Proffieboard Arduino Complilation Error 1
Hey all, I am attempting to fix the config on my Korbanth Skinnyflex yet each time I attempt to compile anything that is not the base ProffieOS test I get exit status 1 as below
c:/users/chris/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\chris\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2' not declared
c:/users/chris/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\chris\AppData\Local\Temp\ProffieOS.ino.elf.4h7TJd.ltrans0.ltrans.o: in function `main':
C:\Users\chris\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\cores\stm32l4/main.cpp:129: undefined reference to `setup'
c:/users/chris/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe: C:\Users\chris\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6\cores\stm32l4/main.cpp:133: undefined reference to `loop'
Here is my config:
#define VOLUME 1600
#define CLASH_THRESHOLD_G 4.0
{ "Tusken", "tracks/heros.wav",
StylePtr<Layers<AudioFlicker<RotateColorsX<Variation,Blue>,RotateColorsX<Variation,Rgb<0,0,128>>>,LockupTrL<Layers<AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,White,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<White,AudioFlicker<White,Blue>,50,1>,TrConcat<TrInstant,AlphaL<White,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<White,Int<16000>>,30>,TrSmoothFade<600>>>,ResponsiveStabL<Red,TrWipeIn<600>,TrWipe<600>>,ResponsiveBlastL<White,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveClashL<White,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,LockupTrL<AlphaL<BrownNoiseFlickerL<White,Int<300>>,SmoothStep<Int<30000>,Int<5000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<28000>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipe<300>,TrWipeIn<500>,Black>,TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>>>(),},
{ 0, WS281XBladePtr<133, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
This tends to happen if you try to compile your config file instead of ProffieOS.ino. Did you open up ProffieOS.ino and change the CONFIG_FILE define to point to your config file?
Yeah, So I opened proffieOS.ino and simply pasted in my config, replacing the base text that is in the .ino file. I placed the .H file in the config directory in ProffieOS as well. When I run the test code already in the .ino file it works no issue.
That doesn’t work.
You put the config file in the config directory, and then you just change one line in ProffieOS.ino (the CONFIG_FILE line) to make it use your config file.
All that other stuff in ProffieOS.ino is needed, you can’t just paste over it and expect it to work.
Apologies I’m still pretty new to this; where can I find this CONFIG_FILE line and make it use my config file?
(or find something on youtube that shows how to do it.)
I did as you said but I got an error about teensy so I went back into preferences and installed teensy but no change, Any further advice?
If you could remove the screen shot and just paste the error id be appreciated (and follow community guidelines). You’ll get more help :).
Have you cleaned up your proffie.ino file?
This needs to be undone. I’d download a fresh copy of ProffieOS just to be sure.
In file included from C:\Users\chris\OneDrive\Desktop\ProffieOS-v5.9 (2)\ProffieOS\config\aniflex_config.h:2,
                 from C:\Users\chris\OneDrive\Desktop\ProffieOS-v5.9 (2)\ProffieOS\ProffieOS.ino:43:
C:\Users\chris\OneDrive\Desktop\ProffieOS-v5.9 (2)\ProffieOS\config\aniflex_config.h:2:28: error: #include nested too deeply
    2 | #include "aniflex_config.h"
In file included from C:\Users\chris\OneDrive\Desktop\ProffieOS-v5.9 (2)\ProffieOS\blades\ws2811_blade.h:37,
                 from C:\Users\chris\OneDrive\Desktop\ProffieOS-v5.9 (2)\ProffieOS\ProffieOS.ino:552:
C:\Users\chris\OneDrive\Desktop\ProffieOS-v5.9 (2)\ProffieOS\blades\monopodws.h:41:2: error: #error "Teensyduino version 1.21 or later is required to compile this library."
   41 | #error "Teensyduino version 1.21 or later is required to compile this library."
Compilation error: #include nested too deeply
here’s the error message. I attempted to try a fresh copy of ProffieOS but I get the same result :confused:
That looks like V5.9, which is pretty old.
Here is the latest stable release (7.14):
Also, you’ll need the right plugin for Arduino.
Set up is laid out here:
I’m still having the same issue even with v7.14. Did I do the ino wrong?
 ProffieOS: Control software for lightsabers and other props.
 http://fredrik.hubbe.net/lightsaber/teensy_saber.html
 Copyright (c) 2016-2019 Fredrik Hubinette
 Additional copyright holders listed inline below.
 This program is free software: you can redistribute it and/or modify
 it under the terms of the GNU General Public License as published by
 the Free Software Foundation, either version 3 of the License, or
 (at your option) any later version.
 This program is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 GNU General Public License for more details.
 You should have received a copy of the GNU General Public License
 along with this program.  If not, see <http://www.gnu.org/licenses/>.
|  You can have multiple configuration files, and specify which one |
|  to use here by removing the two slashes at the beginning.        |
|  **NOTE** Only ONE line should be left uncommented at a time!     |
|  Add the slashes to any that you are not using.                   |
#define CONFIG_FILE "config/aniflex_config.h"
// #define CONFIG_FILE "config/default_proffieboard_config.h"
// #define CONFIG_FILE "config/default_v3_config.h"
// #define CONFIG_FILE "config/crossguard_config.h"
// #define CONFIG_FILE "config/graflex_v1_config.h"
// #define CONFIG_FILE "config/prop_shield_fastled_v1_config.h"
// #define CONFIG_FILE "config/owk_v2_config.h"
// #define CONFIG_FILE "config/test_bench_config.h"
// #define CONFIG_FILE "config/toy_saber_config.h"
// #define CONFIG_FILE "config/proffieboard_v1_test_bench_config.h"
// #define CONFIG_FILE "config/proffieboard_v2_testing_config.h"
// #define CONFIG_FILE "config/td_proffieboard_config.h"
// #define CONFIG_FILE "config/proffieboard_v1_graflex.h"
// #define CONFIG_FILE "config/teensy_audio_shield_micom.h"
// #define CONFIG_FILE "config/proffieboard_v2_ob4.h"
// #define CONFIG_FILE "config/testconfig.h"
#ifdef CONFIG_FILE_TEST
#undef CONFIG_FILE
#define CONFIG_FILE CONFIG_FILE_TEST
#ifndef CONFIG_FILE
#error Please set CONFIG_FILE as shown above.
