Wanted to save this for posterity, in case anything happens where this is posted elsewhere. This prop file for my EE3 Blaster was created for Beta Testing the Proffie Blaster functionality, and indeed wound up installed into a commission.
Here it is:
#include "proffieboard_v1_config.h"
#define NUM_BLADES 2
#define VOLUME 2000
#define CLASH_THRESHOLD_G 1.0
#define DELAYED_OFF
#define ENABLE_BLASTER_AUTO
#include "../props/blaster.h"
// Default basic blast color with red audio flicker on blast
{ "blstr1", "tracks/fates.wav",
StylePtr<Lockup<BlastFadeout<BlastFadeout<Black,AudioFlicker<Black,Red>,250,EFFECT_FIRE>,AudioFlicker<Black,Blue>,1500,EFFECT_STUN>,AudioFlicker<Black,Red>>>(),
{"bank1","tracks/credits.wav",
{"bank2","tracks/swars.wav",
{"bank3","tracks/fates.wav",
{"bank4","tracks/march.wav",
{"bank5","tracks/credits.wav",
{"bank6","tracks/swars.wav",
template<int milliohms = 1200>
struct CreeXPE2DRedTemplate {
static constexpr float MaxAmps = 1.0;
static constexpr float MaxVolts = 2.5;
static constexpr float P2Amps = 0.35;
static constexpr float P2Volts = 2.1;
static constexpr float R = milliohms / 1000.0;
static const int Red = 255;
static const int Green = 0;
static const int Blue = 0;
struct CreeXPE2DRed2Template {
static const int Red = 0;
static const int Green = 255;
template<int milliohms = 300>
struct CreeXPE2RBlueTemplate {
static constexpr float MaxVolts = 3.4;
static constexpr float P2Volts = 3.1;
static const int Blue = 255;
{ 0, SimpleBladePtr<CreeXPE2DRedTemplate<1200>, CreeXPE2DRed2Template<1200>,CreeXPE2BlueTemplate<300>, NoLED>(),
WS2811BladePtr<14, WS2811_800kHz | WS2811_GRB, blade2Pin, PowerPINS<bladePowerPin6>>(),
CONFIGARRAY(presets) },
#endif ```
