Proffie Battery Drain
Hello there! I have a proffie core from Darkwolf LGT that is having some problems. I uploaded a new config and noticed the battery starts draining very quickly, even when the saber is turned off. No kill switch with this chassis. The area around the proffie board almost feels like it’s building up heat with the battery in. This happened with one of my other proffie cores and it ended up toasting the board so I had to send it back. Could this be an issue with my config file? Or possibly a wiring issue? Any ideas would be appreciated!
Here is a link to the config file I used: #ifdef CONFIG_TOP#include "proffieboard_v2_config.h"#define NUM_BLADES 1#d - Pastebin.com
Don’t see anything weird in your config file. For wiring issues you’re going to have to talk to Darkwolf or LGT directly.
