitionEffectL<TrConcat<TrDelay<2125>,Cyan,TrFade<100>,Black,TrDelay<10>,Cyan,TrFade<150> >,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<2125>,AlphaL<White,Bump<Int<16384>,Int<32768>>>,TrFade<100>, Black,TrDelay<10>,AlphaL<White,Bump<Int<16384>,Int<32768>>>,TrFade<150> >,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<2100>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<3000>>>,TrDelay<100>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<4000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<5000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<10000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,
TrSmoothFade<175>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<30000>>>,
TrSmoothFade<125>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<35000>>>,
TrSmoothFade<150>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<30000>>>,
TrSmoothFade<75>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,
TrSmoothFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<8000>>>,
TrSmoothFade<25>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<3000>>>,TrFade<50>,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Int<16384>,Int<20000>>>,TrDelay<25>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<BrownNoiseFlicker<DeepSkyBlue,White,100>,Bump<Scale<Trigger<EFFECT_PREON,Int<2000>,Int<1000>,Int<500>>,Int<-1000>,Int<16500>>,Int<1500>>>,TrDelay<2000>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrDelay<1100>,AlphaL<Red,Int<0>>,TrSmoothFade<700>,Black,TrDelay<100>,AlphaL<White,Bump<Int<16384>,Int<3000>>>,TrDelay<100>>,EFFECT_PREON>
"Light"
{"bells;common", "common/tracks/bells.wav",
/* copyright Fett263 Holidays (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Holidays
OS6.7 v4.019
Base Style: Candy Cane (Inertia Swing White + 1 Color)
Base Color: Rgb<255,0,0> (0)
Clash Effect: Real Clash V1
StylePtr<Layers<StripesX<Int<2000>,Scale<HoldPeakF<SwingSpeed<200>,Int<300>,Scale<SwingSpeed<200>,Int<8000>,Int<24000>>>,Int<0>,Int<-2000>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Rgb<128,128,128>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<300>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
"bells"
// Hook up the main blade as normal.
// Hook up one of the crossguards like this:
// NEOPIXEL + <--> positive power (probably from charge port)
// NEOPIXEL - <--> LED4 pad on the bottom of the teensysaber
// NEOPIXEL data <--> Nepixel data 2 (through a 300ohm resistor)
// Hook up the other crossguards like this:
// NEOPIXEL - <--> LED5 pad on the bottom of the teensysaber
// NEOPIXEL data <--> Nepixel data 3 (through a 300ohm resistor)
{ 0, // blade ID resistor not used
// Main blade, 127 LEDs
WS2811BladePtr<133, WS2811_800kHz | WS2811_GRB>(),
CONFIGARRAY(presets)
I did some testing with this, and I found that TrLoopNX was missing one iteration. (fixed on github master) Everything else seems to work fine when I tried it in a simple style.
This is what I actually tested:
StylePtr<Layers<
Red,
InOutTrL<TrConcat<TrDelay<2000>,TrSmoothFade<1800>,White,TrLoopNX<Int<5>,TrJoin<TrSmoothFade<1500>,TrWipe<1500>>>>,TrWipeIn<1000>>>>()
OK will check asap.
Hey, what makes PULSE work? is it when the function returns 32768?
Someone have a basic example of what an appropriate pulse could be?
As in, it doesn’t sound like Sin would be a good pulse generator…
// Usage: TrLoopUntil<PULSE, TRANSITION, OUT>
// TRANSITION, OUT: TRANSITION
// PULSE: FUNCTION (pulse)
// Return Value: TRANSITION
// Runs the specified transition until the pulse occurs.
// When the pulse occurs, the loop continues, but OUT is used to
// transition away from it, and when OUT is done, the transition is done.
Pulses trigger when non-zero.
Pulses are generally meant to be short, meaning that they only return non-zero for a single frame. (one run() call)
Any function can be converted into a pulse with ThresholdPulseF.
However, the easy way to generate a pulse is EffectPulseF.
I tested and it works as expected but I updated the control comments at the top of the prop in case there was confusion.
"Battle Mode" Controls* - While ON
Blast Effect = Click AUX
After Blast, swing within 2 seconds to enter Multi-Blast Mode
While in “Battle Mode” if you do a Blast effect by clicking the button and THEN swing again within 2 seconds it automatically enters Multi-Blast Mode so that every swing (until you clash or hit a button) creates another Blast deflection. Since you’re already in Battle Mode there isn’t a sound, it just enters automatically if you do a Blast effect AND Swing after that effect. Now if you’re swinging during the first Blast effect you need to stop or reverse the swing within 2 seconds and swing again for it to see a Swing “After” the Blast.
So the process is:
- Enter Battle Mode
- Do a normal Blast effect with a button
- Swing (after the first Blast, within 2 seconds)
- All following swings generate Blast deflection unless you clash or hit a button
- Clashing, hitting button or exiting Battle Mode will end MultiBlast
If you are NOT in Battle Mode and enter MultiBlast with the normal button control there a re notification sounds (if in your font) for blstbgn.wav and blstend.wav.