#define CONFIG_TOP
#include CONFIG_FILE
#undef CONFIG_TOP
#ifndef BOOT_VOLUME
#define BOOT_VOLUME VOLUME
#ifdef SAVE_STATE
#define SAVE_VOLUME
#define SAVE_PRESET
#define SAVE_COLOR_CHANGE
#define SAVE_BLADE_DIMMING
#ifdef ENABLE_ALL_EDIT_OPTIONS
#define DYNAMIC_BLADE_LENGTH
#define DYNAMIC_BLADE_DIMMING
#define DYNAMIC_CLASH_THRESHOLD
#define SAVE_VOLUME
#define SAVE_CLASH_THRESHOLD
// #define ENABLE_DEBUG
#ifdef KEEP_SAVEFILES_WHEN_PROGRAMMING
#warning Your config file has KEEP_SAVEFILES_WHEN_PROGRAMMING in it. If you experience problems, please remove it and try again before asking for help. For more information, see: https://pod.hubbe.net/config/keeping-edits-when-uploading.html
// OVERVIEW
// Here explain some general code concepts to make it easier
// to understand the code below.
// Most things start with the ProbBase class. Depending on the
// configuration, this class is extended by the Saber class,
// the Detonator class, or some other class. The extended class
// is instantiated as "prop", and is responsible for handling
// button clicks, clashes, swings and other events. These events
// are then send to all registered SaberBase classes.
// Generally speaking, there are usually two registered SaberBase
// classes listening for events. One for sound and one for
// the blade. Sound and blade effects are generally executed
// separately by separate clases.
// Blades are generally handled by one of the child-classes of
// BladeBase. These classes know how many LEDs the current
// blade has, and how to set those LEDs to a given color, but
// they don't actually decide what the blade should look like.
// Instead they just call the current BladeStyle class and
// asks it to set the colors. The BladeStyle classes don't
// need to know what kind of blade is attached, although
// some combinations of BladeBases and BladeStyles just don't
// make any sense.
// Sounds are also abstracted. It starts with scanning a directory
// on the SD card for files that match known patterns of file names.
// The Effect class is responsible for keeping track of all numbered
// files that for a particular filename prefix.
// Once the directory has been scanned, we'll decide how to play
// sounds. In the past, there was one class for handling NEC style
// fonts and another for handling Plecter style fonts. However,
// both of those have now been merged into the HybridFont class
// which can do both. It is also capable of doing some mix and matching,
// so you can use a plecter style hum together with a NEC style
// swing if you so desire. The HybridFont class inherit from
// SaberBase and listen on on/off/clash/etc. events, just like
// BladeBase classes do.
// HybridFont tells the audio subsystem
// to trigger and mix sounds as aproperiate. The sound subsystem
// starts with an DMA channel which feeds data to a digital-to-analog
// converter. Once the data buffer is half-gone, and interrupt is
// triggered in the DAC class, which tries to fill it up by
// reading data from a int16_t AudioStream. Generally, that data
// stream is hooked up to the AudioDynamicMixer class. This
// class is responsible for taking multiple audio inputs,
// summing them up and then adjusting the volume to minimize
// clipping.
// TODO LIST:
//   stab detect/effect
// Audio work items:
//   select clash from force
//   stab effect
// Blade stuff
//    better clash
// Allow several blades to share power pins.
// If defined, DAC vref will be 3 volts, resulting in louder sound. (teensy only)
#define LOUD
// You can get better SD card performance by
// activating the  USE_TEENSY3_OPTIMIZED_CODE define
// in SD.h in the teensy library, however, my sd card
// did not work with that define.
#include <Arduino.h>
#ifdef TEENSYDUINO
#include <DMAChannel.h>
#include <usb_dev.h>
#ifndef USE_TEENSY4
#include <kinetis.h>
#include <i2c_t3.h>
#else
// This is a hack to let me access the internal stuff..
#define private public
#include <Wire.h>
#undef private
#include <SD.h>
#include <SPI.h>
#ifdef abs
#undef abs
namespace {
template<typename T> constexpr auto abs(T x) -> decltype(-x) { return x < 0 ? -x : x; }
#else // TEENSYDUINO
#define digitalWriteFast digitalWrite
#endif // TEENSYDUINO
#ifdef ARDUINO_ARCH_STM32L4
#include <Wire.h>
#undef private
#include <FS.h>
#include <stm32l4_wiring_private.h>
#include <stm32l4xx.h>
#include <armv7m.h>
#include <stm32l4_gpio.h>
#include <stm32l4_sai.h>
#include <stm32l4_dma.h>
#include <stm32l4_system.h>
#include <arm_math.h>
#include <STM32.h>
#define DMAChannel stm32l4_dma_t
#define DMAMEM
#define NVIC_SET_PRIORITY(X,Y) NVIC_SetPriority((X), (IRQn_Type)(Y))
#else //  ARDUINO_ARCH_STM32L4
#define INPUT_ANALOG INPUT
#endif //  ARDUINO_ARCH_STM32L4
#include <math.h>
#include <malloc.h>
#ifdef ENABLE_SERIALFLASH
#define protected public
#include <SerialFlash.h>
#undef private
#undef protected
#ifdef ENABLE_SNOOZE
#define startup_early_hook DISABLE_startup_early_hook
#include <Snooze.h>
#undef startup_early_hook
SnoozeTimer snooze_timer;
SnoozeDigital snooze_digital;
SnoozeTouch snooze_touch;
SnoozeBlock snooze_config(snooze_touch, snooze_digital, snooze_timer);
const char version[] = "v7.14";
#include "common/common.h"
#include "common/state_machine.h"
#include "common/monitoring.h"
#include "common/stdout.h"
#include "common/errors.h"
Monitoring monitor;
DEFINE_COMMON_STDOUT_GLOBALS;
void PrintQuotedValue(const char *name, const char* str) {
  STDOUT.print(name);
  STDOUT.write('=');
  if (str) {
    while (*str) {
      switch (*str) {
        case '\n':
          STDOUT.print("\\n");
          break;
        case '\t':
          STDOUT.print("\\t");
          break;
        case '\\':
          STDOUT.write('\\');
        default:
          STDOUT.write(*str);
      ++str;
  STDOUT.write('\n');
#ifdef ENABLE_DEBUG
// This class is really useful for finding crashes
// basically, the pin you give it will be held high
// while this function is running. After that it will
// be set to low. If a crash occurs in this function
// it will stay high.
