I have made some measurement on my saber:
on with blade: 2200mA
on with only 5 led hilt: 150mA
off (with oled screen and BLE activated): 50mA
off after 5min => idle (oled screen and AV leds + BLE are OFF) : 17mA to 22mA
so it still draw 20mA in deep sleep mode and it will deplete my battery in a few days.
i surely have missed something…
any idea?
below is my config and my wiring
#define NUM_BLADES 4
#define VOLUME 800
const unsigned int maxLedsPerStrip = 137; // 132+5
#define CLASH_THRESHOLD_G 1.0
#define ENABLE_SSD1306
#define ENABLE_SERIAL
#define IDLE_OFF_TIME 60*5*1000 //idle after 5min
// custom FETT263
// #define DISABLE_DIAGNOSTIC_COMMANDS
#define FETT263_FORCE_PUSH
#define FETT263_MULTI_PHASE
{ "Maul", "tracks/track4.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Red>,RotateColorsX<Variation,Rgb<128,0,0>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Orange,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Rgb<255,200,0>,DarkOrange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>>>(),
StylePtr<Layers<Red,InOutTrL<TrInstant,TrInstant,Pulsing<Black,Red,3000>>>>(),
StyleNormalPtr<BLUE, BLUE, 300, 800>(),
StylePtr<BLUE>(),
"Maul"},
StyleNormalPtr<RED, RED, 300, 800>(),
StylePtr<BLUE>(),
"Sith red"},
struct AVRedLED {
static constexpr float MaxAmps = 0.02;
static constexpr float MaxVolts = 2.15;
static constexpr float P2Amps = 0.01;
static constexpr float P2Volts = 1.8;
static constexpr float R = 100.0; // Resistor value
static const int Red = 255;
static const int Green = 0;
static const int Blue = 0;
struct AVBlueLED {
static constexpr float MaxVolts = 2.55;
static const int Red = 0;
static const int Blue = 255;
struct BT_CH3 { // activation BLE on channel Blue
static constexpr float MaxAmps = 1;
static constexpr float MaxVolts = 1000;
static constexpr float P2Amps = 0.0;
static constexpr float P2Volts = 0.0;
static constexpr float R = 0.0; // Resistor value
{ 0, WS281XBladePtr<137, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), //main blade
SimpleBladePtr<AVRedLED, NoLED, NoLED, NoLED, bladePowerPin4, -1, -1, -1>(), // Led Power button
SimpleBladePtr<AVBlueLED, NoLED, NoLED, NoLED, bladePowerPin5, -1, -1, -1>(), // Led Aux button
SimpleBladePtr<BT_CH3, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(), // BLE activation on channel blue
CONFIGARRAY(presets) },
