Well, this appears to have solved the connection issue. But I might have a fragile system since I got this while I had the monitor window left open between connections:
java.io.IOException: jssc.SerialPortException: Port name - COM9; Method name - setEventsMask(); Exception type - Can't set mask.
at processing.app.Serial.dispose(Serial.java:171)
at processing.app.SerialMonitor.close(SerialMonitor.java:147)
at processing.app.AbstractMonitor.suspend(AbstractMonitor.java:113)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - COM9; Method name - setEventsMask(); Exception type - Can't set mask.
at jssc.SerialPort.setEventsMask(SerialPort.java:279)
at jssc.SerialPort.removeEventListener(SerialPort.java:1064)
at jssc.SerialPort.closePort(SerialPort.java:1090)
at processing.app.Serial.dispose(Serial.java:168)
... 4 more
And with the #if 0 I got 2 minutes without disconnection. I didn’t tested further, so that seems to be the core issue on the problems with monitoring.
I took the liberty of testing with:
#define BLADE_ID_CLASS ExternalPullupBladeID<bladeIdentifyPin, 33000>
#define BLADE_DETECT_PIN blade3Pin
I tested eight times per Blade ID:
45,403.71
685,978.25
856,263.81
856,263.81
66,096.77
701,608.50
811,800.00
960,882.75
833,461.81
1,173,858.37
45,041.57
1,022,999.00
45,041.57
1,022,999.00
8,513.51
880,296.56
8,513.51
1,173,858.37
8,564.58
1,057,064.00
8,513.51
1,318,680.00
8,513.51
642,840.00
8,513.51
1,132,242.00
8,513.51
604,585.25
8,513.51
685,978.25
6,708.58
1,375,000.87
6,708.58
991,000.94
6,661.97
856,263.81
6,661.97
1,022,999.00
6,661.97
1,318,680.00
6,708.58
656,632.88
856,263.81
833,461.81
856,263.81
833,461.81
856,263.81
856,263.81
833,461.81
833,461.81
833,461.81
856,263.81
833,461.81
856,263.81
856,263.81
833,461.81
811,800.00
856,263.81
833,461.81
Then I went and did a set of tests with Blade Present and no multisampling:
685,978.25
856,263.81
856,263.81
66,096.77
701,608.50
811,800.00
960,882.75
833,461.81
1,173,858.37
45,041.57
1,022,999.00
45,041.57
1,022,999.00
8,513.51
880,296.56
8,513.51
1,173,858.37
8,564.58
1,057,064.00
8,513.51
1,318,680.00
8,513.51
642,840.00
8,513.51
1,132,242.00
8,513.51
604,585.25
8,513.51
685,978.25
6,708.58
1,375,000.87
6,708.58
991,000.94
6,661.97
856,263.81
6,661.97
1,022,999.00
6,661.97
1,318,680.00
6,708.58
656,632.88
856,263.81
833,461.81
856,263.81
833,461.81
856,263.81
856,263.81
833,461.81
833,461.81
833,461.81
856,263.81
833,461.81
856,263.81
856,263.81
833,461.81
811,800.00
856,263.81
833,461.81
Then I redid the test but with Blade Present plus #define BLADE_ID_TIMES 20.
834,602.06
839,162.44
835,742.19
834,602.06
838,022.38
835,742.19
844,113.63
839,162.44
44,978.63
834,773.06
824,850.00
836,882.25
839,280.94
839,794.69
835,856.19
842,639.69
839,162.44
837,163.13
833,575.94
845,043.00
45,014.68
841,442.63
834,773.06
839,219.44
103,728.33
801,792.50
106,005.69
802,631.00
104,676.30
823,916.19
105,836.09
879,287.31
104,900.10
844,030.94
103,098.16
904,360.94
102,034.46
878,908.00
104,116.52
834,133.63
6,678.28
910,578.44
6,666.64
986,173.00
6,671.29
823,302.44
6,661.98
906,300.44
6,671.29
957,356.31
6,675.96
813,782.56
6,668.96
6,730.42
6,661.98
897,397.81
8,505.87
977,995.00
8,521.18
897,616.13
8,510.98
969,839.63
8,508.42
742,550.75
8,505.87
917,474.44
8,518.62
875,079.63
8,508.43
831,451.69
8,500.79
937,246.19
848,344.81
829,243.56
838,307.38
835,974.69
842,819.81
849,660.44
838,250.38
838,197.94
6,659.65
840,478.13
6,671.29
828,380.19
6,680.63
835,124.19
6,675.96
840,478.13
6,664.32
837,176.38
6,659.65
837,167.25
6,661.99
826,201.88
6,666.65
831,691.00
846,548.63
852,353.63
854,586.69
838,056.69
837,786.75
842,088.94
845,584.13
837,676.88
6,657.11
928,584.19
6,603.64
1,087,600.37
6,714.03
1,188,606.75
6,572.92
1,296,764.87
6,680.00
1,143,575.87
6,619.63
1,033,736.19
6,797.19
1,232,400.87
6,627.92
1,219,759.37
6,708.58
852,941.81
6,689.94
6,689.94
8,508.43
847,617.19
45,059.80
849,423.31
21,679.64
861,316.63
45,005.69
844,985.94
45,077.70
974,889.00
45,150.04
851,949.63
45,403.71
685,978.25
856,263.81
856,263.81
66,096.77
701,608.50
811,800.00
960,882.75
833,461.81
1,173,858.37
45,041.57
1,022,999.00
45,041.57
1,022,999.00
8,513.51
880,296.56
8,513.51
1,173,858.37
8,564.58
1,057,064.00
8,513.51
1,318,680.00
8,513.51
642,840.00
8,513.51
1,132,242.00
8,513.51
604,585.25
8,513.51
685,978.25
6,708.58
1,375,000.87
6,708.58
991,000.94
6,661.97
856,263.81
6,661.97
1,022,999.00
6,661.97
1,318,680.00
6,708.58
656,632.88
856,263.81
833,461.81
856,263.81
833,461.81
856,263.81
856,263.81
833,461.81
833,461.81
833,461.81
856,263.81
833,461.81
856,263.81
856,263.81
833,461.81
811,800.00
856,263.81
833,461.81
When I tested the 45k blade plug the blade was detected but many times not the 45k resistor: May be I didn’t push strong enough since the plug was a bit short? Again, the 39k charging plug was detected on the 105k range. I’m not convinced about the #define BLADE_ID_TIMES 20
NO Blade Detected
EVENT: Select-On millis=37912
Blade Detected
EVENT: Select-Off millis=41117
NO Blade Detected
EVENT: Select-On millis=44198
Blade Detected
EVENT: Select-Off millis=46766
NO Blade Detected
EVENT: Select-On millis=51103
Blade Detected
EVENT: Select-Off millis=54271
NO Blade Detected
EVENT: Select-On millis=56467
Blade Detected
EVENT: Select-Off millis=59903
NO Blade Detected
EVENT: Select-On millis=62510
Blade Detected
EVENT: Select-Off millis=67636
NO Blade Detected
EVENT: Select-On millis=71192
Blade Detected
EVENT: Select-Off millis=74998
NO Blade Detected
EVENT: Select-On millis=77263
Blade Detected
Or may be I just need to try the #define BLADE_ID_CLASS SnapshotBladeID<bladeIdentifyPin> and see if it makes any difference?
