Slightly unusual one - I have a relatively simple blade style intended to achieve the Kestis colour changing effect using the EFFECT_USERx feature. Effect user is linked in the prop to a swing/button press combination.
It works great to achieve the colour changes, however when it gets to the last colour, that’s it - it doesn’t wrap back to the first colour on the next swing. The only way to reset it is by switching away from that font and then back to it.
It’s not a deal-breaker, but I guess my question is, can it be set to wrap back to the start, and if so, where would that get done - in the prop or in the bladestyle, or somewhere else in the OS?
Thanks in advance. Relevant code extracts below:
Prop file:
case EVENTID(BUTTON_NONE, EVENT_SWING, MODE_ON | BUTTON_POWER):
SaberBase::DoEffect(EFFECT_USER1, 0);
return true;
Blade style:
StylePtr<Layers<
Layers<
ColorSelect<AltF,TrFade<300>,Green,Rgb<147,0,255>,Yellow,Cyan,Magenta,Orange,Azure,Red,Rgb<128,0,128>,DeepSkyBlue>,
ColorSelect<AltF,TrFade<300>,RandomL<Rgb<0,125,0>>,RandomL<Rgb<70,0,125>>,RandomL<Rgb<125,125,0>>,RandomL<Rgb<0,125,125>>,RandomL<Rgb<125,0,125>>,RandomL<Rgb<125,49,0>>,RandomL<Rgb<110,125,125>>,RandomL<Rgb<125,0,0>>,RandomL<Rgb<64,0,64>>,RandomL<Rgb<0,75,125>>>,
TransitionEffectL<TrDoEffectX<TrInstant,EFFECT_ALT_SOUND,ModF<Sum<AltF,Int<1>>,Int<10>>>,EFFECT_USER1>,
OriginalBlastL<White>,
LockupL<Strobe<Azure,Black,20,16>,Strobe<White,Black,20,16>>,
ResponsiveMeltL<Mix<TwistAngle<>,Red,Yellow>,TrInstant,TrInstant>,
SimpleClashL<Strobe<White,Black,28,25>,260>,
InOutTrL<TrWipe<500>,TrWipeInX<WavLen<EFFECT_RETRACTION>>>,
TransitionEffectL<TrConcat<TrWipe<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<BatteryLevel,Int<-10>>>,TrWipeIn<1000>>,EFFECT_BATTERY_LEVEL>>>>(),
