OS 7.7 Compile error
I keep getting a compile error that i cant seem to find a fix for. It revolves around the “CONFIGARRAY” and “PRESETS”. This is a new Sabertrio Saber, so im still new to how they modified their saber and trying to figure out how they did this…but even looking at my other working config files for my non-sabertrio sabers…i cant seem to find what is causing the error. I commenting out some of their stuff in the config, but that isnt really helping
#define NUM_BLADES 2
#define VOLUME 2200
#define CLASH_THRESHOLD_G 1.0
#define IDLE_OFF_TIME 60*2*1000
#define MOTION_TIMEOUT 60*10*1000
#define SHARED_POWER_PINS
//#define DISABLE_BASIC_PARSER_STYLES
#define BLADE_DETECT_PIN 17
#define FILTER_CUTOFF_FREQUENCY 60
#define KILL_OLD_PLAYERS
#define ENABLE_SPINS
//#define SAVE_PRESET
//#define FETT263_TWIST_ON
//#define FETT263_TWIST_OFF
//#define KEEP_SAVEFILES_WHEN_PROGRAMMING
//#define ENABLE_ALL_EDIT_OPTIONS
//#define FETT263_EDIT_MODE_MENU
//#define FETT263_HOLD_BUTTON_OFF
//#define FETT263_SAY_COLOR_LIST
//#define FETT263_SAY_COLOR_LIST_CC
//#ifdef CONFIG_PROP
//#include"../props/saber_sabertrio_buttons.h"
//#endif
{ "Sur-blue;common", "tracks/cal-trk.wav",
StylePtr</* copyright Fett263 Rotoscope (Primary Blade) OS6 Style
OS6.7 v4.021
Base Color: Rgb<0,0,255> (0)
PowerUp Effect: Power Burst Emitter
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Blue>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Blue>>>,RgbArg<BASE_COLOR_ARG,Blue>>,RgbArg<BASE_COLOR_ARG,Blue>>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<200>>,TrInstant>,AlphaL<Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,White>,Mix<Int<7710>,Rgb16<65535,65535,62742>,RgbArg<IGNITION_COLOR_ARG,White>>,Mix<Int<3855>,Rgb16<63851,65535,57353>,RgbArg<IGNITION_COLOR_ARG,White>>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,6000>,Int<-7000>>>,TrFade<200>>,EFFECT_IGNITION>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,NavajoWhite>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,NavajoWhite>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
  LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,NavajoWhite>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
  LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,White>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,White>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
  LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
  InOutTrL<TrWipeX<IgnitionTime<>>,TrWipeInX<RetractionTime<>>>>>(),
"preset 1"
{ "Sur-purple;common", "tracks/cal-trk.wav",
OS6.7 v4.021
Base Color: Rgb<173,0,255> (0)
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<173,0,255>>>,
"preset 2"
{ "Sur-yellow;common", "tracks/cal-trk.wav",
OS6.7 v4.021
Base Color: Rgb<255,255,0> (0)
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Yellow>,RgbArg<BASE_COLOR_ARG,Yellow>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Yellow>>,RgbArg<BASE_COLOR_ARG,Yellow>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Yellow>>>,RgbArg<BASE_COLOR_ARG,Yellow>>,RgbArg<BASE_COLOR_ARG,Yellow>>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<122,240,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<107,211,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<107,211,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
  LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<117,214,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
"preset 3"
{ "Sur-orange;common", "tracks/cal-trk.wav",
OS6.7 v4.021
Base Color: Rgb<orange> (0)
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,DarkOrange>,RgbArg<BASE_COLOR_ARG,DarkOrange>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,DarkOrange>>,RgbArg<BASE_COLOR_ARG,DarkOrange>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,DarkOrange>>>,RgbArg<BASE_COLOR_ARG,DarkOrange>>,RgbArg<BASE_COLOR_ARG,DarkOrange>>,
"preset 4"
{ "Sur-white;common", "tracks/cal-trk.wav",
OS6.7 v4.021
Base Color: Rgb<246,224,255> (0)
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<246,224,255>>>,
  TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<200>>,TrInstant>,AlphaL<Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,White>,Mix<Int<7710>,Rgb16<40112,57353,65535>,RgbArg<IGNITION_COLOR_ARG,White>>,Mix<Int<3855>,Rgb16<49276,62191,65535>,RgbArg<IGNITION_COLOR_ARG,White>>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,6000>,Int<-7000>>>,TrFade<200>>,EFFECT_IGNITION>,
  TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,237,122>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,
  Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,250,107>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,250,107>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,
  LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,117>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
"preset 5"
{ "Jinn;common", "tracks/DualFate1.wav",
OS6.7 v4.021
Base Color: Rgb<0,255,0> (0)
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Green>,RgbArg<BASE_COLOR_ARG,Green>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Green>>,RgbArg<BASE_COLOR_ARG,Green>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Green>>>,RgbArg<BASE_COLOR_ARG,Green>>,RgbArg<BASE_COLOR_ARG,Green>>,
