Hi!
I’m running into a strange case on a Proffie v3.9 board with touch buttons set up and a few additional Neopixel strips and accent LEDs.
Upon boot it repeatedly triggers the blade removal sound and what looks like the Proffie rebooting.
Below is the full config that I have flashed which triggers the constant reboots.
This was flashed with ProffieOS 7.10 on Proffieboard v3.9
#define NUM_BLADES 6
#define NUM_BUTTONS 3
#define BLADE_DETECT_PIN blade2Pin
#define SHARED_POWER_PINS
#define VOLUME 50
#define SAVE_STATE
#define CLASH_THRESHOLD_G 5.0
#define ORIENTATION_ROTATION 0,20,0
#define FETT263_SWING_ON
#define FETT263_SWING_ON_SPEED 400
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
#define FILTER_CUTOFF_FREQUENCY 50
#define FILTER_ORDER 8
"Dark;common", "",
// Main blade
/* copyright Fett263 DarkSaber (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#DarkSaber
OS6.7 v4.021
Base Style: Live Action Darksaber (Hyper-Responsive)
Base Color: Rgb<100,100,150> (0)
PowerUp Effect: Power Surge (Stable)
Retraction Effect: SparkTip Retraction
Melt Effect: Intensity Melt
Stab Effect: Normal Stab
Blast Effect: Responsive Blast Wave (Sound Based)
Clash Effect: Real Clash V1
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<400>,Scale<SwingAcceleration<>,Int<2000>,Int<4000>>,Int<8000>>,HumpFlicker<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Stripes<35000,-200,Mix<Int<14000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<24000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<28000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,100>,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>,TransitionEffectL<TrConcat<TrInstant,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrFade<1200>>,EFFECT_IGNITION>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<WavLen<>>,TrWipeIn<200>>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrWipe<1000>>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>(),
// Chassis accent Pixel strips
/* copyright Fett263 (Accent LED / PCB) OS6 Style
OS6.7 v4.021
On Behavior: AudioFlicker (Single Color)
Off Behavior: Fast Pulse Dim-On
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<100,100,150>>>>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrWipeInX<RetractionTime<0>>,Pulsing<Mix<Int<8192>,Black,RgbArg<OFF_COLOR_ARG,Rgb<100,100,150>>>,RgbArg<OFF_COLOR_ARG,Rgb<100,100,150>>,2000>>>>(),
OS6.7 v4.021
// Control card white accents
OS6.7 v4.021
Off Behavior: Off
Base Color: Rgb<255,255,255> (0)
StylePtr<Layers<AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,255,255>>>>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
OS6.7 v4.021
Off Behavior: Off
OS6.7 v4.021
Off Behavior: Off
"dark"
template<int ohms = 70>
struct TwoWhiteAccents {
static constexpr float MaxAmps = 0.01;
static constexpr float MaxVolts = 3.0;
static constexpr float P2Amps = 0.0079;
static constexpr float P2Volts = 3.15;
static constexpr float R = ohms;
static const int Red = 255;
static const int Green = 255;
static const int Blue = 255;
WS281XBladePtr<136, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>(),
SubBladeReverse(0, 4, WS281XBladePtr<5, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin5>>()),
SubBladeReverse(0, 4, WS281XBladePtr<5, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5>>()),
DimBlade(20, SimpleBladePtr<TwoWhiteAccents<140>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>()),
DimBlade(20, SimpleBladePtr<TwoWhiteAccents<140>, NoLED, NoLED, NoLED, bladePowerPin4, -1, -1, -1>()),
DimBlade(20, SimpleBladePtr<TwoWhiteAccents<140>, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>()),
CONFIGARRAY(presets)
TouchButton PowerButton(BUTTON_POWER, powerButtonPin, 1700, "pow");
TouchButton AuxButton(BUTTON_AUX, auxPin, 1700, "aux");
TouchButton Aux2Button(BUTTON_AUX2, aux2Pin, 1700, "aux2");
Here’s the serial monitor output showing that it’s constantly rebooting
Activating polyphonic font.
Activating SmoothSwing V2
Accent Swings Enabled.
Polyphonic swings: 16
Monophonic swings: 0
Accent Slashes NOT Detected:
unit = 0 vol = 0.50, Playing Dark/boot/boot1.wav
EVENT: SeActivating polyphonic font.
unit = 0 vol = 0.50, Playing common/bladeout.wav
Welcome to ProffieOS v7.8
EVENT: Select-On millis=4369
blade = 0
WS2811 Blade with 136 leds.
WS2811 Blade with 5 leds.
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
Scanning sound font: Dark done
Scanning sound font: common done
unit = 0 vol = 0.50, Playing common/bladein.wav
EVENT: Select-Off millis=4547
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
Amplifier off.
EVENT: Select-On millis=5557
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=5722
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=6058
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=6238
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=6646
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=6817
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=7319
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=7499
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=7860
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=8014
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=8353
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=8507
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=8666
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=8848
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
Amplifier off.
EVENT: Select-On millis=9853
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=10021
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-On millis=10552
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
EVENT: Select-Off millis=10708
blade = 0
Simple Blade
Simple Blade
Simple Blade
Style RAM = 1464
Style RAM = 132
Style RAM = 132
Style RAM = 104
Style RAM = 104
Style RAM = 104
... ad nauseum
I have tried a few variations of this
Attempt: Simplifying down to 1 WS281XBladePtr blade and 1 TouchButton
Result: Proffie boots up with blade removal sound and gesture controls are non-responsive. I’m going to guess here that Fett263’s gesture sleep kicked in pausing gesture controls when blade detect doesn’t detect a blade -
Attempt: Change TouchButton to regular Button
Result: No issues. Saber does not boot with blade removal sound and does not constantly reboot. Gesture controls are functional, presumably because gesture sleep didn’t kick in yet -
Attempt: Downgrading to Proffie OS7.7
Result: Same behaviour with constant reboots -
Attempt: Desolder blade1Pin and blade2Pin
Attempt: Test on another Proffieboard v3.9 with only speaker wired up
Result: Exact same behaviour without anything else wired up
I can run a few more tests and post the results here such as attempting on a new Proffieboard v2.2 as well as isolating out the accent Neopixel strips and the accent LEDs.
I’ve done a few similar installs with TouchButtons and accent LEDs (not Neopixel accent strips for those installs) on Proffieboard v2.2 and haven’t encountered this issue.
