Just finished my second Proffieboard saber. Everything works great but there is no sound. I’ve tried several speakers and am mostly confident that I have it wired correctly (though I might still be an idiot). Nonetheless, I still get no sound. Below is the config file I’ve been working with. It’s a slightly modified version of what I got from the configurator, though I’ve had the same problem using the vanilla configurator config. I’ve tried everything I can think of on the computer side including using a different computer and an older version of Arduino IDE (V 1.8.3). Is there anything else I might be missing or is it a hardware issue.
I apologize if there is an obvious mistake or if I’m repeating a previous post. Thanks
#define NUM_BLADES 5
#define NUM_BUTTONS 1
#define VOLUME 1000
#define CLASH_THRESHOLD_G 3.5
#define ENABLE_SSD1306
#define SHARED_POWER_PINS
#define ENABLE_SERIAL
StyleNormalPtr<RED, WHITE, 300, 800>(),
StyleFirePtr<RED, YELLOW, 1>(),
StyleFirePtr<RED, YELLOW, 2>(),
StyleFirePtr<RED, YELLOW, 3>(),
StyleFirePtr<RED, YELLOW, 4>(), "fire"},
StyleFirePtr<BLUE, CYAN, 0>(),
StyleFirePtr<BLUE, CYAN, 1>(),
StyleFirePtr<BLUE, CYAN, 2>(),
StyleFirePtr<BLUE, CYAN, 3>(),
StyleFirePtr<BLUE, CYAN, 4>(), "blue fire"},
StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >(),
StyleNormalPtr<WHITE, RED, 300, 800, RED>(),
StyleNormalPtr<AudioFlicker<YELLOW, WHITE>, BLUE, 300, 800>(),
{ "SmthGrey", "tracks/venus.wav",
StylePtr<InOutSparkTip<EASYBLADE(MAGENTA, WHITE), 300, 800> >(),
{ "SmthFuzz", "tracks/mars.wav",
StyleNormalPtr<Gradient<RED, BLUE>, Gradient<CYAN, YELLOW>, 300, 800>(),
{ "RgueCmdr", "tracks/mercury.wav",
StyleRainbowPtr<300, 800>(),
{ "TthCrstl", "tracks/uranus.wav",
StyleStrobePtr<WHITE, Rainbow, 15, 300, 800>(),
&style_pov,
StyleNormalPtr<BLACK, BLACK, 300, 800>(), "POV"},
&style_charging,
WS281XBladePtr<8, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin4, bladePowerPin5> >(),
WS281XBladePtr<2, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >()
, CONFIGARRAY(presets) },