Let me know if you’re still having trouble (maybe shoot a video) and I can try to figure out for you.
Thanks, and that helps. A couple of follow-up questions.
- I opened the Presets.ini in Sublime Text and it comes up with the same format as in my post above, every time. I cannot open it in the MacOS native TextEdit application. Assuming the second save file is the Presets.tmp…
- When I open Presets.tmp in Sublime Text, the same format as the above. However, when I open it in the native MacOS application TextEdit, it opens just fine, and looks very similar to the Presets.ini file as it was in OS6, with one exception. The additional characters at the top…are these characters the 512 bytes you reference in the documentation?
˛Zˇ{jwT¢˛Zˇ{jwT¢Mar 5 2023 14:41:08installed=Mar 5 2023 14:41:08
new_preset
font=ANH_GRAFLEX;common
track=common/tracks/starwars.wav
style=builtin 0 1 20605,65535,65535 ~ 0 0 300 ~ 65535,62656,40406 0 65535,62656,40406 65535,62656,40406 65535,62656,40406 16000 65535,65535,65535 28265 65535,62656,40406 65535,5279,0 26000 65535,65535,65535 0 ~ -97 65535,62656,40406 0 368 0 0 ~ 65535,62656,40406 0 65535,62656,40406 ~ 0
style=builtin 0 1 65535,65535,65535 ~ 0 0 300 ~ 65535,62656,40406 0 65535,62656,40406 65535,62656,40406 65535,62656,40406 16000 65535,65535,65535 28265 65535,62656,40406 65535,5279,0 26000 65535,65535,65535 0 ~ -97 65535,62656,40406 0 368 0 0 ~ 65535,62656,40406 0 65535,62656,40406 ~ 0
name=anh graflex
variation=0
Just delete the .ini version. It will get rewritten based on .tmp.
I read the prop file directions. I’m entering battle mode via gesture. I am blasting then swinging within 1 second and its not working.
I also tried entering battle mode by holding aux and swinging. I get the “battle mode” voice, and all the battle mode stuff works except for blast then swing to trigger multi blast. I’ll try and do a video after work.
Strange, I tested with your config, a video might help.
What about the odd characters at the top of the .tmp? Is the .tmp the second savefile as mentioned in the documentation? What about the 512 bytes mentioned?
Unless you’re really trying to save something that you had preserved in that saved presets.ini file, just delete both and let the board rewrite based on your current config and whatever change you make.
I’m honestly still a little fuzzy on when they get created. I think you need to enter color change mode once?
I definitely am trying to retain all of what I have in the Presets.ini. Back to my confusion, why is the .tmp file openable and readable by an app like TextEdit, but the .ini file is not? I actually get an error when attempting to open it. The .tmp file also looks similar to an OS6 Presets.ini file other than the symbol characters at the very top.
Both open in Sublime Text but look the same as I pasted above. My goal is to understand which file to edit and how when I want to make what were historically Presets.ini edits.
In OS7, it’s hard to tell which file is the last saved one. (It’s either the ini or the tmp)
To make an edit, you have to delete the first 512 bytes, and everything after the “end” statement.
Save the file as *.ini, then delete the *.tmp file.
You’ll want an editor that can actually show the zeroes in the file, instead of just skipping them. I’m sure sublime has a setting for that, but I don’t use it myself, so I don’t know where to find it.
Oh, and if the ini file looks weird but the tmp file doesn’t, that’s because it’s only saved data once. On the second save, the tmp file will be converted to the new format as well.
Thank you. I appreciate the clarification into the .ini vs. .tmp, especially that I’ll need to save whatever one I edit as the .ini after adjusting.
Re: the 512 bytes, this is what the .tmp looks like at the top. Are those characters at the top the first 512 bytes? How do I measure how many bytes they are otherwise?
So, I’ve made some progress. If I delete everything before the “installed…” and save that file, I can then open it in Sublime Text and it looks like a standard Presets.ini file other than all the errant characters after the “end”. However, I can delete those, save the file, and then open it in any text editor, even MacOS’ TextEdit, and it looks like a traditional Presets.ini file end to end.
If there is a text editor that will work from the get-go, we can actually measure the text I’m deleting before the “installing” to ensure it is the 512 bytes referred to by the documentation. For now, it’s a hunch.
Since you can’t see the zeroes, there is no way to know if you did it right or not.
You need a text editor that will show the zeroes.
On windows, Notepad++ can do it with the “show all characters” setting.
Emacs can do it on any platform, I just don’t like recommending it to people.
I’ll delete my .ini files on SD, update from repo, and re-flash again tonight when I get home.
Emacs seems unattainable for me, as does a Windows setup. I’ll have to find another text editor. This “workaround” I discovered has, at least, gotten me to a Presets.ini file that looks identical to the traditional Presets.ini file. Every preset is there end to end. I even tested it (deleted Presets.ini and .tmp, and replaced with the Presets.ini I created) and it worked.
It’s not clean, but perhaps workable. The hardest part is determining which (Presets.ini or Presets.tmp) is the most up-to-date savefile when backing up/making adjustments.
