Hey there. First time user of Proffie board.
I’m one of the suckers that bought an Ultrasabers neopixel proffie lite… I know, I should have done my research first. ![]()
I’m having trouble with it turning itself on/on rapidly or simply stops responding and locks up.
It seems like a loose wire as sometimes it works fine. and if I pull the chassis out it fixes it sometimes. So, if I have to take it apart to find the problem, I might as well replace the controller while I’m at it. So, I purchased a Proffie V3.9.
Will I have to change any resistors to the led’s or neopixel data pins? It has a single RGB momentary power button and the pixel blade.
I’d like to add a USB-C charge port. From what I’ve read. I should be able to add a panel mount USB-C Charging port to the Vbus and Gnd pins on the board. Is this correct?
Like this one:
Amazon.com: DWEII 10PCS Type-C Female Chassis Waterproof 2P Solder Wire Type USB C Pigtail Cable Extension Power Cable USB-C Plug to 2 Pin Bare Wire Open End Connector : Electronics -
Do I have to have a kill switch? I’d rather not have to cut another hole in the hilt.
Lastly, are there any tips on how to disassemble the saber? It’s a Guardian model.
I appreciate any help!
Thanks.
