I’ve been trying out the motion controls with my proffie saber, and have found that they are extremely finnicky. I have spent the last half hour trying and failing to go into color change mode (I’ve done it quite a few times just hours earlier) to no avail. It’s extremely irritating. Therefore, I want to try and get my saber to control similarly to an RGB saber (i.e. holding the button down for 2 seconds enters color change mode). I also would like white to show up in color change mode, instead of getting skipped over. Where would I go to change the cycle of color change mode?
Controls are all dependent on which prop file you are using, especially how colorchange works.
Which are you using?
Currently, the base controls that come with an LGT one button proffieboard. I was just wondering if I could change the controls to have a button-based variant (i.e. hold button down for 2 seconds while the blade is on to change color). Color change is currently done by pointing the blade down, holding the button, and twisting. I’ve done it before, but I can’t seem to really get the hang of it.
Yes but you need to edit the prop file, which is why I asked which one you’re using. In your config file there’s a #ifdef CONFIG_PROP
section with the prop file name.
If you post your config, we can help further if you need.
