I’ve found on specifically “dyadKylo” something is causing clashes to register after retracting the saber, the baselit led will flash white every time i hit or swing the saber, although if i revert it to os6 it doesn’t happen for me.
I’m also finding since going to os7 I’ve been unable to deactivate motion controls as well, it will either goes to volume menu or change presets
If I remember correctly, we changed clash events in OS7 so that they would occur even if the saber is turned off. Normally, this wouldn’t show anything because the in/out layer would cover it up.
I’m not sure why it’s showing through in your case though.
I looked at the style, and it seems fine.
Are you sure it’s the “dyadKylo” style that has the problem?
What does the serial monitor say when this happens?
Disabling motion control sounds like a @Fett263 issue…
I don’t think it’s a clash (you can check in the Serial Monitor).
I can’t replicate on a neopixel, so might specific to baselit? I “think” it’s something with TrWipeInSparkTipX or TrWipeSparkTipX or the EFFECT_POSTOFF transition layer but can’t replicate on my blade and I don’t own any baselit sabers.
@profezzorn, maybe one of the changes to transitions is keeping the SparkTip or the TrConcat in his EFFECT_POSTOFF active somehow?
Side note, I forgot to submit EFFECT_OFF_CLASH support in my prop previously so just submitted PR to get it added in. This effect is not present in the style and it isn’t currently active anywhere in the OS so I don’t think it could be involved, plus the InOutTrL layer covers his EFFECT_CLASH layer in his style with Black (and there’s no clash sounds in his demo video).
after some testing it also occurs on the presets “inquisitoriusRed” and “Magnetic” the first seems to be a copy and paste, the second though seems to be slightly different, just going off the number at the start of the bladestyle.
As far as I can recall almost all of the bladestyles including this one was made in the fett263 style creator, I remember trying to find a slow ripple on your site, It ended up being slow power ripple I think.
Well, it looks like I can reproduce this on the “Magnetic” preset at least.
Now I just need to figure out why.
The inout layer is a bit weird and complicated, maybe that’s why…
after attempting to apply the settings I got this error about my accent LED’s
In file included from C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\ProffieOS.ino:607:
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h:213:5: error: 'WS281XBladePtr' was not declared in this scope; did you mean 'SaviBladePtr'?
213 | WS281XBladePtr<5, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
| SaviBladePtr
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h:213:73: error: expected primary-expression before '>' token
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h:213:75: error: expected primary-expression before ')' token
Compilation error: 'WS281XBladePtr' was not declared in this scope; did you mean 'SaviBladePtr'?
Hm maybe I had something go corrupt, I’ll re-download the master and try again
Quick edit: It was indeed a corrupted file it passed perfectly this time
after uploading the config my cree has no lights, not sure why, I did add a bunch of the new os7 effects, I’ll drop my config.
(so far I’ve just reverted back to os6 to make sure I didn’t have a disconnected wire and it lit up, gonna experiment and see if any of the defines caused it) FlagshipConfigOS7.h (101.2 KB)
Ops, turns out my “fix” made the problem go away by simply breaking SimpleBlade… I guess that’s what I get for trying to fix bugs late at night…
Will report back once I have a better fix.
hm, no changes to my config but i’m getting a scopedpintracer error
I have redownloaded the zip in case of a corruption but same issue
In file included from C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\ProffieOS.ino:568:
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\blades\pwm_pin.h: In function 'void {anonymous}::LSanalogWriteSetup(uint32_t)':
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\blades\pwm_pin.h:95:3: error: 'ScopedPinTracer' was not declared in this scope
95 | ScopedPinTracer pt(blade3Pin);
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h: At global scope:
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h:214:5: error: 'WS2811BladePtr' was not declared in this scope; did you mean 'SaviBladePtr'?
214 | WS2811BladePtr<5, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin1> >(),
| SaviBladePtr
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h:214:73: error: expected primary-expression before '>' token
C:\Users\jamer\Desktop\Proffie\ProffieOS7.X Alpha\ProffieOS\config\FlagshipConfigOS7.h:214:75: error: expected primary-expression before ')' token
Compilation error: 'ScopedPinTracer' was not declared in this scope