class ScopedPinTracer {
public:
  explicit ScopedPinTracer(int pin) : pin_(pin) {
    pinMode(pin_, OUTPUT);
    digitalWriteFast(pin, HIGH);
  ~ScopedPinTracer() {
    digitalWriteFast(pin_, LOW);
private:
  int pin_;
class ScopedTracer3 {
public:
  explicit ScopedTracer3(int code) {
    pinMode(bladePowerPin1, OUTPUT);
    pinMode(bladePowerPin2, OUTPUT);
    pinMode(bladePowerPin3, OUTPUT);
    digitalWriteFast(bladePowerPin1, !!(code & 1));
    digitalWriteFast(bladePowerPin2, !!(code & 2));
    digitalWriteFast(bladePowerPin3, !!(code & 4));
  ~ScopedTracer3() {
    digitalWriteFast(bladePowerPin1, LOW);
    digitalWriteFast(bladePowerPin2, LOW);
    digitalWriteFast(bladePowerPin3, LOW);
#include "common/scoped_cycle_counter.h"
#include "common/profiling.h"
uint64_t audio_dma_interrupt_cycles = 0;
uint64_t pixel_dma_interrupt_cycles = 0;
uint64_t motion_interrupt_cycles = 0;
uint64_t wav_interrupt_cycles = 0;
uint64_t loop_cycles = 0;
#include "common/loop_counter.h"
#if defined(ENABLE_SSD1306) || defined(INCLUDE_SSD1306)
#define ENABLE_DISPLAY_CODE
#ifdef DOSFS_CONFIG_STARTUP_DELAY
#define PROFFIEOS_SD_STARTUP_DELAY DOSFS_CONFIG_STARTUP_DELAY
#else
#define PROFFIEOS_SD_STARTUP_DELAY 1000
#ifndef CONFIG_STARTUP_DELAY
#define CONFIG_STARTUP_DELAY 0
#if PROFFIEOS_SD_STARTUP_DELAY > CONFIG_STARTUP_DELAY
#define PROFFIEOS_STARTUP_DELAY PROFFIEOS_SD_STARTUP_DELAY
#else
#define PROFFIEOS_STARTUP_DELAY CONFIG_STARTUP_DELAY
#include "common/linked_list.h"
#include "common/looper.h"
#include "common/command_parser.h"
#include "common/monitor_helper.h"
CommandParser* parsers = NULL;
MonitorHelper monitor_helper;
#include "common/vec3.h"
#include "common/quat.h"
#include "common/ref.h"
#include "common/events.h"
#include "common/saber_base.h"
#include "common/saber_base_passthrough.h"
SaberBase* saberbases = NULL;
SaberBase::LockupType SaberBase::lockup_ = SaberBase::LOCKUP_NONE;
SaberBase::ColorChangeMode SaberBase::color_change_mode_ =
  SaberBase::COLOR_CHANGE_MODE_NONE;
bool SaberBase::on_ = false;
uint32_t SaberBase::last_motion_request_ = 0;
uint32_t SaberBase::current_variation_ = 0;
float SaberBase::sound_length = 0.0;
int SaberBase::sound_number = -1;
float SaberBase::clash_strength_ = 0.0;
#ifdef DYNAMIC_BLADE_DIMMING
int SaberBase::dimming_ = 16384;
#include "common/box_filter.h"
// Returns the decimals of a number, ie 12.2134 -> 0.2134
float fract(float x) { return x - floorf(x); }
// clamp(x, a, b) makes sure that x is between a and b.
float clamp(float x, float a, float b) {
  if (x < a) return a;
  if (x > b) return b;
  return x;
float Fmod(float a, float b) {
  return a - floorf(a / b) * b;
int32_t clampi32(int32_t x, int32_t a, int32_t b) {
  return x;
int16_t clamptoi16(int32_t x) {
  return clampi32(x, -32768, 32767);
int32_t clamptoi24(int32_t x) {
  return clampi32(x, -8388608, 8388607);
#include "common/sin_table.h"
void EnableBooster();
void EnableAmplifier();
bool AmplifierIsActive();
void MountSDCard();
const char* GetSaveDir();
#include "common/lsfs.h"
#include "common/strfun.h"
// Double-zero terminated array of search paths.
// No trailing slashes!
char current_directory[128];
const char* next_current_directory(const char* dir) {
  dir += strlen(dir);
  dir ++;
  if (!*dir) return NULL;
  return dir;
const char* last_current_directory() {
  const char* ret = current_directory;
  while (true) {
    const char* tmp = next_current_directory(ret);
    if (!tmp) return ret;
    ret = tmp;
const char* previous_current_directory(const char* dir) {
  if (dir == current_directory) return nullptr;
  dir -= 2;
  while (true) {
    if (dir == current_directory) return current_directory;
    if (!*dir) return dir + 1;
    dir--;
#include "sound/sound.h"
#include "common/battery_monitor.h"
#include "common/color.h"
#include "common/range.h"
#include "common/fuse.h"
#include "common/config_file.h"
#include "blades/blade_base.h"
#include "blades/blade_wrapper.h"
class MicroEventTime {
  void SetToNow() { micros_ = micros(); millis_ = millis(); }
  uint32_t millis_since() { return millis() - millis_; }
  uint32_t micros_since() {
    if (millis_since() > (0xFFFF0000UL / 1000)) return 0xFFFFFFFFUL;
    return micros() - micros_;
private:
  uint32_t millis_;
  uint32_t micros_;
template<class T, class U>
struct is_same_type { static const bool value = false; };
template<class T>
struct is_same_type<T, T> { static const bool value = true; };
// This really ought to be a typedef, but it causes problems I don't understand.
