I have recently purchased a lightsaber from Ultra Sabers and have added some fonts that come with balde styles; however, I don’t know how to get the blade styles to work or to get them on my board. Ultra Sabers uses ultraproffie lite. Can soemone please help me?
Fett263
September 16, 2025, 10:54pm
2
Unfortunately, UltraSabers is not a real Proffieboard, so nobody here will really be able to help you.
I would inquire about a refund and get a real Proffieboard from a reputable saber company, then we can easily help you.
I’ve just received an email from ultrasabers and in the specs they are listing this:
Ease of use: Simple, single button and gesture-controlled on-board settings menu allows you to adjust blade brightness, color, sound, sensitivity, volume, and more straight from the saber without the use of morse code style button presses, or the need for a second button.
More in your saber: Easily cycle through 25 preloaded sound & blade color profiles without connecting to a computer, and easily add your own by connecting to our browser based app, up to a total of 99!
Smooth swing, tip drag, all-new ignition and deactivation effects, new lockup, blaster block, wall melt, blaster mode, force lightning and so so so much more- all baked right in.
Advanced sensitivity controls for every single motion your saber is capable of.
Switch your Ultrasaber into Stealth-Mode for around 1/3rd of the power output, to extend your saber’s battery life.
No need for a kill-key. UltraProffie features a Deep-Sleep Mode to keep your battery from dying while not in use.
Upgraded from a 2watt to a 3watt speaker.
Built in USB recharge port on each soundboard.
Auto-power-off at timeout and low battery.
100% Compatible with any existing Proffie Profiles.
Battle-ready: Between the factory-mounted chassis, protective resin and on-board electrical protections, the UltraProffie soundboard is more reliable for combat than boards soldered on a printed chassis available through other sabersmiths.
Better availability: Ultrasabers has taken strides to position ourselves to make those boards. Many other boards on the market are either delayed or slow to release due to semiconductor supply problems. We took measures to avoid such situations.
Have they gone ahead and implemented a 3.7?
MFBoom
September 17, 2025, 2:23pm
3
Any other companies or brands that sell lightsabers with Proffie like this, so I know not to buy from them or just get an empty hilt?
Knew UltraSabers cut corners in a lot of places, so that’s why I never got anything from them, but this??? Not even what you pay for…
