Hi all,
Brand new here and obviously a noob to Proffie!
I am building my first saber and I have a V3.9 board ready to go.
I am keeping it as simple as possible!
Illuminated PCB from TCSS.
2 anti vandal illuminated switches.
Speaker.
Custom quad core blade that I made with 117 Leds per strip.
I used the config generator on Frank’s site to start and ran into a compilation error related to the button config section. “Power” and “aux” not defined.
This is what Frank’s generator gave me:
#define NUM_BLADES 5
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
#define SHARED_POWER_PINS
StyleFirePtr<RED, YELLOW, 1>(),
StyleFirePtr<RED, YELLOW, 2>(),
StyleFirePtr<RED, YELLOW, 3>(),
StyleFirePtr<RED, YELLOW, 4>(), "fire"},
StyleNormalPtr<RED, WHITE, 300, 800>(),
StyleFirePtr<BLUE, CYAN, 0>(),
StyleFirePtr<BLUE, CYAN, 1>(),
StyleFirePtr<BLUE, CYAN, 2>(),
StyleFirePtr<BLUE, CYAN, 3>(),
StyleFirePtr<BLUE, CYAN, 4>(), "blue fire"},
StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >(),
StyleNormalPtr<WHITE, RED, 300, 800, RED>(),
StyleNormalPtr<AudioFlicker<YELLOW, WHITE>, BLUE, 300, 800>(),
{ "SmthGrey", "tracks/venus.wav",
StylePtr<InOutSparkTip<EASYBLADE(MAGENTA, WHITE), 300, 800> >(),
{ "SmthFuzz", "tracks/mars.wav",
StyleNormalPtr<Gradient<RED, BLUE>, Gradient<CYAN, YELLOW>, 300, 800>(),
{ "RgueCmdr", "tracks/mercury.wav",
StyleRainbowPtr<300, 800>(),
{ "TthCrstl", "tracks/uranus.wav",
StyleStrobePtr<WHITE, Rainbow, 15, 300, 800>(),
&style_pov,
StyleNormalPtr<BLACK, BLACK, 300, 800>(), "POV"},
&style_charging,
{ 0, WS281XBladePtr<117, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, blade5Pin, -1, -1, -1>(),
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, blade6Pin, -1, -1, -1>()
, CONFIGARRAY(presets) },
Button PowerButton(BUTTON_POWER, power, "pow");
Button AuxButton(BUTTON_AUX, aux, "aux");
With the help of Fett’s site I replaced the config button section with this and got it to compile properly:
This has made me doubt Franks generator and specifically the blade config section.
Why does it have this as my blade config and a num value of 5 for blades?
Does this look correct for what I selected as buttons, PCB etc?
I want to solder this board correct the first time so thank you in advance for reading through this.
I also have issues with adding styles to the config but I’ll wait on that!
