Then it should just be a matter of cutting the part that sticks out shorter.
For through-hole connections, push the insulation all the way up to the board and solder on the other side. No goose necks.
I HAVE DONE IT!!! I know what the problem was! It was the blade pcb the whole time! I rigged up my saber and some alligator clips o have to the long neopixel strip I have. Clipped positive, negative and data to the right places and Walla! The strip light up no problem!! So it looks I need a different blade pcb from a different company. The ones I have are from the custom saber shop and now I know they donāt work with this kind of saber. So does anyone have any suggestions for blade pcbs? But thank you all so much for all the help and support! I wouldnāt not have come to this conclusion if I didnāt know what I was looking for! Thank you again and maybe not get blade pcbs from the custom saber shop ![]()
Or maybe, get hilt side pcb and blade side pcb from the same shop & same manufacturer & make sure the versions are compatible?
I am happy for you that you figured it out. If any more problems (hopefully not) or questions, please come back anytime. We will be happy to assist.
The KR hilt side and TCSS blade side PCB are compatible. I think what you discovered is that you got a short in the blade, which didnāt happen in the clip test. Clean up that PCB and you might be fine. Regardless, itās a win ![]()
I would agree yes! Okay I will definitely get it more cleaned than before. I was also wondering about the pcb, I know I donāt need a resistor, but would I need to bridge the resistor pads on the pcb?
Yes. You can do it with just solder, or use an LED leg or resistor leg you clip. Without it thereās no data flow to the strips.
Shown here (2:09):
The Custom Saber Shop is a well-known, long-time-running, and reputable store.
Whatever issues you had, were they actually due to the hardware you purchased, if you reached out Iām sure they would rectify it.
Respectfully: Making backhand comments about such a company when there was no attempt at resolution with them and clearly a lot of user error is in poor taste.
I have done it!! It works!!! And @ryryog25 yes I agree, it was all user error. Custom saber shops pcb had nothing to do with it. Was just me forgetting a step as I usually do. But the blade is working!! I finally got it to light up and it is awesome!! It looks like I was missing the bridged resistor pads the whole time, I feel like an idiot but itās fixed! I do have a small question thou. I did notice when I ignite my blade, it lights at the top first and then the bottom comes to meet it. Do I need to check my blade wiring or check the configuration? But thank you all so much for all the help! Iām very grateful for all of it!
Time to post you config again please ![]()
like this
@LyleStyle, you got it. Its just the simple one from earlier.
#define NUM_BLADES 2
#define NUM_BUTTONS 1
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
{ 0,
SubBlade(30, 141, WS281XBladePtr<142, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>()),
SubBlade(0, 29, NULL),
CONFIGARRAY(presets),
Well, thereās nothing in there that is telling the LEDs to do that that I can see. The problem IMO is still mechanical. Maybe a bad LED from the old wiring.
Iād test another blade, but since it seems you only have this one you could do a test on another strip, or finish the full blade and test that.
I actually did finish the full blade and itās behaving like that. I will have to check the wiring then, the strip works fine, I tested it before putting it in the blade with my arduino and a simple test sketch for it. So, I will go over everything in the blade and see if I can find the issue.
Quick update, the blade still works! and I was able to fix my previous problem with the top of the blade lighting first. It was the actual code! I checked the wiring and everything was fine. So here is the original code that had that was making it do that.
{ 0,
so here is the code that I replaced it with, this is the code that I got from the proffie with a bit modifications.
SubBlade(0, 15, WS281XBladePtr<16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >()),
SubBlade(1, 15, NULL),
it works, but it has a bit of a glitch, when it ignites, itās as if it has two ignitions, one at the base and then the rest of the blade. all the other effects just fine but that. I wonder if it has something to do with the number of blades. I was able to edit the blade length with edit mode thanks to the fett263 upgrade. But not the base where it was is now a bit dimmer than the rest of the blade. So, I am unsure how to edit the config so it all acts as one smooth blade. If anyone has any tips or tricks or even a config that I can just plug in let me know! thank you guys again!
You have two WS281XBladePtr<> that use the same pin.
That does not actually work, and is probably what is causing your glitches.
