Currently using 1.5 G value sometimes find certain effects are hard to trigger such as drag. Curious to see what others are setting
It depends on the hilt. Usually around 2.5ish.
Not just hilt.
You have to then factor in volume level and whether or not you’re using AudioSuppression.
Take your time tuning it, one step at a time to find what works best.
Sabertrio Senza with Swappable Core
#define VOLUME 2300
#define CLASH_THRESHOLD_G 4
#define AUDIO_CLASH_SUPPRESSION_LEVEL 5
Also there’s blade type, which can determine how hard you want to hit it.
KR Pixel V2 showblade, 1.0
Pixel Strip Battle Blade, 2.5
1.0 recommend for the pixel strip? Thats what i have
I think the words “pixel strip” are confusing ![]()
If the strip is a pcb, like the KR, I use lower numbers for lighter impacts. If it’s two flexible strips back to back in a thick blade tube, I bump it up to hit harder.
