My proffie board will not allow me to use the usb connection without battery power supplied while using the usb cabe. I have tried different cables, different laptops and reprograming with os6.7 and os6.8 same results, the board works when powered without the usb attached just cannot communicate over usb connection by itself I have attached the last programing competion any ideas thanks for the help
c:/users/hfsiudhf/appdata/local/arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\hfsiudhf\AppData\Local\Arduino15\packages\proffieboard\hardware\stm32l4\3.6.0\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2' not declared
Sketch uses 188424 bytes (71%) of program storage space. Maximum is 262144 bytes.
dfu-util 0.9
ID 0483:df11
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
dfuERROR, clearing status
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 188432
Download [=========================] 100% 188432 bytes
Download done.
File downloaded successfully
