Presets.ini EDIT MODE currupting?
I’m curious, has anyone ever had their EDIT MODE act up, and generate a presets ini line that looks like this?
style=builtin 0 1 30324,0,49768 11102,92,53864 2 -1828312037 2046883269 1176148761 17976,63486,65460 -251090687 17976,45059,59581 63487,64509,17926 6857,59376,63701 -134239743 45664,37633,59853 151056463 17152,63686,13240 62016,6176,62146 845478040 64203,26792,61496 -120205047 53756,62016,4896 1142228226 44729,39441,26704 -1190496094 -1694257421 -787987037 -121487104 -410711552 26914,45362,37389 -230677504 58751,40453,58760 62146,2048,63168 -1660079579 46260,46260,65535 0,0,65535
I was going through the EDIT COLOR menu, setting a few colors, then suddenly the blade started acting strangely. When I took the SD card out and put the presets ini through the converter, it showed the font I was editing saved this as the style settings. Many of these numbers are far larger then they should be…
I’ve had it happen with two fonts in the past 2 days, both while using EDIT MODE’s EDIT COLOR menu, using Proffie OS 7.14.
I’ve used EDIT MODE for months with no issue. This is on a ProffieBoard v2.2, where I usually use it on a Proffieboard v3.9. Does that make a diff? Still, I was able to edit a couple dozen blade styles on it using EDIT MODE with no issues, until yesterday.
Obviously this shouldn’t happen.
I guess the tricky question is if we can nail down if there is one particular interaction that makes this happen…
What version of arduino-proffieboard do you have?
One possibility is something simply running out of RAM memory. (Not the same as flash memory)
The 3.9 has much more memory, so it wouldn’t happen there.
Audrino 2.3.3, Proffieboard 3.6
I’ll have to try to make a bare-bones test install and see if i can repro it in an isolated case that’s simple.
My Proffie OS is v7.14, but it has a few specific edits from post 7.14 added in:
Commit IDs:
932404a6bec5f78c393ddffd106c6cdd197fb5c5 - Fix defines.
fabfc0c234edfc89dc8b431f2cfc17ea24855c29 - 3677203ce3ebaf9c60a406294059125000621fa4 for Int_Select.h
