Proffieboard V2 and V3.9 pin numbers
I am looking a diagram or table that gives all of the pin numbers for not for the V2 board and the V3.9 board.
3.9 board
https://fredrik.hubbe.net/lightsaber/v6/
That does not give a pin number to all of the connection points and it does not give a number to the battery positive and negative or ground pin. Normally all connection have a pin number assigned to them, even if they are normally called out by positive negative or ground. I would also like to know what the pin numbers for the V2 board.
https://fredrik.hubbe.net/lightsaber/v5/
The pinout diagram lists the pin numbers in parenthesis.
