Every time I try to upload my config I get “Error opening serial port ‘COM4’. (Port busy)” I have uploaded the config multiple times before. Someone has suggested it might be my computer. If so I have a less than a month old Lenovo Legion 5.
c:/users/jacob/documents/arduinodata/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\Jacob\Documents\ArduinoData\packages\proffieboard\hardware\stm32l4\3.6.0\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region `SRAM2' not declared
Sketch uses 239288 bytes (91%) of program storage space. Maximum is 262144 bytes.
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2061)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM4'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
Error opening serial port 'COM4'. (Port busy)
That’s a new one… just to give you something to try until smarter minds weigh in, did you try swapping USB ports on the computer? Also, you’re going straight into the computer right? No hubs? Lastly, did you try restarting the computer?
Very annoying hahahaa, I have 4 separate ports that I have used, all the same outcome and I’ve used hubs, no hubs, different cables. The works! Restarted my computer, re installed arduino
I, literally a half hour ago, solved a hellacious issue that had been bugging me for almost a month. And by solved, I mean it randomly resolved itself out of the blue, with no indication of what I did to solve it. So trust me, I both feel your pain and am eager to see your overcome it.
Try forcing bootloader mode (2 buttons push). Ignore not being able to select a port after that and just upload anyway. Any luck?
If the port is busy, then some other program is talking to it.
Do you have other devices on your system that has COM ports?
I recommend using a hub, that protects your computer from any shorts or other crap that could happen in your saber.
You don’t need to run zadig. You can just do BOOT+RESET and then hit upload.
(The reason running zadig works is because after you do that, the board is in bootloader mode, not because you ran zadig.)
It’s allowing me to upload after I put it through zadig and use a different port each time, I just did it and got the error directly after
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: “Proffieboard V2, Serial + WebUSB, SDCARD (SPI), 80 MHz, Smallest Code”
c:/users/jacob/documents/arduinodata/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe:C:\Users\Jacob\Documents\ArduinoData\packages\proffieboard\hardware\stm32l4\3.6.0\variants\STM32L433CC-ProffieboardV2/linker_scripts/STM32L433CC_FLASH.ld:224: warning: memory region SRAM2’ not declared
c:/users/jacob/documents/arduinodata/packages/proffieboard/tools/arm-none-eabi-gcc/9-2020-q2-update/bin/…/lib/gcc/arm-none-eabi/9.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: warning: changing start of section .bss by 24 bytes
Sketch uses 180944 bytes (69%) of program storage space. Maximum is 262144 bytes.
dfu-util 0.9
Please report bugs to dfu-util / Tickets
Opening DFU capable USB device…
ID 0483:df11
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
dfuERROR, clearing status
dfuIDLE, continuing
Downloading to address = 0x08000000, size = 180952
Download [=========================] 100% 180952 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state Cannot open DFU device 0483:df11 processing.app.SerialException: Error opening serial port ‘COM4’.
at processing.app.Serial.(Serial.java:152)
at processing.app.Serial.(Serial.java:82)
at processing.app.SerialMonitor$2.(SerialMonitor.java:132)
at processing.app.SerialMonitor.open(SerialMonitor.java:132)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:132)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2126)
at processing.app.Editor.access$1300(Editor.java:116)
at processing.app.Editor$UploadHandler.run(Editor.java:2095)
at java.lang.Thread.run(Thread.java:748)Caused by: jssc.SerialPortException: Port name - COM4; Method name - openPort(); Exception type - Port not found.
at jssc.SerialPort.openPort(SerialPort.java:167)
at processing.app.Serial.(Serial.java:141)
… 8 moreError opening serial port ‘COM4’.
After a couple of successful uploads on multiple board I’m getting the same errors again, I thought it might be anti virus or firewall intercepting it while uploading but I turned that all off and I’m still getting the error. I can upload after I run it through zadig again!
