I’m new to proffie, and ran into a problem trying to verify the config file on Arduino. I followed a tutorial on youtube and i believe i followed every step. I am using mac. When i try to verify, it shows this error:
fork/exec /Users/(myname)/Library//Arduino15/packages/proffieboard/tools/arm-none-eabi-gcc/12-3-rel1/bin/arm-none-eabi-g++: no such file or directory
Error compiling for board Proffieboard V2
I haven’t added any fonts or changed blade styles. I have not seen anyone else with this exact error. Does someone know what could be the issue here?
Hello Loeroe, Goedeavond ! (no I don’t speak Dutch - well just a little)
Welcome to the the Crucible.
So first of, you need to edit and delete the photo of the screenshot. It is not appreciated here. You may not be able to edit your post as a new user, but you will after you post a few times. It will need to be deleted if you want proffezorn help.
Second, better if you copy/paste the whole error (text format) message here.
To post, used 3 back ticks “`” before and after your error code.
Like this:
You errors here, check "Raw post" for formatting
You can aslo use the same format to post your config or you can attach it as a file too.
Now about your error, I believe it is a problem with your Proffieboard Arduino Plugin. Newest version 4.1.0 was just released today. Do you have it installed in Arduino (or at least the previous version 3.6.0) ? The plugin is either not there or not installed correctly.