#define StyleAllocator class StyleFactory*
#include "styles/rgb.h"
#include "styles/rgb_arg.h"
#include "styles/charging.h"
#include "styles/fire.h"
#include "styles/sparkle.h"
#include "styles/gradient.h"
#include "styles/random_flicker.h"
#include "styles/random_per_led_flicker.h"
#include "styles/audio_flicker.h"
#include "styles/brown_noise_flicker.h"
#include "styles/hump_flicker.h"
#include "styles/rainbow.h"
#include "styles/color_cycle.h"
#include "styles/cylon.h"
#include "styles/ignition_delay.h"
#include "styles/retraction_delay.h"
#include "styles/pulsing.h"
#include "styles/blinking.h"
#include "styles/on_spark.h"
#include "styles/rgb_cycle.h"
#include "styles/clash.h"
#include "styles/lockup.h"  // Also does "drag"
#include "styles/blast.h"
#include "styles/strobe.h"
#include "styles/inout_helper.h"
#include "styles/inout_sparktip.h"
#include "styles/colors.h"
#include "styles/mix.h"
#include "styles/style_ptr.h"
#include "styles/file.h"
#include "styles/stripes.h"
#include "styles/random_blink.h"
#include "styles/sequence.h"
#include "styles/byteorder.h"
#include "styles/rotate_color.h"
#include "styles/colorchange.h"
#include "styles/transition_pulse.h"
#include "styles/transition_effect.h"
#include "styles/transition_loop.h"
#include "styles/effect_sequence.h"
#include "styles/color_select.h"
#include "styles/remap.h"
#include "styles/edit_mode.h"
// functions
#include "functions/ifon.h"
#include "functions/change_slowly.h"
#include "functions/int.h"
#include "functions/int_arg.h"
#include "functions/int_select.h"
#include "functions/sin.h"
#include "functions/scale.h"
#include "functions/battery_level.h"
#include "functions/trigger.h"
#include "functions/bump.h"
#include "functions/smoothstep.h"
#include "functions/swing_speed.h"
#include "functions/sound_level.h"
#include "functions/blade_angle.h"
#include "functions/variation.h"
#include "functions/twist_angle.h"
#include "functions/layer_functions.h"
#include "functions/islessthan.h"
#include "functions/circular_section.h"
#include "functions/marble.h"
#include "functions/slice.h"
#include "functions/mult.h"
#include "functions/wavlen.h"
#include "functions/wavnum.h"
#include "functions/effect_position.h"
#include "functions/time_since_effect.h"
#include "functions/sum.h"
#include "functions/ramp.h"
#include "functions/center_dist.h"
#include "functions/linear_section.h"
#include "functions/hold_peak.h"
#include "functions/clash_impact.h"
#include "functions/effect_increment.h"
#include "functions/increment.h"
#include "functions/subtract.h"
#include "functions/divide.h"
#include "functions/isbetween.h"
#include "functions/clamp.h"
#include "functions/alt.h"
#include "functions/volume_level.h"
#include "functions/mod.h"
// transitions
#include "transitions/fade.h"
#include "transitions/join.h"
#include "transitions/concat.h"
#include "transitions/instant.h"
#include "transitions/delay.h"
#include "transitions/wipe.h"
#include "transitions/boing.h"
#include "transitions/random.h"
#include "transitions/colorcycle.h"
#include "transitions/wave.h"
#include "transitions/select.h"
#include "transitions/extend.h"
#include "transitions/center_wipe.h"
#include "transitions/sequence.h"
#include "transitions/blink.h"
#include "transitions/doeffect.h"
#include "transitions/loop.h"
#include "styles/legacy_styles.h"
//responsive styles
#include "styles/responsive_styles.h"
#include "styles/pov.h"
class NoLED;
#include "blades/power_pin.h"
#include "blades/drive_logic.h"
#include "blades/pwm_pin.h"
#include "blades/ws2811_blade.h"
#include "blades/fastled_blade.h"
#include "blades/simple_blade.h"
#include "blades/saviblade.h"
#include "blades/sub_blade.h"
#include "blades/dim_blade.h"
#include "blades/leds.h"
#include "blades/blade_id.h"
#include "common/preset.h"
#include "common/blade_config.h"
#include "common/current_preset.h"
#include "common/status_led.h"
#include "styles/style_parser.h"
#include "styles/length_finder.h"
#include "styles/show_color.h"
#include "styles/blade_shortener.h"
BladeConfig* current_config = nullptr;
class BladeBase* GetPrimaryBlade() {
#if NUM_BLADES == 0
  return nullptr;
#else
  return current_config->blade1;
const char* GetSaveDir() {
  if (!current_config) return "";
  if (!current_config->save_dir) return "";
  return current_config->save_dir;
ArgParserInterface* CurrentArgParser;
#define CONFIG_STYLES
#undef CONFIG_STYLES
#define CONFIG_PRESETS
#undef CONFIG_PRESETS
#define CONFIG_PROP
#undef CONFIG_PROP
#ifndef PROP_TYPE
#include "props/saber.h"
PROP_TYPE prop;
#ifdef BLADE_ID_SCAN_MILLIS
bool ScanBladeIdNow() { return prop.ScanBladeIdNow(); }
#if 0
#include "scripts/test_motion_timeout.h"
#warning MOTION TEST SCRIPT ACTIVE
MotionTimeoutScript script;
#if 0
#include "scripts/v3_test_script.h"
#warning !!! V3 TEST SCRIPT ACTIVE !!!
V3TestScript script;
#include "buttons/floating_button.h"
#include "buttons/latching_button.h"
#include "buttons/button.h"
#ifdef TEENSYDUINO
#include "buttons/touchbutton.h"
#include "buttons/stm32l4_touchbutton.h"
#include "buttons/rotary.h"
#include "buttons/pots.h"
#include "ir/ir.h"
#include "ir/receiver.h"
#include "ir/blaster.h"
#include "ir/print.h"
#include "ir/nec.h"
#include "ir/rc6.h"
#include "ir/stm32_ir.h"
#ifndef TEENSYDUINO
uint32_t startup_AHB1ENR;
uint32_t startup_AHB2ENR;
uint32_t startup_AHB3ENR;
uint32_t startup_APB1ENR1;
uint32_t startup_APB1ENR2;
uint32_t startup_APB2ENR;
uint32_t startup_MODER[4];
#define CONFIG_BUTTONS
#undef CONFIG_BUTTONS
#ifdef BLADE_DETECT_PIN
LatchingButtonTemplate<FloatingButtonBase<BLADE_DETECT_PIN>>
    BladeDetect(BUTTON_BLADE_DETECT, BLADE_DETECT_PIN, "blade_detect");
#include "common/sd_test.h"
class I2CDevice;
class Commands : public CommandParser {
 public:
  enum PinType {
    PinTypeFloating,
    PinTypePulldown,
    PinTypeCap,
    PinTypeOther,
  bool TestPin(int pin, PinType t) {
    int ret = 0;
    pinMode(pin, OUTPUT);
    digitalWrite(pin, LOW);
    delayMicroseconds(20);
    ret <<= 1;
    ret |= digitalRead(pin);
    digitalWrite(pin, HIGH);
    ret <<= 1;
    // Discharge time
    pinMode(pin, INPUT_PULLDOWN);
    uint32_t start = micros();
    uint32_t end;
    while (digitalRead(pin)) {
      end = micros();
      if (end - start > 32768) break; // 32 millis
    ret <<= 16;
    ret |= (end - start);
    pinMode(pin, INPUT_PULLUP);
    ret <<= 1;
    pinMode(pin, INPUT);
    return ret;
  bool Parse(const char* cmd, const char* e) override {
    if (!strcmp(cmd, "ls")) {
      char tmp[128];
      SerialFlashChip::opendir();
      uint32_t size;
      while (SerialFlashChip::readdir(tmp, sizeof(tmp), size)) {
        STDOUT.print(tmp);
        STDOUT.print(" ");
        STDOUT.println(size);
