I’ve recently purchased 4 Proffieboards from the same reputable seller and 2 of the 4 will not connect properly with my computer. I can still connect with 20 other Proffieboards, but these 2 are showing a “Driver is unavailable” error. Through checking the USB serial device properties, I’m seeing events with descriptions that read “Device not migrated” and “Device install requested.”
I’ve used various cables, USB ports, three different versions of ProffieOS, but I can’t get these boards to connect properly. Is there a way to manually select a specific driver and upload it?
I’ve attached 4 screenshots showing what I’m seeing.
Blurgh. I ran the .exe file and am still getting the same exact errors. What’s vexing is my computer works with nearly two dozen other boards, but not these two.
I may attempt deleting ProffieOS and Arduino and starting over completely.
That would lead me to believe there’s an issue with these boards then, once the drivers recognize a Proffieboard it should work the same regardless of the individual board. You may inquire about replacements if you purchased recently.
Yeah, unfortunately if you have other boards that connect without issue, the most likely problem is the boards themselves. If done correctly you only ever need to set up the drivers once. You can try this video but I’m thinking the boards are the problem.
