Presets.ini on ProffieOS v6
Hey, I think I’m on 6.8 but I want to edit the presets.ini and I’m having a hard time finding the details of how to edit the presets.ini in that version on a windows box. I downloaded the unlock_presets_ini.py.
Use Edit Mode or ProffieOS Workbench to edit presets.ini for OS6 or later.
ProffieOS 6.x doesn’t do anything interesting to the presets.ini file, it’s just a text file and you can use a text editor to make changes. unlock_presets_ini.py is not required for ProffieOS 6.x
More information here:
the preset.ini had some weird characters.
I was using the edit mode and I copied a whole heap of presets and just wanted to remove it. could you explain how the delete preset works, I tried to delete it in edit mode and clicked save but it was still there. is there anything else I need to do for the delete to take effect after you select the accept.
Delete preset should just delete the preset you’re currently viewing, that’s it.