"preset 6"
{ "Maul;common", "tracks/DualFate1.wav",
OS6.7 v4.021
Base Color: Rgb<255,0,0> (0)
Layers<
  Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Red>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Red>>>,RgbArg<BASE_COLOR_ARG,Red>>,RgbArg<BASE_COLOR_ARG,Red>>,
"preset 7"
    { "battery", "tracks/cal-trk.wav",
//  SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>(),
  CONFIGARRAY(presets) },
And this is the error(s)
In file included from D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\ProffieOS.ino:614:
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:73:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
   73 | "preset 1"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:107:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  107 | "preset 2"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:141:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  141 | "preset 3"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:175:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  175 | "preset 4"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:209:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  209 | "preset 5"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:243:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  243 | "preset 6"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:277:1: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  277 | "preset 7"
      | const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:282:21: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  282 |    &style_charging, "Battery\nLevel"}
      |                     const char*
In file included from D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\ProffieOS.ino:584:
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:289:15: error: cannot convert 'Preset*' to 'BladeBase*' in initialization
  289 |   CONFIGARRAY(presets) },
      |               Preset*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\common\preset.h:6:24: note: in definition of macro 'CONFIGARRAY'
    6 | #define CONFIGARRAY(X) X, NELEM(X)
In file included from D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\ProffieOS.ino:233:
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\common\common.h:18:28: error: invalid conversion from 'unsigned int' to 'Preset*' [-fpermissive]
   18 | #define NELEM(X) (sizeof(X)/sizeof((X)[0]))
      |                            unsigned int
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\common\preset.h:6:27: note: in expansion of macro 'NELEM'
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:289:3: note: in expansion of macro 'CONFIGARRAY'
Compilation error: cannot convert 'const char*' to 'StyleFactory*' in initialization
Change NUM_BLADES to 1 or uncomment the 2nd blade and add a 2nd blade style to each preset.
You can also try this tool, it helps prevent conflicts in # of blades and other syntax errors and makes it easier to read and pick features, etc.
But you’ll want to remove the 2nd blade in BladeConfig as the tool doesn’t interpret commenting out so it will “see” 2 blades.
That worked! thank you so much! :slight_smile:
You’re welcome
The one last thing i cant seem to get working is the “Battery level indicator” (last style). Everything works fine if i do not include it…
StylePtr<WHITE>(), "Maul"},
   { "battery;common", "tracks/cal-trk.wav",
   StylePtr<WHITE>(), "battery"}
Ive included the last line of he previous style/font above, in case theres any needed/uneccesary commas brackets or something.
The error still reads as:
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:281:4: error: expected '}' before 'StylePtr'
  281 |    StylePtr<WHITE>(), "battery"}
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:279:4: note: to match this '{'
  279 |    { "battery;common", "tracks/cal-trk.wav",
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:38:20: note: to match this '{'
   38 | Preset presets[] = {
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:280:22: error: cannot convert 'const char*' to 'StyleFactory*' in initialization
  280 |     &style_charging, "Battery\nLevel"
      |                      const char*
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:281:32: error: expected declaration before '}' token
D:\BK SABER STUFF\Proffie\ProffieOS-v7.7\ProffieOS\config\BK-sabertrio-2button.h:284:1: error: expected declaration before '}' token
  284 | };
Compilation error: expected '}' before 'StylePtr'
Because you have 2 styles in it. Remove 2nd style.
Should just be
    &style_charging, "BatteryLevel"}
hmmm…doing that has the error of
  280 |     &style_charging, "BatteryLevel"}
      |                      const char*
removing this did the trick.
, "BatteryLevel"
works 100% now
The pointer is showing you the error.
You left the “name” argument from when it had one style when you added the second style.
Only one “name” at the end of the whole preset.
*edit - oh good you got it. Nevermind me.
