I got my Arcann saber with proffie. I modified 2 headers in the config file. I wanted to keep it simple. I changed the time from 5 to 1, and I enabled the Twist_off mode as it came disabled.
I attempted to compile the code, and it fails. It gave the following error message:
Arduino: 1.8.3 (Linux), Board: “Proffieboard V3, Serial + WebUSB, SDCARD (SDIO High Speed), 80 MHz, Smallest Code”
Build options changed, rebuilding all
Archiving built core (caching) in: /tmp/arduino_cache_647500/core/core_proffieboard_stm32l4_ProffieboardV3-L452RE_usb_cdc_webusb,dosfs_sdmmc1,speed_80,opt_os_8bc9da3b26ece0906ca36c1bc523688a.a
/home/aguil/.arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld:/home/aguil/.arduino15/packages/proffieboard/hardware/stm32l4/3.6.0/variants/STM32L452RE-ProffieboardV3/linker_scripts/STM32L452RE_FLASH.ld:224: warning: memory region `SRAM2’ not declared
/home/aguil/.arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld: warning: changing start of section .bss by 8 bytes
fork/exec /home/aguil/.arduino15/packages/proffieboard/hardware/stm32l4/3.6.0/tools/linux//dfu-suffix: no such file or directory
It’s looking for a directory, but as far as I know, I installed everything needed.
Do you know what the problem might be? Any suggestions are welcomed.
The issue is with your plugin install.
I would start with quit Arduino, delete the /home/aguilarluis/.arduino15 folder, reinstall the plugin under Arduino menu Tools>Board>Boards Manager.
@NoSloppy Hi! I just tried the newest version of Arduino (2.2.1) and it didn’t work. I got the same error message. I even added the URL which you suggested in addition to the one that’s required, and no success
