Hi, I have built this one button crossguard saber, but recently it’s been playing up and seemingly getting stuck in colour change mode. Pressing the power button should select the colour and exit the menu, but it is not. It is also very difficult to trigger the retraction of the saber (hold power button, or twist). What might be the issue here?
The controls in the prop for color change are 4 clicks with the blade parallel or down and one click to select (long click to revert and not change). Watching your video, I see what you mean that it appears stuck. You can watch on a serial monitor to see what it’s doing since the prop prints out each button event and “Color change mode done” when you exit. Is it possible you’re in edit mode? When off and double click and hold you go into edit mode. From there you have to hold power to go back to the main menu and then hold power again to exit (or rotate to exit and click).
If you’re in edit mode but not hearing the menu prompts, it might point to missing files in your voicepack. If this doesn’t solve it, you might post your config here so we can take a look and help you further.
Yep, that’s one of NoSloppy’s and no issue there. It should have all the sounds you need. Serial is the best next step. If you can’t figure it out you can post what you’re seeing here.
I had a look at the serial monitor and it all seemed fine, but the saber wasn’t playing up this time, it seems to be an intermittent fault.
I know it sounds a bit fudged, but I use some tape to insulate the board from the hilt itself - however sometimes the tape will get worn through in certain places. One of these places is the Button1 pad. Do you think this could be causing the issue, rather than a software issue?
I had a short from button one’s pad to the little chip next to it behind blade power pins 4 and 5 that caused a bunch of wacky stuff, including stuck on color change. Desoldering, wicking, and resoldering the button connection fixed it!
Ok, thanks for all the advice - I reinforced the tape and extended it slightly to ensure the whole board is insulated. This seems to have done the trick, hopefully no more problems now. Thanks again!
