And heres the test config:
// ProffieOS7 Config File
#define NUM_BLADES 2
#define NUM_BUTTONS 1
#define VOLUME 1000
#define BOOT_VOLUME 800
#define CLASH_THRESHOLD_G 3
#define FILTER_CUTOFF_FREQUENCY 320
#define FILTER_ORDER 8
#define FETT263_RANDOMIZE_QUOTE_PLAYER
{ "Ahsoka;common", "Ahsoka/tracks/tracks2.waw",
https://fett263.com/fett263-proffieOS7-style-library.html#Rotoscope
OS7.12 v1.017-p
Base Color: BaseColorArg (0)
PowerUp Effect: Power Flash [Color: IgnitionColorArg]
Retraction Effect: Fade Out [Color: RetractionColorArg]
Lockup Effect: Intensity Lockup V1, Begin Effect: Full Blade Flash, End Effect: Full Blade Absorb [Color: LockupColorArg]
Clash Effect: Flash on Clash (Full Blade) [Color: ClashColorArg]
Battery Level: Full Blade (Green to Red)
Battery Monitor: Passive Battery Monitor (Boot)
Power Save: 25% Increment
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<238,255,0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<300>>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrFadeX<BendTimePowInvX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>,EffectSequence<EFFECT_POWERSAVE,AlphaL<Black,Int<8192>>,AlphaL<Black,Int<16384>>,AlphaL<Black,Int<24576>>,AlphaL<Black,Int<0>>>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,Mix<BatteryLevel,Red,Green>,TrFade<300>>,EFFECT_BATTERY_LEVEL>,TransitionEffectL<TrConcat<TrJoin<TrDelay<2000>,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BOOT>>>(),
/* copyright Fett263 Rotoscope (Accent LED / PCB) OS7 Style
OS7.12 v1.017-p
Off Behavior: Off [Color: OffColorArg]
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,InOutTrL<TrInstant,TrInstant,Black>>>(),
"preset0"
struct UltraSabersStarWhiteTemplate {
static constexpr float MaxAmps = 1.0;
static constexpr float MaxVolts = 3.7;
static constexpr float P2Amps = 0.7;
static constexpr float P2Volts = 3.5;
static constexpr float R = 0;
// LED color
static const int Red = 255;
static const int Green = 255;
static const int Blue = 255;
struct UltraSabersStarRedTemplate {
static constexpr float MaxVolts = 2.6;
static constexpr float P2Volts = 2.4;
// LED color
static const int Green = 0;
static const int Blue = 0;
struct UltraSabersStarGreenTemplate {
static constexpr float MaxVolts = 4.5;
static constexpr float P2Volts = 4.2;
// LED color
static const int Red = 0;
struct UltraSabersStarBlueTemplate {
// LED color
struct AccentBlue {
static constexpr float MaxAmps = 0.015;
static constexpr float MaxVolts = 2.8;
static constexpr float P2Amps = 0.012;
static constexpr float P2Volts = 2.5;
// LED color
struct UltraSabersStarWhite : public UltraSabersStarWhiteTemplate {};
struct UltraSabersStarRed : public UltraSabersStarRedTemplate { typedef UltraSabersStarWhite SUBTRACT; };
struct UltraSabersStarGreen : public UltraSabersStarGreenTemplate { typedef UltraSabersStarWhite SUBTRACT; };
struct UltraSabersStarBlue : public UltraSabersStarBlueTemplate { typedef UltraSabersStarWhite SUBTRACT; };
{ 0, SimpleBladePtr<UltraSabersStarRed, UltraSabersStarBlue, UltraSabersStarGreen, UltraSabersStarWhite,
bladePowerPin1, bladePowerPin2, bladePowerPin3, bladePowerPin4>(),
SimpleBladePtr<AccentBlue, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(),
CONFIGARRAY(presets) },
/* Generated with Fett263 Config Helper v3.0 */
