Proffie V2.2 / OS7 saber that worked properly now ignites in only one blade style/ font. There is no sound and aux button not working while on or off. Any ideas?
Post your config, pretty much anytime you need help troubleshooting we need to see your config to start. Use pastebin.com and paste the URL.
You can also hook up to Serial Monitor and see what it’s saying in the presets that don’t work.
My guess is that this is an SD problem.
Either way, serial monitor output would be very helpful.
I found my issue. I had a damaged wire hidden by shrink. Thank you anyways.