      STDOUT.println("Done listing files.");
      return true;
    if (!strcmp(cmd, "rm")) {
      if (SerialFlashChip::remove(e)) {
        STDOUT.println("Removed.\n");
      } else {
        STDOUT.println("No such file.\n");
      return true;
    if (!strcmp(cmd, "format")) {
      STDOUT.print("Erasing ... ");
      SerialFlashChip::eraseAll();
      while (!SerialFlashChip::ready());
      STDOUT.println("Done");
      return true;
#ifdef ENABLE_SD
#ifndef DISABLE_DIAGNOSTIC_COMMANDS
    if (!strcmp(cmd, "dir")) {
      LOCK_SD(true);
      if (!e || LSFS::Exists(e)) {
        for (LSFS::Iterator dir(e ? e : ""); dir; ++dir) {
          STDOUT.print(dir.name());
          STDOUT.print(" ");
          STDOUT.println(dir.size());
      } else {
        STDOUT.println("No such directory.");
      LOCK_SD(false);
      return true;
    if (!strcmp(cmd, "cat") && e) {
      LOCK_SD(true);
      File f = LSFS::Open(e);
      while (f.available()) {
        STDOUT.write(f.read());
      f.close();
      LOCK_SD(false);
      return true;
    if (!strcmp(cmd, "del") && e) {
      LOCK_SD(true);
      LSFS::Remove(e);
      LOCK_SD(false);
      return true;
#ifdef ENABLE_DEVELOPER_COMMANDS
    if (!strcmp(cmd, "readalot")) {
      uint8_t tmp[10];
      LOCK_SD(true);
      for (int i = 0; i < 10000; i++) {
        f.seek(0);
        f.read(tmp, 10);
        f.seek(1000);
        f.read(tmp, 10);
      f.close();
      LOCK_SD(false);
      return true;
#endif // ENABLE_DEVELOPER_COMMANDS
    if (!strcmp(cmd, "sdtest")) {
      SDTestHelper sdtester;
      if (e && !strcmp(e, "all")) {
	sdtester.TestDir("");
      } else {
	sdtester.TestFont();
      return true;
#endif  // ENABLE_SD
#if defined(ENABLE_SD) && defined(ENABLE_SERIALFLASH)
    if (!strcmp(cmd, "cache")) {
      LOCK_SD(true);
      if (!f) {
        STDOUT.println("File not found.");
        return true;
      int bytes = f.size();
      if (!SerialFlashChip::create(e, bytes)) {
        STDOUT.println("Not enough space on serial flash chip.");
        return true;
      SerialFlashFile o = SerialFlashChip::open(e);
      while (bytes) {
        char tmp[256];
        int b = f.read(tmp, min(bytes, (int)NELEM(tmp)));
        o.write(tmp, b);
        bytes -= b;
      LOCK_SD(false);
      STDOUT.println("Cached!");
      return true;
    if (!strcmp(cmd, "effects")) {
      Effect::ShowAll();
      return true;
#if 0
    if (!strcmp(cmd, "df")) {
      STDOUT.print(SerialFlashChip::capacity());
      STDOUT.println(" bytes available.");
      return true;
    if (!strcmp(cmd, "high") && e) {
      pinMode(atoi(e), OUTPUT);
      digitalWrite(atoi(e), HIGH);
      STDOUT.println("Ok.");
      return true;
    if (!strcmp(cmd, "low") && e) {
      digitalWrite(atoi(e), LOW);
      return true;
#if VERSION_MAJOR >= 4
    if (!strcmp(cmd, "booster")) {
       if (!strcmp(e, "on")) {
         digitalWrite(boosterPin, HIGH);
         STDOUT.println("Booster on.");
         return true;
       if (!strcmp(e, "off")) {
         digitalWrite(boosterPin, LOW);
         STDOUT.println("Booster off.");
         return true;
#ifdef ENABLE_AUDIO
#if 0
    if (!strcmp(cmd, "ton")) {
      EnableAmplifier();
      dac.SetStream(&saber_synth);
      saber_synth.on_ = true;
      return true;
    if (!strcmp(cmd, "tof")) {
      saber_synth.on_ = false;
      return true;
    if (!strcmp(cmd, "dumpwav")) {
      int16_t tmp[32];
      wav_players[0].Stop();
      wav_players[0].read(tmp, NELEM(tmp));
      wav_players[0].Play(e);
      for (int j = 0; j < 64; j++) {
        int k = wav_players[0].read(tmp, NELEM(tmp));
        for (int i = 0; i < k; i++) {
          STDOUT.print(tmp[i]);
          STDOUT.print(" ");
        STDOUT.println("");
      return true;
    if (!strcmp(cmd, "dumpwavplayer")) {
      for (size_t i = 0; i < NELEM(wav_players); i++) {
        if (e && atoi(e) != (int)i) continue;
        wav_players[i].dump();
      return true;
    if (!strcmp(cmd, "sleep") && e) {
      delay(atoi(e));
      return true;
    if (!strcmp(cmd, "twiddle")) {
      int pin = strtol(e, NULL, 0);
      STDOUT.print("twiddling ");
      STDOUT.println(pin);
      for (int i = 0; i < 1000; i++) {
        delay(10);
        delay(10);
      STDOUT.println("done");
      return true;
    if (!strcmp(cmd, "twiddle2")) {
        for (int i = 0; i < 500; i++) {
          delayMicroseconds(1);
        delay(10);
      return true;
    if (!strcmp(cmd, "malloc")) {
      STDOUT.print("alloced: ");
      STDOUT.println(mallinfo().uordblks);
      STDOUT.print("Free: ");
      STDOUT.println(mallinfo().fordblks);
      return true;
    if (!strcmp(cmd, "make_default_console")) {
      default_output = stdout_output;
      return true;
#if 0
    // Not finished yet
    if (!strcmp(cmd, "selftest")) {
      struct PinDefs { int8_t pin; PinType type; };
      static PinDefs pin_defs[]  = {
        { bladePowerPin1, PinTypePulldown },
        { bladePowerPin2, PinTypePulldown },
        { bladePowerPin3, PinTypePulldown },
        { bladePowerPin4, PinTypePulldown },
        { bladePowerPin5, PinTypePulldown },
        { bladePowerPin6, PinTypePulldown },
        { bladePin,       PinTypeOther },
        { blade2Pin,      PinTypeFloating },
        { blade3Pin,      PinTypeFloating },
        { blade4Pin,      PinTypeFloating },
        { blade5Pin,      PinTypeFloating },
        { amplifierPin,   PinTypeFloating },
        { boosterPin,     PinTypeFloating },
        { powerButtonPin, PinTypeFloating },
        { auxPin,         PinTypeFloating },
        { aux2Pin,        PinTypeFloating },
        { rxPin,          PinTypeOther },
        { txPin,          PinTypeFloating },
      for (size_t test_index = 0; test_index < NELEM(pin_defs); test_index++) {
        int pin = pin_defs[test_index].pin;
        for (size_t i = 0; i < NELEM(pin_defs); i++)
          pinMode(pin_defs[i].pin, INPUT);
        // test
        for (size_t i = 0; i < NELEM(pin_defs); i++) {
          pinMode(pin_defs[i].pin, OUTPUT);
          digitalWrite(pin_defs[i].pin, HIGH);
          // test
          digitalWrite(pin_defs[i].pin, LOW);
          // test
    if (!strcmp(cmd, "top")) {
#ifdef TEENSYDUINO
      if (!(ARM_DWT_CTRL & ARM_DWT_CTRL_CYCCNTENA)) {
        ARM_DEMCR |= ARM_DEMCR_TRCENA;
        ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
        STDOUT.println("Cycle counting enabled, top will work next time.");
        return true;
      if (!(DWT->CTRL & DWT_CTRL_CYCCNTENA_Msk)) {
        CoreDebug->DEMCR |= 1<<24; // DEMCR_TRCENA_Msk;
        DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
        return true;
      // TODO: list cpu usage for various objects.
