Other color displays?
I have worked with the color displays so I know proffie os supports 4 different ones right now.
I assume this is a technical reason. Is it possible to support other displays?
I found this little guy and think it would be good for some projects like blaster scopes.
https://www.aliexpress.us/item/3256805407977104.html
It is definitely possible to support other displays, but it may take some work, depending on protocols, chips, etc. The four supported ones are simply the ones that I have tested.
This display uses a different family of chips from the other color screens we support, so it may require more work than other screens, but I’m fairly certain it is possible. It’s just a matter of reading the data sheet and/or the Adafruit code for this display and then add the required commands to the ProffieOS code.
Displays that use the same chips that we already support are easier; it’s just a matter of putting together the right display definition, which is fairly easy. (And about 10 lines of code.)
gotcha. So something with the ST7735 (or ST7789 according to adafruit) would be easier?
Something like this?:
https://www.aliexpress.us/item/3256809897412406.html
Yep, that one will most likely be pretty easy to get to work.
Just copy this: (714-728)
change the size, then see if it works.
It may need rotation, shifting and/or color order adjustments, but those should be fairly easy to figure out.
I am getting ready to try this out (as well as 2 other displays) and I have a question about connecting the pins…
In the configurator and here: Color display progress - #18 by profezzorn
the listed the pin connections for the eyespi are:
EYESPI PBV3 function
TCS GND Chip Select
RST no connect Reset
DC Free3 Command Select
MISO no connect
MOSI Data3 Data
SCK Free1 Clock
Gnd GND power
Lite Free2 Backlight control
Vin SD_VDD power
However on these displays I have SDA and SCL instead:
Display Function (I think)
GND Ground
VCC Power In
SCL ???
SDA ???
RST Reset
DC Command
CS Chip Select
BL Backlight Control
From my limited understanding, this may be the I2C protocol instead? Can these be used with the color display settings? If so, what proffie pins connect to SDA and SCL?
for an I2C display, you would wire it the same as an OLED display.
However, the current code is not set up for that, so it would need additional code to work.
Also, I2C maxes out at 400kBit/s, which would be very slow for a color display unless it has very few bits. SPI displays generally operate at 10x or even 100x that speed.
It is possible that SDA really means “Data” and SCL really means SCK though.
