Ok good to know. I only have one Proffie saber so far, that Iâm just finishing up, so I donât have any experience with any of the older OS versions.
My false clash encounters were not as extreme as some have experienced and happened mostly early in my build.
Saber is a Korbanth OWK4 with a Goth 3d eco removable chassis. My learning saber, first build.
A few things I noticedâŚ
When I was still testing and removing the chassis frequently, The frequency of false clashes was at its highest. The press fit of the board into the chassis was not all that tight, but I wasnât ready to bust out the E6000 because I was still popping the board up regularly. I ran a few loops of 1/4inch art tape around the chassis and over the top of the micro USB housing, to hold the board down. It also kinda shimmed the chassis a bit resulting in less wobble.
Dramatic reduction in false clashes ensued.
After I was finished with the install and testing, I glued the board in and used the chassis set screw on the saber to tighten the fit and also tightened the rattling and loose D-ring and it resolved the issue entirely.
During this, my clash threshold was at 4.
However clashes were a little harder than I liked to trigger from blade slaps, being a thin neck with a pixel stick show blade. I set the threshold to 3 and it worked great. Sweetspot achieved⌠No flase clashes, just the right amount of force to triggerâŚ
Until I put a Smugglers Outpost Elite 28mm speaker in, and cranked the volume to 2500. I can now feel the air moving and pulsing from my saber. This led to occasional but predictable/repeatable breakthrough clashes. Some fonts, worse than others. The heavy bass events and dark side styles mostly.
All issues now resolved by setting clash threshold to 3.5.
So in my case, it was definitely vibration and volume related it appears. Never had issues with clashes occurring from spirited saber swinging.
Just wanted to add that to the knowledge base.