      float total_cycles =
        (float)(audio_dma_interrupt_cycles +
	        pixel_dma_interrupt_cycles +
		motion_interrupt_cycles +
                 wav_interrupt_cycles +
		 Looper::CountCycles() +
		 CountProfileCycles());
      STDOUT.print("Audio DMA: ");
      STDOUT.print(audio_dma_interrupt_cycles * 100.0f / total_cycles);
      STDOUT.println("%");
      STDOUT.print("Wav reading: ");
      STDOUT.print(wav_interrupt_cycles * 100.0f / total_cycles);
      STDOUT.print("Pixel DMA: ");
      STDOUT.print(pixel_dma_interrupt_cycles * 100.0f / total_cycles);
      STDOUT.print("LOOP: ");
      STDOUT.print(loop_cycles * 100.0f / total_cycles);
      STDOUT.print("Motion: ");
      STDOUT.print(motion_interrupt_cycles * 100.0f / total_cycles);
      STDOUT.print("Global loops / second: ");
      global_loop_counter.Print();
      STDOUT.println("");
      STDOUT.print("High frequency loops / second: ");
      hf_loop_counter.Print();
      STDOUT.println("");
      SaberBase::DoTop(total_cycles);
      Looper::LoopTop(total_cycles);
      DumpProfileLocations(total_cycles);
      noInterrupts();
      interrupts();
      return true;
    if (!strcmp(cmd, "version")) {
      STDOUT << version
      << "\n" CONFIG_FILE "\nprop: "  TOSTRING(PROP_TYPE)  "\nbuttons: " TOSTRING(NUM_BUTTONS) "\ninstalled: "
      << install_time << "\n";
      return true;
    if (!strcmp(cmd, "reset")) {
#ifdef TEENSYDUINO
      SCB_AIRCR = 0x05FA0004;
      STM32.reset();
      STDOUT.println("Reset failed.");
      return true;
    if (!strcmp(cmd, "shutdown")) {
      STDOUT.println("Sleeping 10 seconds.\n");
      STM32.stop(100000);
      return true;
    if (!strcmp(cmd, "RebootDFU")) {
      stm32l4_system_dfu();
      return true;
    if (!strcmp(cmd, "dumpfusor")) {
      fusor.dump();
      return true;
    if (!strcmp(cmd, "stm32info")) {
      STDOUT.print("VBAT: ");
      STDOUT.println(STM32.getVBAT());
      STDOUT.print("VREF: ");
      STDOUT.println(STM32.getVREF());
      STDOUT.print("TEMP: ");
      STDOUT.println(STM32.getTemperature());
      return true;
    if (!strcmp(cmd, "i2cstate")) {
      extern void DumpI2CState();
      DumpI2CState();
      SaberBase::DumpMotionRequest();
      return true;
    if (!strcmp(cmd, "portstates")) {
      GPIO_TypeDef *GPIO;
      for (int i = 0; i < 4; i++) {
        switch (i) {
          case 0:
            GPIO = (GPIO_TypeDef *)GPIOA_BASE;
            STDOUT.print("PORTA: ");
            break;
          case 1:
            GPIO = (GPIO_TypeDef *)GPIOB_BASE;
            STDOUT.print("PORTB: ");
            break;
          case 2:
            GPIO = (GPIO_TypeDef *)GPIOC_BASE;
            STDOUT.print("PORTC: ");
            break;
          case 3:
            GPIO = (GPIO_TypeDef *)GPIOH_BASE;
            STDOUT.print("PORTH: ");
            break;
        for (int j = 15; j >= 0; j--) {
          uint32_t now = (GPIO->MODER >> (j * 2)) & 3;
          uint32_t saved = (startup_MODER[i] >> (j * 2)) & 3;
          STDOUT.print((now == saved ? "ioga" : "IOGA")[now]);
          if (!(j & 3)) STDOUT.print(" ");
        STDOUT.print("  ");
          uint32_t now = (GPIO->PUPDR >> (j * 2)) & 3;
          STDOUT.print("-ud?"[now]);
        STDOUT.print("  ");
          uint32_t now = ((GPIO->IDR >> j) & 1) | (((GPIO->ODR >> j) & 1) << 1);
          STDOUT.print("lhLH"[now]);
        STDOUT.print("  ");
	  int afr = 0xf & (GPIO->AFR[j >> 3] >> ((j & 7) * 4));
          STDOUT.print("0123456789ABCDEF"[afr]);
        STDOUT.println("");
      return true;
    if (!strcmp(cmd, "CLK")) {
      if (e) {
        uint32_t c = atoi(e) * 1000000;
        stm32l4_system_sysclk_configure(c, c/2, c/2);
      STDOUT.print("Clocks: hse=");
      STDOUT.print(stm32l4_system_hseclk());
      STDOUT.print(" lse=");
      STDOUT.print(stm32l4_system_lseclk());
      STDOUT.print(" sys=");
      STDOUT.print(stm32l4_system_sysclk());
      STDOUT.print(" f=");
      STDOUT.print(stm32l4_system_fclk());
      STDOUT.print(" h=");
      STDOUT.print(stm32l4_system_hclk());
      STDOUT.print(" p1=");
      STDOUT.print(stm32l4_system_pclk1());
      STDOUT.print(" p2=");
      STDOUT.print(stm32l4_system_pclk2());
      STDOUT.print(" sai=");
      STDOUT.println(stm32l4_system_saiclk());
      return true;
    if (!strcmp(cmd, "whatispowered")) {
      STDOUT.print("ON: ");
#define PRINTIFON(REG, BIT) do {                                        \
        if (RCC->REG & RCC_##REG##_##BIT##EN) {                         \
          STDOUT.print(" " #BIT);                                       \
          if (!(startup_##REG & RCC_##REG##_##BIT##EN)) STDOUT.print("+"); \
      } while(0)
      PRINTIFON(AHB1ENR,FLASH);
      PRINTIFON(AHB1ENR,DMA1);
      PRINTIFON(AHB1ENR,DMA2);
      PRINTIFON(AHB2ENR,GPIOA);
      PRINTIFON(AHB2ENR,GPIOB);
#ifdef GPIOC_BASE
      PRINTIFON(AHB2ENR,GPIOC);
#ifdef GPIOD_BASE
      PRINTIFON(AHB2ENR,GPIOD);
#ifdef GPIOE_BASE
      PRINTIFON(AHB2ENR,GPIOE);
#if defined(STM32L476xx) || defined(STM32L496xx)
      PRINTIFON(AHB2ENR,GPIOF);
      PRINTIFON(AHB2ENR,GPIOG);
      PRINTIFON(AHB2ENR,GPIOH);
#if defined(STM32L496xx)
      PRINTIFON(AHB2ENR,GPIOI);
      PRINTIFON(AHB2ENR,ADC);
      PRINTIFON(APB1ENR1,DAC1);
      PRINTIFON(AHB2ENR,OTGFS);
#else
      PRINTIFON(APB1ENR1,USBFS);
      PRINTIFON(APB2ENR,USART1);
      PRINTIFON(APB1ENR1,USART2);
#if defined(STM32L433xx) || defined(STM32L476xx) || defined(STM32L496xx)
      PRINTIFON(APB1ENR1,USART3);
      PRINTIFON(APB1ENR1,UART4);
      PRINTIFON(APB1ENR1,UART5);
      PRINTIFON(APB1ENR2,LPUART1);
      PRINTIFON(APB1ENR1,I2C1);
      PRINTIFON(APB1ENR1,I2C2);
      PRINTIFON(APB1ENR1,I2C3);
      PRINTIFON(APB1ENR2,I2C4);
      PRINTIFON(APB2ENR,SPI1);
      PRINTIFON(APB1ENR1,SPI2);
      PRINTIFON(APB1ENR1,SPI3);
      PRINTIFON(APB1ENR1,CAN1);
      PRINTIFON(APB1ENR1,CAN2);
      PRINTIFON(AHB3ENR,QSPI);
      PRINTIFON(APB2ENR,SDMMC1);
      PRINTIFON(APB2ENR,SAI1);
      PRINTIFON(APB2ENR,SAI2);
      PRINTIFON(APB2ENR,DFSDM1);
      PRINTIFON(APB2ENR,TIM1);
      PRINTIFON(APB1ENR1,TIM2);
#ifdef TIM3_BASE
      PRINTIFON(APB1ENR1,TIM3);
#ifdef TIM4_BASE
      PRINTIFON(APB1ENR1,TIM4);
#ifdef TIM5_BASE
      PRINTIFON(APB1ENR1,TIM5);
      PRINTIFON(APB1ENR1,TIM6);
#ifdef TIM7_BASE
      PRINTIFON(APB1ENR1,TIM7);
#ifdef TIM8_BASE
      PRINTIFON(APB2ENR,TIM8);
      PRINTIFON(APB2ENR,TIM15);
      PRINTIFON(APB2ENR,TIM16);
      PRINTIFON(APB2ENR,TIM17);
      PRINTIFON(APB1ENR1,LPTIM1);
      PRINTIFON(APB1ENR2,LPTIM2);
      // Not sure what CPUs implement these
      PRINTIFON(AHB1ENR, CRC);
      PRINTIFON(AHB1ENR, TSC);
      PRINTIFON(AHB2ENR, RNG);
#ifdef LCD_BASE
      PRINTIFON(APB1ENR1, LCD);
      PRINTIFON(APB1ENR1, RTCAPB);
      PRINTIFON(APB1ENR1, WWDG);
      PRINTIFON(APB1ENR1, CRS);
      PRINTIFON(APB1ENR1, CAN1);
      PRINTIFON(APB1ENR1, PWR);
      PRINTIFON(APB1ENR1, OPAMP);
#ifdef SWPMI1_BASE
      PRINTIFON(APB1ENR2, SWPMI1);
      PRINTIFON(APB2ENR, SYSCFG);
      PRINTIFON(APB2ENR, FW);
      STDOUT.println("");
      STDOUT.print("VBUS: ");
      STDOUT.println(stm32l4_gpio_pin_read(GPIO_PIN_PB2));
      STDOUT.print("USBD connected: ");
      STDOUT.println(USBD_Connected());
      return true;
#ifdef HAVE_STM32L4_DMA_GET
    if (!strcmp(cmd, "dmamap")) {
      for (int channel = 0; channel < 16; channel++) {
	stm32l4_dma_t *dma = stm32l4_dma_get(channel);
	if (dma) {
	  STDOUT.print(" DMA");
	  STDOUT.print( 1 +(channel / 8) );
	  STDOUT.print("_CH");
	  STDOUT.print( channel % 8 );
	  STDOUT.print(" = ");
	  STDOUT.println(dma->channel >> 4, HEX);
      return true;
#endif // HAVE_STM32L4_DMA_GET
    return false;
StaticWrapper<Commands> commands;
#include "common/serial.h"
#if defined(ENABLE_MOTION) || defined(ENABLE_DISPLAY_CODE)
#include "common/i2cdevice.h"
I2CBus i2cbus;
#ifdef ENABLE_SSD1306
#include "display/ssd1306.h"
#ifndef DISPLAY_POWER_PINS
#define DISPLAY_POWER_PINS PowerPINS<>
StandardDisplayController<128, uint32_t> display_controller;
SSD1306Template<128, uint32_t, DISPLAY_POWER_PINS> display(&display_controller);
#ifdef INCLUDE_SSD1306
#ifdef ENABLE_MOTION
#include "motion/motion_util.h"
#include "motion/mpu6050.h"
#include "motion/lsm6ds3h.h"
#include "motion/fxos8700.h"
#include "motion/fxas21002.h"
// Define this to record clashes to sd card as CSV files
// #define CLASH_RECORDER
#ifdef GYRO_CLASS
// Can also be gyro+accel.
StaticWrapper<GYRO_CLASS> gyroscope;
#ifdef ACCEL_CLASS
StaticWrapper<ACCEL_CLASS> accelerometer;
#endif   // ENABLE_MOTION
#include "sound/amplifier.h"
#include "common/sd_card.h"
#include "common/booster.h"
void setup() {
#define SAVE_RCC(X) startup_##X = RCC->X
  SAVE_RCC(AHB1ENR);
  SAVE_RCC(AHB2ENR);
  SAVE_RCC(AHB3ENR);
  SAVE_RCC(APB1ENR1);
  SAVE_RCC(APB1ENR2);
  SAVE_RCC(APB2ENR);
#define SAVE_MODER(PORT, X) startup_MODER[X] = ((GPIO_TypeDef *)GPIO##PORT##_BASE)->MODER
  SAVE_MODER(A, 0);
  SAVE_MODER(B, 1);
  SAVE_MODER(C, 2);
  SAVE_MODER(H, 3);
  // TODO enable/disable as needed
  pinMode(boosterPin, OUTPUT);
  Serial.begin(115200);
  // TODO: Figure out if we need this.
  // Serial.blockOnOverrun(false);
  // Wait for all voltages to settle.
  // Accumulate some entrypy while we wait.
  uint32_t now = millis();
  while (millis() - now < PROFFIEOS_STARTUP_DELAY) {
#ifndef NO_BATTERY_MONITOR
    srand((rand() * 917823) ^ LSAnalogRead(batteryLevelPin));
    // Figure out if blade is connected or not.
    // Note that if PROFFIEOS_STARTUP_DELAY is smaller than
    // the settle time for BladeDetect, this won't work properly.
    BladeDetect.Warmup();
  SerialFlashChip::begin(serialFlashSelectPin);
#ifdef ENABLE_SD
  bool sd_card_found = LSFS::Begin();
  if (!sd_card_found) {
    if (sdCardSelectPin >= 0 && sdCardSelectPin < 255) {
      STDOUT.println("No sdcard found.");
      pinMode(sdCardSelectPin, OUTPUT);
      digitalWrite(sdCardSelectPin, 0);
      delayMicroseconds(2);
      pinMode(sdCardSelectPin, INPUT);
      if (digitalRead(sdCardSelectPin) != HIGH) {
        STDOUT.println("SD select not pulled high!");
    stm32l4_gpio_pin_configure(GPIO_PIN_PA5,   (GPIO_PUPD_PULLUP | GPIO_OSPEED_HIGH | GPIO_MODE_INPUT));
    delayMicroseconds(10);
    if (!stm32l4_gpio_pin_read(GPIO_PIN_PA5)) {
      STDOUT.println("SCK won't go high!");
    stm32l4_gpio_pin_configure(GPIO_PIN_PA5,   (GPIO_PUPD_PULLDOWN | GPIO_OSPEED_HIGH | GPIO_MODE_INPUT));
    if (stm32l4_gpio_pin_read(GPIO_PIN_PA5)) {
      STDOUT.println("SCK won't go low!");
  } else {
    STDOUT.println("Sdcard found..");
  Looper::DoSetup();
  // Time to identify the blade.
  prop.FindBlade();
  SaberBase::DoBoot();
  if (!sd_card_found) ProffieOSErrors::sd_card_not_found();
#endif // ENABLE_SD
#ifdef MTP_RX_ENDPOINT
void mtp_yield() { Looper::DoLoop(); }
void mtp_lock_storage(bool lock) {
  AudioStreamWork::LockSD(lock);
#include "mtp/mtpd.h"
MTPD mtpd;
#ifdef ENABLE_SD
#include "mtp/mtp_storage_sd.h"
MTPStorage_SD sd_storage(&mtpd);
#include "mtp/mtp_storage_serialflash.h"
MTPStorage_SerialFlash serialflash_storage(&mtpd);
#endif  // MTP_RX_ENDPOINT
#include "common/clock_control.h"
void loop() {
  mtpd.loop();
  Looper::DoLoop();
#define CONFIG_BOTTOM
#undef CONFIG_BOTTOM
#define PROFFIEOS_DEFINE_FUNCTION_STAGE
Did you install the Arduino plug in?
I also prefer to leave out underscores so you could turn aniflex_config.h to aniflexconfig.h in the original file and in the ino.
I went ahead and removed the underscore and yes I installed the plugin when I pasted the URL into preferences and installed it within board manager and set the tools tab to use proffieboard v2 and set the port as well as changed the USB type to Serial + mass storage + webUSB. Still same compilation error though
This is correct.
The underscore is fine. It’s spaces that are not recommended.
This all sounds right.
That doesn’t make sense though. Post your config file and the error.
Here is my config, I only have one soundfont on it to start for the sake of simplicity
#include "aniflexconfig.h"
#define VOLUME 1600
and here is my error message:
In file included from C:\Users\chris\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\config\aniflexconfig.h:2,
                 from C:\Users\chris\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\ProffieOS.ino:57:
C:\Users\chris\OneDrive\Desktop\ProffieOS-v7.14\ProffieOS\config\aniflexconfig.h:2:27: error: #include nested too deeply
    2 | #include "aniflexconfig.h"
This is wrong.
It should include files which specify what kind of board it is, something like:
or
DUDE thank you so much it’s working now. All I gotta do now is fix the saber from turning itself off from gesture controls. If you have any advice for that I’d be thankful but you’ve helped a ton already
I love the twist on but hate the twist off.
Ha, I hate twist on love twist off :slight_smile:
Set up for this and so much more here:
awesome, It seemed to work but one of my wires snapped off makes the saber light up so now I gotta figure out soldering to fix it. Thank you all for your help!
